​详解gitlab+jenkins如何打造ceph的rpm自动编译
电子工程师 来源:fqj 2019-04-24 11:06 次阅读
前置条件
准备jenkins和gitlab的安装,这个过程请自行谷歌
jenkins 插件设置
需要添加的插件:Gitlab Hook、Build Authorization Token Root、Gitlab Authentication、Gitlab
gitlab新建ceph
源码包上传到gitlab
在 http://download.ceph.com/tarballs/ 下载对应的软件包版本,以12.2.12为例
解压软件包
[root@demohost1supdev]#tarzxfceph-12.2.12.tar.gz#解压[root@demohost1ceph-12.2.12]#cdceph-12.2.12[root@demohost1ceph-12.2.12]#lsadminceph-erasure-code-corpusChangeLogCONTRIBUTING.rstdebiando_freebsd.shfusetracemake-apk.shman
pom.xmlREADME.alpine.mdREADME.solarisshare
udevalpineceph-object-corpuscmakeCOPYINGdocDoxyfileINSTALLmake-
debs.shmirroring qa
README.FreeBSDREADME.xiosrcAUTHORSceph.spec
CMakeLists.txtCOPYING-GPL2doc_deps.deb.txtetc
install-deps.shmake-distNEWS
READMEREADME.git-subtreerun-make-check.shSubmittingPatches.rstbinceph.spec.in
CodingStyleCOPYING-LGPL2.1do_cmake.shexampleskeys
make-srpm.shPendingReleaseNotesREADME.aixREADME.md selinux
systemd[root@demohost1ceph-12.2.12]#find.-name".gitignore"|xargsrm-f#关键步骤,剔除掉.gitignore,不然后面编译依赖检查会报错
初始化git,提交到gitlab仓库
[root@demohost1ceph-12.2.12]#gitinitInitializedemptyGitrepositoryin/home/supdev/ceph-12.2.12/.git/[root@demohost1ceph-12.2.12]#pwd/home/demo/ceph-12.2.12[root@demohost1ceph-12.2.12]#gitremoteaddoriginhttp://gitlab.cephdemo.local/diluga/ceph.git[root@demohost1ceph-12.2.12]#gitadd--all.Thefilewillhaveitsoriginallineendingsinyourworkingdirectory.warning:CRLFwillbereplacedbyLFinsrc/rapidjson/thirdparty/gtest/googletest/msvc/gtest_unittest.vcproj.Thefilewillhaveitsoriginallineendingsinyourworkingdirectory.[root@demohost1ceph-12.2.12]#gitcommit-m"Initialcommit"[master(root-commit)85a9fab]InitialcommitCommitter:rootYournameandemailaddresswereconfiguredautomaticallybasedonyourusernameandhostname.Pleasecheckthattheyareaccurate.Youcansuppressthismessagebysettingthemexplicitly:gitconfig--globaluser.name"YourName"gitconfig--globaluser.emailyou@example.comAfterdoingthis,youmayfixtheidentityusedforthiscommitwith:gitcommit--amend--reset-authorThefilewillhaveitsoriginallineendingsinyourworkingdirectory.46084fileschanged,9316748insertions(+)createmode100644.gitmodule_mirrorscreatemode100644.gitmodules...createmode100644udev/60-ceph-by-parttypeuuid.rulescreatemode100644udev/95-ceph-osd.rules[root@demohost1ceph-12.2.12]#gitpush-uoriginmasterUsernamefor'http://gitlab.cephdemo.local':dilugaPasswordfor'http://diluga@gitlab.cephdemo.local':Countingobjects:48328,done.Deltacompressionusingupto32threads.Compressingobjects:100%(47048/47048),done.Writingobjects:100%(48328/48328),83.34MiB|8.29MiB/s,done.Total48328(delta12162),reused0(delta0)remote:Resolvingdeltas:100%(12162/12162),done.Tohttp://gitlab.cephdemo.local/diluga/ceph.git*[newbranch]master->masterBranchmastersetuptotrackremotebranchmasterfromorigin.
