基于LED1202 12路低静态电流LED驱动解决方案
电子工程师 来源:陈翠 2019-05-11 10:12 次阅读
ST公司LED1202是12路低静态电流LED驱动器,保证了5V输出驱动功能,而每路能提供高达20 mA和电压裕度仅为350mV.每路的输出电流由8位模拟和12位数字调光控制来单独调整.慢开时间和慢关时间提高了系统的低噪音性能,而移相功能有助于降低浪涌电流,八种模式存储在内部寄存器而不需要MCU干预进行自动定序.器件的1.8V兼容的I²C接口基于快速模式指标,工作高达400kHz.工作电压2.6V-5V,每路的电流能力20mA,16mA时的12路的电流匹配度1%,2.5mA时的匹配度2%,8位模拟调光单独控制,12位本地PWM分辨率.LED1202具有LED开路检测和超温保护.主要用在RGB照明如可穿戴电子学,电池供电设备和手持附件.本文介绍了LED1202主要特性,框图和驱动器电路框图,以及评估板STEVAL-LLL007V1主要特性,电路图和材料清单.
The LED1202 is a 12-channel low quiescent current LED driver; it guarantees 5 V output driving capability and each channel is able to provide up to 20 mA with a headroom voltage of 350 mV (typ.) only. The output current can be adjusted separately for each channel by 8-bit analog and 12-bit digital dimming control.
A slow turn-on and turn-off time improves the system low noise generation performance; moreover, the phase shifting function helps to reduce the inrush current. Eight patterns can be stored in the internal registers for automatic sequencing without MCU intervention.
The pattern sequence can be also configured for duration time and number of repetition. For multi-device applications, a common clock domain can be shared for timing synchronization. The device includes thermal shutdown and open LED detection.
The device I²C interface is based on fast mode specification and works up to 400 kHz. Eight I²C addresses are possible by using two configuration pins (A0/A1) only.
The LED1202 is available in WLCSP20 package 1.71 x 2.16 x 0.5 mm with 0.4 mm pitch and in QFN20 3x3 package 3 x 3 x 0.6 mm with 0.5 mm pitch.
LED1202主要特性:
Supply range from 2.6 V to 5 V
12 channels for single LED
20 mA current capability per channel
1% (typ.) current matching at 16 mA and 2% (typ.) at 2.5 mA
1.8 V compatible I²C control interface
8-bit analog dimming individual control
12-bit local PWM resolution
8 programmable patterns
Programmable pattern sequence
Synchronization for multi-device application
Phase shifting between channels
Open LED detection
Overtemperature protection
8 configurable I²C slave addresses plus global address
Fault flag pin
LED1202应用:
• RGB LED lighting, fade-in and fade-out breathing effect,indicator lights for:
– Wearable electronics
– Battery powered devices
– Portable accessories
图1.LED1202简化框图
图2.LED1202驱动器电路框图
图3.菊花链共通时钟域配置概述图
评估板STEVAL-LLL007V1
Evaluation kit for the LED1202 12-channel low quiescent current LED driver STMicroelectronics STEVAL-LLL007V1 Evaluation Kit is configured to evaluate the operation of the LED1202 driver. The STEVAL-LLL007V1 Evaluation Kit includes the STEVAL-LLL007M1 main board and the STEVAL-LLL007D1 and STEVAL-LLL007D2 panel boards. The main board connects to a NUCLEO-L073RZ development platform running the STSW-LLL007FW firmware. This firmware comes with pre-configured random and wave patterns for use in standalone mode.
Users are able to develop your own pattern sequences by connecting the Nucleo platform to a PC running a dedicated GUI program, giving access to all the LED driver settings. The STEVAL-LLL007D1 panel board and the STEVAL-LLL007D2 panel board connected with an external power source via the J13 connector on the STEVAL-LLL007M1 board achieves maximum luminosity.
