1. PLC 可编程逻辑控制器2. absolute 绝对位置
3. absoluteoutput 绝对输出4 .actuator 执行器/作动器5. against 对比6. allocate 分配7. alter 改变/修改8. ambient 环境周围 ambient operating temperature9. analog 模拟 analogoutput10. analysis 分析thecollection an and analysis of data12. applicable 可用the applicableCPU for the module13. assign 分配14. back up battey 备用电池15. barcode reader/ID 条形码阅读器16. base unit 主基板17. baud 波特18. beforehand 事先19. binary 二进制20. buffer memory 缓冲存储器21. bus 总线22. case外壳do notremove the module's print board from the case
23. characteristic特征
I/Ocharacterristic
24. check 校验the datalink status canbe checked25. child-station 子站26. common terminal 公共端
27. compatible 兼容compatiblewith the MODBUS protocol
28. compound 混合compoundsystem communication29. condensation 结露30. condition 条件 conditionsetting
31.conductive 导电 conductivemetal picees32. configuration组态
systemconfiguration
33. configure 组态34. confirm 确认how toconfirm the operation of the module35.consumption 消耗
currentconsumption36. content 目录37. control level 控制级38. convenient 方便moreconvenient and easy-to-use39.conventionaly 传统
whichconventionaly has been used40. conversion转换Analog-Digital conversion module41. converter 转换器42. conveyor 传送conveyorline43. corrosive 腐蚀corrosivegas44. countermeasure 对策
countermeasure for mis-inpute45. cutoff 切断46. debug 调试isrecommended before debugging47. dedicated 屏蔽
cc-linkdedicated cable48.dedicated 专用dedicatedtransmission protocol49. default value 缺省值50. define 解释/阐明Offset value and gain value are defined as follow.51. design 设计design asystem52. device level 现场级53. diagnosis 诊断diagnosisfunction54. digital 数字digitalinpute55. DIN rail 导轨56. diverse 不同的/各种各样的57. download 下载58. duplicate 完全一样59. dust 灰尘60. eliminate 免得61. enterprise level 管理级62. erase 清除63. exceed 超出The numberadmitted must not exceed 200
64.execute 执行date linkis executed using these parameters
65. expand 扩展can beeapanded up to 255 networks66. faulty 故障站67. field bus 现场总线68. fix 固定69. flexibly 灵活的to supporta variety systerm flexibly
70. flow 流量71. format 格式 transmission format72. fuse 融丝
73.graph图标坐标图曲线voltage output characterristicgraph
74.guaranteed 担保nomaloperration cannot be guaranteed75. handle 处理76. hardware manual 硬件手册77. hint 提示programminghints78. humidity 湿度ambientoperating humdlity79. individual 独立的80. inductance 电感 inductanceload81. initiate 实施发起can be initiate by a computer [i`nifieit]82. input 输入83. input point 输入点数84. install 安装85. instruction 指令
the FROMinstruction86. insulation隔离form rubberprovides good insulation87. interface 接口88.interlocking 互锁can be usedfor sequence program interlocking89. internal external 内部外部internal connection90. interrupt 中断excute aninterrupt processing91. invalid无效errorinvalid station function92. magnetic有磁性的magneticfields [maeg`netik]93. main circuit 主回路/线电路94. malfunction 故障causesystem malfunction95. mandatory 强制96. mantenance 维护
maintenancecosts are reduced97. manual 手册User'Manual98. mechanical 机械michanicallife 机械寿命99. module 模块/组件 mount orremove the module100. momentary power failure 瞬时断电101. monitor 监视102. mount 固定 mount orremove the module103. multiple 多样 mutipleremote i/o modules104. negative 负105. observation 观察106. occupy 占用 occupies 1station107. occur 发生108. offline 离线 offlinetest109. offset gain 偏置增益110. oil mist 油雾112. optical loop 光缆回路113. optimum 最佳的optimumcontrol114. output 输出115. overall 总的 overalldistance116. overview 总揽 communication overview117. parameter 参数118. path 路径 transmission path119. per network120. perform 进行normal datalink cannot be performed121. performance specifations 性能规格122. peripheral 外围/外部设备 Whenutilizing peripheral device to assign I/O number.123. phase相 swith offall phases of the power supply124. point 要点125. port 接口Rs232c port126. positive 正127.power line电源线128. power on/off 电源开/关129.precaution 注意事项precaution when configuing system130. print board 印刷电路板131. procedure 过程
follow theprocedure132. programing interface 编程接口/编程界面133. protocol 协议
protocolcommunication issues134. range 范围135. rated input voltage 额定输入电压136. ratio 比率137. recommend 建议 isrecommended before debugging138. reduce 减少/缩小 the numberof steps in operation program can be reduced139. refer to 参照 refer toChapter 6140. register 数据寄存器141. relay 继电器142. remote I/O远程网络143. reserved station预留主站144. resistor 电阻器
load bridgingresistor负载转移电阻
load compensating resistor负荷补偿电阻
load shifting resistor负载移动电阻器 ; 负荷转移电阻
load-resistor contactor负载电阻器接触器 ; 负荷电阻接触器
anode load resistor 释义阳极负载电阻 ; 阳极负载电阻
effect of load resistor负载电阻效应
145. resolution 分辨率
nMaximum resolution最大分辨率146. restriction 限制 norestriction [ri`strikfn]147. retry 重试148. scan扫描link scan149. screw螺丝Teminal-block screw150. seamless network 无缝网络151. sequence programme 顺控程序152. serial communications module 串口通信模块153. series系列154. servo伺服系统155. short 短路156. signal信号157. sink 漏极sink commen158. slot周边元件扩展插槽
159. soures源极sourescommen160. specifications特性inputmodules specifications161. stabilized power supply稳压电源162. standby master station备用主站163. start up起动164. status 状态 data linkstatus165. step drive 步进166. storage 存储 storagearea167. store 存储168. switch off 切断swith offall phases of the power supply169. swith开关170. table 表格171. transfer传送172. transistor晶体管173. transmission speed传输速度174. transmit 传送/传输 data istransmitted in unchanged code175. triac 三端双向可控硅开关元件
176. troubleshooting 故障处理177. unuseble 不可以使用178. upload 上传/上载179. utilize 利用180. verify 校验 verify theset parameter contents181. voltage 电压 highvoltage182. watchdog 看门狗定时器183. width 范围184. wire chips 线头
电阻器
21文章
3885浏览量
62828 -
plc
5024文章
13526浏览量
468905 -
存储器
38文章
7579浏览量
165447
原文标题:你都认识吗?184个PLC常用的英语词汇大全
文章出处:【微信号:gongkongworld,微信公众号:工控资料窝】欢迎添加关注!文章转载请注明出处。