jenkins 任务设置
新建一个自由风格的软件项目,输入"rpmbuilid_ceph"
之后在源码管理里面选择git,输入之前新建的gitlab项目信息,设置相应的分支,这里选的是默认master分支
Credentials部分,选择“添加”,输入gitlab的账号和密码如下
之后设置 构建触发器,选择“Build when a change is pushed to GitLab”,记录“GitLab webhook URL”,选择在 “Push Events” 和 “Accepted Merge Request Events” 两种事件类型的时候触发webhook通知。
同时在Secret token 点击“Generate”,记录生成的token字段
最后选择"构建” -> "执行 shell",输入对应的rpm编译打包脚本,点击保存,完成jenkins设置。
脚本如下
#!/bin/bashrm-rf~/rpmbuild/usr/bin/rpmdev-setuptreecp-f./ceph.spec~/rpmbuild/SPECS#gitarchivemaster--prefix=ceph-12.2.12/|bzip2>ceph-12.2.12.tar.bz2mkdirceph-12.2.12mv*ceph-12.2.12cp.gitmodulesceph-12.2.12tar-cvjSfceph-12.2.12.tar.bz2ceph-12.2.12cpceph-12.2.12.tar.bz2~/rpmbuild/SOURCES/cd~/rpmbuild/usr/bin/rpmbuild-bbSPECS/ceph.spec
gitlab webhook设置
打开gitlab 对应的项目,在 settings -> integrations
输入之前的“GitLab webhook URL” 和 token,勾选 push和 merge 两种类型的事件,如果没用到SSL,则取消SSL认证
启动编译
回到jenkins对应的"rpmbuild_ceph"任务列表,点击“立即构建”,开始编译ceph的rpm包,
编译过程可以通过点击具体任务,查看“控制台输出”,看到编辑的当前进度状态。
编译完成后,RPM包会存储在jenkins节点的/root/rpmbuild/下。
总结
上面的设置需要注意的有3点
代码提交到gitlab一定要剔除掉“.gitignore”,当然你可以手工去修改具体内容,不然后面编译会报错。
jenkins是基于gitlab的pull和merge事件来触发后台的自动编译,所有后续在gitlab上面的代码pull和merge操作都会触发相应版本的rpm包编译,注意这里只针对源码的master分支做了处理,各位根据实际情况进行调整。
源码里面的“ceph.spec”文件写死了一些配置,如果你改变了编译流程细节,则需要修改对应的配置内容,比如源件包名称必须是"ceph-12.2.12.tar.bz2",具体可以参考ceph.spec内容。
  • 编译
  • 脚本
  • jenkins
原文标题:​gitlab+jenkins打造ceph的rpm自动编译
文章出处:【微信号:cephbook,微信公众号:Ceph对象存储方案】欢迎添加关注!文章转载请注明出处。
    基于服务器安装node环境的步骤
    jenkins+gitlab+vue进行自动化构建部署项目打包
    发表于 05-22 11:06
    Gitlab安装及集成LDAP
    https://packages.gitlab.com/install/repositories/gitlab/gitlab-ce/script.rpm.sh | sudo bash
    发表于 07-09 06:28
    ansible playbook+jenkins如何实现自动新增域名
    ansible-playbook+jenkins实现自动新增域名
    发表于 06-03 11:58
    Ceph是什么?Ceph的统一存储方案简析
    Ceph是什么?Ceph是一个开源的分布式存储系统,可大规模扩展、高性能、无单点故障,在普通的服务器上可以支持到PB级容量,商用机器上支持的容量可以达到EB级别。Ceph的竞争力市面上提供云存储
    发表于 10-08 15:40
    jenkins简单的使用教程_jenkins安装与配置
    jenkins是一个开源软件项目,是基于Java开发的一种持续集成工具,用于监控持续重复的工作,旨在提供一个开放易用的软件平台,使软件的持续集成变成可能。开发第一步、提交第二步、编译第三步、测试第四步、发布第五步
    发表于 12-20 18:40 8643次阅读
