AP72200高效同步DC-DC升降压转换器解决方案
电子工程师 来源:陈翠 2019-05-11 10:06 次阅读
Diodes公司的AP72200是大电流同步DC/DC降压转换器,具有高效率,极好的瞬态响应和大DC输出精度.它采用四开关H桥配置,支持降压和升压工作,升/降压提供大于2A的输出电流.AP72200具有I2C兼容两线串行接口,包括双向串行数据线,SDA和串行时钟线,SCL.支持SCL时钟速率高达3.4MHz;此外,还具有UVLO,OTP和OCP保护电路.输入电压VIN从2.3V到5.5V,输出电压从2.6V-5.14V,连续输出电流2A,当VOUT=3.4V和 VIN>2.9V时效率高达97%.主要用在智能手机,平板电脑和其它手持设备.本文介绍了AP72200主要特性,功能框图,典型应用以及评估板AP72200-EVM主要特性,电路图,材料清单和PCB设计图.
The AP72200 is a high-current synchronous buck-boost converter providing high efficiency, excellent transient response, and high DC output accuracy. The targeted applications are smartphones, tablets, and other handheld devices. The AP72200 utilizes a four-switch H-bridge configuration to support buck and boost operation. The buck-boost provides at least 2A output current.
The current control scheme handles wide input/output voltage ratios and provides low external component count with outstanding performance in line/load transient response and seamless transition between buck and boost modes.
The AP72200 features I2C compatible, two-wire serial interface consisting of a bidirectional serial-data line, SDA, and a serial-clock line, SCL. It supports SCL clock rates up to 3.4MHz.
The AP72200 also features UVLO, OTP, and OCP to protect the circuit.
This IC is available in a small 2.125mm × 1.750mm, 20 balls WLCSP package.
AP72200主要特性:
• VIN 2.3V to 5.5V
• Output Voltage Range: 2.6V to 5.14V
• 2A Continuous Output Current for VOUT=3.4V and VIN>2.9V Efficiency Up to 97%
• 2.5MHz Switching Frequency
• I2C Interface
• Selectable MODE PFM/PWM
• Ultrasonic Operation Programmable through I2C
• Power Good Indicator with 5MΩ Internal Pull-Up
• Adjustable Overcurrent Limit
• Fully Protected for Overcurrent, Short Circuit, Reverse Current Protection, Overtemperature, and UVLO
• Totally Lead-Free & Fully RoHS Compliant (Notes 1 & 2)
• Halogen and Antimony Free. “Green” Device (Note 3)
AP72200应用:
• Smartphones
• Tablets
• Portable Consumer Devices
图1.AP72200框图
图2. AP72200典型应用
评估板AP72200-EVM
The AP72200 is a high current synchronous buck-boost converter providing high efficiency, excellent transient response and high DC output accuracy. The targeted applications are smartphones, tablets, and other handheld devices. The AP72200 utilizes a four switches H-bridge configuration to support buck and boost operation. The buck-boost provides at least 2A output current.
The AP72200 features I2C compatible, 2-wires serial interface consisting of a bidirectional serial-data line, SDA, and a serial-clock line, SCL. It supports SCL clock rates up to 3.4MHz.