评估板STEVAL-LLL007V1主要特性:
3x LED1202 12-channel low quiescent current LED drivers embedded on main board
Can immediately drive 36 white LEDs available on main board, to help you get started
Includes additional panel boards to let you expand your development:
1 with 36 white LEDs
1 with 12 RGB LEDs
Designed for use with NUCLEO-L073RZ development platform running the STSW-LLL007FW firmware
E5V connector to supply STM32 Nucleo board and additional panels
Supplied with a range of default patterns
GUI for advanced driver configuration and customized pattern generation
CE Certified
RoHS and China RoHS compliant
WEEE compliant (2012/19/UE RAEE II)
评估板STEVAL-LLL007V1包括:
STEVAL-LLL007D1 panel board with 36 white LEDS
STEVAL-LLL007D2 panel board with 12 RGB LEDS
图4.评估板STEVAL-LLL007V1外形图
图5.评估板STEVAL-LLL007V1电路图(1)
图6.评估板STEVAL-LLL007V1电路图(2)
图7.评估板STEVAL-LLL007V1电路图(3)
评估板STEVAL-LLL007M1材料清单:
评估板STEVAL-LLL007D1材料清单:
评估板STEVAL-LLL007MD2材料清单:
  • led
    led
  • LED驱动
    基于四LED驱动驱动解决方案
    STP4CMP是基于电荷泵的四LED驱动器,设计用于RGB照明或LCD显示器背光。支持正向电压高达成3.8V的LED,工作电压2.7V~5.5V,四
    发表于 06-13 10:19 4041次阅读
    隔离式LED驱动电源设计及解决方案
    本帖最后由 eehome 于 2013-1-5 10:06 编辑 隔离式LED驱动电源方案高效率,高功率因数,安全隔离,符合EMI 标准,高电流控制精度,高可靠性、体积小、成本低
    发表于 06-19 14:44
    LED照明的直流驱动电路解决方案
    。作为卤素灯低压照明的一种替代技术,LED照明日益流行。与卤素灯泡不同的是,LED没有效率、可靠性差以及使用寿命短等问题的困扰。本文描述了一种在直流照明系统中驱动大功率
    发表于 08-27 16:14
    安森美LED驱动解决方案
    的NUD4001低成本集成电流源可以替代汽车内部照明分立解决方案,在和高交流或直流电压应用中(6至120V)驱动LED,这样就不再需要单独
    发表于 05-15 10:57
    用于驱动LED的典型离散解决方案
    。如何提高能效。传统意义上,LED都是由离散解决方案驱动的。图1显示了三种典型的方案:运算放大器(op amp)(方案1)、直接与汽车电池连
    发表于 11-11 07:53
    安森美LED照明驱动解决方案
    安森美LED照明驱动解决方案
    发表于 04-14 15:50 57次下载
    安森美<b class='flag-5'>LED</b>照明<b class='flag-5'>驱动</b><b class='flag-5'>解决方案</b>
    LED驱动器探讨和实用解决方案
    关键词:LED,光电器件,无源元件,摘要: LED 是由电流驱动的器件,其亮度与正向电流呈比例关系。众多的便携电子产品均需要背景灯
    发表于 05-04 07:53 42次下载
    Linear LT3760 8LED驱动解决方案 (应用电
    Linear LT3760 8LED驱动解决方案 (应用电路) Linear 公司的LT3760是集成了升压DC/DC控制器的 8
    发表于 02-10 08:32 1022次阅读
    Linear LT3760 8<b class='flag-5'>路</b><b class='flag-5'>LED</b><b class='flag-5'>驱动</b><b class='flag-5'>解决方案</b> (应用电
    电流LED的应用、经济线性恒流稳压解决方案
    电流LED的应用、经济线性恒流稳压解决方案 凭借着节能、长使用寿命及色彩组合丰富等优势,LED照明目前已成为增速最快的半导体领域之一,近
    发表于 02-25 10:46 2517次阅读
    <b class='flag-5'>低</b><b class='flag-5'>电流</b><b class='flag-5'>LED</b>的应用、经济线性恒流稳压<b class='flag-5'>解决方案</b>
    LED电源解决方案:控制正向电流
    LED厂商建议通过控制正向电流使发光二极管保持额定的光通量和特定的色温。鉴于LED的亮度与正向电流值成正比,这个控制方法是最佳的LED电源
    发表于 07-21 09:47 1544次阅读
    <b class='flag-5'>LED</b>电源<b class='flag-5'>解决方案</b>:控制正向<b class='flag-5'>电流</b>
    基于电荷泵的四LED驱动解决方案
    ST公司的STP4CMP是基于电荷泵的四LED驱动器,设计用于RGB照明或LCD显示器背光。支持正向电压高达成3.8V的LED,工作电压2.7V~5.5V,四
    发表于 08-14 11:31 1263次阅读
    基于电荷泵的四<b class='flag-5'>路</b><b class='flag-5'>LED</b><b class='flag-5'>驱动</b><b class='flag-5'>解决方案</b>
    意法半导体最新发布可编程12通道RGB-LED驱动
    意法半导体12通道LED驱动LED1202采用专利技术,可防止在“流水灯”或“跑马灯”LED动画特效中出现分散注意力的闪光现象,使智能家居
    发表于 12-02 14:47 1013次阅读
    LED1202JR STMicroelectronics LED1202 12通道LED驱动
    电子发烧友网为你提供ST(ST)LED1202JR相关产品参数、数据手册,更有LED1202JR的引脚图、接线图、封装手册、中文资料、英文资料,LED1202JR真值表,LED1202
    发表于 10-29 12:28
    LED1202 LED驱动器实现更多自主可能性
      菊花链 LED1202 更容易,因为它们都使用只需要两个地址引脚(A0 和 A1)的微型封装,尽管它们能够使用 I 2 C连接多达八个设备。
    的头像 发表于 05-15 11:15 2096次阅读
    用双电流运放来驱动汽车 LED
    用双电流运放来驱动汽车 LED
    发表于 11-04 09:51 1次下载
    用双<b class='flag-5'>路</b>大<b class='flag-5'>电流</b>运放来<b class='flag-5'>驱动</b>汽车 <b class='flag-5'>LED</b> 灯