    <b class='flag-5'>jenkins</b>简单的使用教程_<b class='flag-5'>jenkins</b>安装与配置
    jenkins有什么用_jenkins如何自动部署
    Jenkins是一个开源的、提供友好操作界面的持续集成(CI)工具,起源于Hudson(Hudson是商用的),主要用于持续、自动的构建/测试软件项目、监控外部任务的运行(这个比较抽象,暂且写上,不做解释)。
    发表于 12-20 19:06 3.7w次阅读
    <b class='flag-5'>jenkins</b>有什么用_<b class='flag-5'>jenkins</b>如何<b class='flag-5'>自动</b>部署
    jenkins自动化部署
    本文详细介绍Jenkins的简单使用—jenkins自动化部署。
    的头像 发表于 02-06 11:27 4856次阅读
    <b class='flag-5'>jenkins</b><b class='flag-5'>自动</b>化部署
    jenkins持续集成原理
    本文详细介绍了jenkins持续集成原理。持续集成就是为解决程序代码提交质量低,提交内容导致原有系统的bug,按时或按需自动编译版本,自动进行自动
    的头像 发表于 02-06 11:43 4179次阅读
    Jenkins是什么_Jenkins常用功能_jenkins的使用总结
    本文详细回答了Jenkins是什么,Jenkins常用功能以及jenkins的使用总结。Jenkins 是一个可扩展的持续集成引擎。Jenkins
    发表于 02-06 14:44 2.8w次阅读
    <b class='flag-5'>Jenkins</b>是什么_<b class='flag-5'>Jenkins</b>常用功能_<b class='flag-5'>jenkins</b>的使用总结
    Prelink的交叉编译和使用详解
    Prelink的交叉编译和使用详解
    的头像 发表于 06-20 12:03 3639次阅读
    Prelink的交叉<b class='flag-5'>编译</b>和使用<b class='flag-5'>详解</b>
    ceph-zabbix监控Ceph集群文件系统
    ceph-zabbix.zip
    发表于 04-26 09:48 2次下载
    <b class='flag-5'>ceph</b>-zabbix监控<b class='flag-5'>Ceph</b>集群文件系统
    autobuild-ceph远程部署Ceph自动构建Ceph
    autobuild-ceph.zip
    发表于 05-05 11:09 2次下载
    autobuild-<b class='flag-5'>ceph</b>远程部署<b class='flag-5'>Ceph</b>及<b class='flag-5'>自动</b>构建<b class='flag-5'>Ceph</b>
    基于Jenkins+GitLab+Maven实现代码自动打包编译发布
    Jenkins是一个独立开源的持续集成和持续交付工具,用于自动化构建、测试和部署软件项目。
    的头像 发表于 11-20 09:57 5321次阅读
    基于<b class='flag-5'>Jenkins+GitLab</b>+Maven实现代码<b class='flag-5'>自动</b>打包<b class='flag-5'>编译</b>发布
    Jenkins 与 SonarQube 集成部署,自动化代码质量监控
    前言 强化代码质量,加速软件交付!Jenkins 携手 SonarQube,与华为云 Flexus X 云服务器强强联合,打造自动化代码质量监控新生态。Flexus X 以其灵活的算力配置、卓越
    的头像 发表于 01-07 17:24 377次阅读
    <b class='flag-5'>Jenkins</b> 与 SonarQube 集成部署,<b class='flag-5'>自动</b>化代码质量监控
    基于 Docker 与 Jenkins 实现自动化部署
    前言 重塑自动化部署新高度,Docker 携手 Jenkins,在华为云 Flexus X 云服务器的加持下,引领持续集成与部署的新纪元。Flexus X 以其卓越的性能、灵活的资源配置和高效的成本
    的头像 发表于 01-07 17:25 276次阅读
    基于 Docker 与 <b class='flag-5'>Jenkins</b> 实现<b class='flag-5'>自动</b>化部署