This IC is available in a small 2.125x1.750mm, 20 balls WLCSP package
评估板AP72200-EVM主要特性:
 VIN 2.3V to 5.5V
 Output Voltage range: 2.6V to 5.14V
 2A Continuous Output Current for VOUT=3.4V and VIN > 2.9V Efficiency Up to 97%
 2.5MHz Switching Frequency
 I2C Interface
 Selectable MODE PFM/PWM
 Ultrasonic Operation Programmable through I2C
 Power Good Indicator with 5M Internal Pull-up
 Adjustable Overcurrent Limit
 Full Protected for Overcurrent,Short Circuit,Reverse Current Protection, Over Temperature, and UVLO
 Totally Lead-Free & Fully RoHS Compliant
 Halogen and Antimony Free. “Green” Device
应用:
 Smartphones
 Tablets
 Portable Consumer Devices
图3.评估板AP72200-EVM外形图
图4.评估板AP72200-EVM电路图
评估板AP72200-EVM材料清单:
图5.评估板AP72200-EVM PCB设计图:顶层
图6.评估板AP72200-EVM PCB设计图:底
  • 转换器
  • DC-DC
    DC-DC转换器是什么及其参数
    DC-DC转换器是什么及其参数DC/DC 转换器为转变输入电压后有效输出固定电压的电压转换器
    发表于 11-14 11:11
    DC-DC转换器
      DC-DC转换器为转变输入电压后有效输出固定电压的电压转换器DC/DC转换器分为
    发表于 03-09 14:20
    DC-DC转换器
    发表于 04-19 11:43
    AP3429A应用电路2A降压DC-DC转换器
    AP3429A的应用电路是2A降压DC-DC转换器。在高负载时,恒定频率PWM控制可实现出色的稳定性和瞬态响应。无需外部补偿组件。 AP34
    发表于 03-07 09:54
    AP3419应用电路2A降压DC-DC转换器
    AP3419的应用电路是2A降压DC-DC转换器。在高负载时,恒定频率PWM控制可实现出色的稳定性和瞬态响应。无需外部补偿组件。 AP341
    发表于 03-08 09:35
    AP3502 340kHz,2A同步DC-DC降压转换器的典型应用
    AP3502 340kHz,2A同步DC-DC降压转换器的典型应用。 AP3502是一款340k
    发表于 03-14 06:17
    电子书:DC-DC 转换器的应用与设计方案
    本书介绍了电源转换器DC/DC转换器为转变输入电压后有效输出固定电压的电压转换器DC/
    发表于 03-14 16:52
    高效率的Ap1603升压型DC-DC转换器的应用
    Ap1603升压型DC-DC转换器的典型应用,Vout = Adj。 AP1603是一款高效率升压型DC
    发表于 06-18 07:34
    DC-DC电源转换器/基准电压源介绍
    AP15014.高效率无电感DC-DC电源转换器FAN56605.小功率极性反转电源转换器ICL76606.
    发表于 10-28 08:44
    一款非常高效DC-DC降压转换器
    描述3.3V/5A DC-DC 转换器这是一款非常高效DC-DC 降压转换器,基于德州仪器
    发表于 07-07 06:47
    非隔离DC-DC转换器的功能特点
    SynQor为高输入电压的非隔离DC-DC转换器提供了高功率、可变电压、输出电压的独具特色解决方案。SynQor军用高压、非隔离DC-DC转换器
    发表于 09-29 17:45 2500次阅读
    高效DC-DC降压转换器
    电子发烧友网站提供《高效DC-DC降压转换器.zip》资料免费下载
    发表于 07-08 10:09 14次下载
    <b class='flag-5'>高效</b>的<b class='flag-5'>DC-DC</b><b class='flag-5'>降压</b><b class='flag-5'>转换器</b>
    AP3418高效率同步DC-DC降压转换器应用笔记
    电子发烧友网站提供《AP3418高效率同步DC-DC降压转换器应用笔记.pdf》资料免费下载
    发表于 07-25 11:21 1次下载
    <b class='flag-5'>AP</b>3418<b class='flag-5'>高效率同步</b><b class='flag-5'>DC-DC</b><b class='flag-5'>降压</b><b class='flag-5'>转换器</b>应用笔记
    YS1601:高效率同步降压DC-DC转换器英文资料
    电子发烧友网站提供《YS1601:高效率同步降压DC-DC转换器英文资料.pdf》资料免费下载
    发表于 12-28 10:23 0次下载
    TDK 加强型300W DC-DC升降压转换器
    DC-DC升降压转换器
    的头像 发表于 02-06 10:41 640次阅读
    TDK 加强型300W <b class='flag-5'>DC-DC</b><b class='flag-5'>升降压</b><b class='flag-5'>转换器</b>
