基于CC3235XSimpleLink Wi-Fi双波段单片解决方案
电子工程师 来源:陈翠 2019-05-11 10:04 次阅读
TI公司的CC3235S和CC3235SF是SimpleLink™ Wi-Fi®双波段单片解决方案. CC3235S包括256KB RAM,IoT网络安全性,器件身份以及MCU级别的安全特性如文件系统加密,用户IP(MCU图)加密,安全引导和调试安全性.而CC3235SF基于CC3235S,除了256KB RAM外还集成了用户专用的1MB可执行闪存.SimpleLink™ Wi-Fi® CC3235x系列产品是双波段系统级芯片(SoC),单片内集成了应按用处理器Arm® Cortex®-M4 MCU和运行所有Wi-Fi和互联网逻辑层的网络处理器包括802.11 a/b/g/n双波段 2.4 GHz和5 GHz无线电,基带,MAC和功能强大的硬件加密引擎.这些器件支持 802.11a (5 GHz),BLE/2.4 GHz无线电共存,可选择的天线,具有FIPS 140-2 Level 1证书的增强安全性,有多达16个同时存在安全插座,认证证书的证书请求文件(CSR),在线证书状态协议(OCSP),Wi-Fi®联盟证书以及改善了快速扫描性能,IPv4和IPv6 TCP/IP 堆栈,工作温度–40℃到 +85℃ ,主要用在物联网应用如建筑物和家庭自动化,HVAC系统和调温器,视频监视,视频门铃和低功耗照相机,以及其建筑物安全系统和电子锁,器械,资产跟踪,工厂自动化,医疗和健康设备以及电网基础设备.本文介绍了CC3235S主要特性,SimpleLink™ Wi-Fi®解决方案框图,硬件概述图和嵌入软件概述图,以及开发板CC3235 LaunchPad™框图,电路图和材料清单和PCB设计图.
The dual-band wireless MCU CC3235x device comes in two variants, CC3235S and C3235SF.
• The CC3235S includes 256KB of RAM,IoT networking security, device identity/keys, as well as, MCUlevel security features such as file system encryption, user IP (MCU image) encryption, secure bootand debug security.
• The CC3235SF builds on the CC3235S and integrates a user-dedicated 1MB of executable flash inaddition to the 256KB of RAM.
Simplify your IoT design with a Wi-Fi CERTIFIED™ wireless microcontroller (MCU). The SimpleLink™ Wi-Fi® CC3235x device family is a dual-band system-on-chip (SoC) solution that integrates two processorswithin a single chip, including:
• Application processor: Arm® Cortex®-M4 MCU with a user-dedicated 256KB of RAM and an optional1MB of executable flash
• Network processor to run all Wi-Fi and internet logical layers. This ROM-based subsystem completelyoffloads the host MCU and includes an 802.11 a/b/g/n dual-band 2.4 GHz and 5 GHz radio, baseband,and MAC with a powerful hardware cryptography engine.
These devices introduce new capabilities that further simplify the connectivity of things to the Internet. Themain new features include:
• 802.11a (5 GHz) support
• BLE/2.4 GHz radio coexistence
• Antenna selection
• Enhanced security with FIPS 140-2 Level 1 certification and more (1)
• Up to 16 concurrent secure sockets
• Certificate sign request (CSR)
• Online certificate status protocol (OCSP)
• Wi-Fi® Alliance certified for IoT applications with low-power capabilities and more
• Hostless mode for offloading template packet transmissions
• Improved fast scan
The CC3235x device family is part of the SimpleLink™ MCU platform—a common, easy-to-usedevelopment environment based on a single-core software development kit (SDK) with a rich tool set andreference designs. The E2E™ community supports Wi-Fi®, Bluetooth® low energy, Sub-1 GHz, and hostMCUs. For more information, visit or
CC3235S主要特性:
• Multiple-core architecture, system-on-chip (SoC)
• 802.11 a/b/g/n: 2.4 GHz and 5 GHz
• FIPS 140-2 Level 1 Certification
• Multilayered security features, help developersprotect identities, data, and software IP
• Low-Power Modes for battery powered application
• Coexistence with 2.4 GHz Radios
• Industrial temperature: –40℃ to +85℃
• Wi-Fi CERTIFIED™ by the Wi-Fi Alliance®
• Application microcontroller subsystem:
– Arm® Cortex®-M4 core at 80 MHz
– User-dedicated memory
– 256KB RAM
– Optional 1MB executable Flash
– Rich set of peripherals and timers
– 27 I/O pins with flexible multiplexing options
UART, I2S, I2C, SPI, SD, ADC,8-bit parallel interface
– Timers and PWM
• Wi-Fi network processor subsystem:
– Wi-Fi® core:
– 802.11 a/b/g/n 2.4 GHz and 5 GHz
– Modes:
– Access Point (AP)
– Station (STA)
– Wi-Fi Direct® (only supported on 2.4 GHz)
– Security:
– WEP
– WPA™/ WPA2™ PSK
– WPA2 Enterprise
– Internet and application protocols:
– HTTPs server, mDNS, DNS-SD, DHCP
– IPv4 and IPv6 TCP/IP stack
– 16 BSD sockets (fully secured TLS v1.2 andSSL 3.0)
– Built-in power management subsystem:
– Configurable low-power profiles (always,intermittent, tag)
– Advanced low-power modes
– Integrated DC/DC regulators
• Multilayered security features:
– Separate execution environments
– Networking security
– Device identity and key
– Hardware accelerator cryptographic engines(AES, DES, SHA/MD5, CRC)
– Application-level security (encryption,authentication, access control)
– Initial secure programming
– Software tamper detection
– Secure boot
– Certificate signing request (CSR)
– Unique per device key pair
• Application throughput:
– UDP: 16 Mbps, TCP: 13 Mbps
– Peak: 72 Mbps
• Power-Management Subsystem:
– Integrated DC/DC converters support a widerange of supply voltage:
– VBAT wide-voltage mode: 2.1 V to 3.6 V
– VIO is always tied with VBAT
– Advanced low-power modes:
– Shutdown: 1 μA, hibernate: 4.5 μA
– Low-power deep sleep (LPDS): 120 μA
– Idle connected (MCU in LPDS): 710 μA
– RX traffic (MCU active): 59 mA
– TX traffic (MCU active): 223 mA
• Wi-Fi TX power:
– 2.4 GHz: 18.0 dBm at 1 DSSS
– 5 GHz: 18.1 dBm at 6 OFDM
• Wi-Fi RX sensitivity:
– 2.4 GHz: –96 dBm at 1 DSSS
– 5 GHz: –92 dBm at 6 OFDM
• Clock source:
– 40.0-MHz crystal with internal oscillator
– 32.768-kHz crystal or external RTC
• RGK package
– 64-Pin, 9-mm × 9-mm very thin quad flatnonleaded (VQFN) package, 0.5-mm pitch
• Device supports SimpleLink™ MCU PlatformDeveloper ’s Ecosystem
CC3235X应用:
• For Internet of Things applications, such as:
– Building and Home Automation:
• HVAC Systems & Thermostat
• Video Surveillance, Video Doorbells, and
Low-Power Camera
• Building Security Systems & E-locks
– Appliances
– Asset Tracking
– Factory Automation
– Medical and Healthcare
– Grid Infrastructure
图1.CC3235x SimpleLink™ Wi-Fi®解决方案框图
图2.CC3235x硬件概述图
图3.CC3235x嵌入软件概述图
图4.CC3235S和CC3235SF高等级架构图
图5.CC3235x引擎区域图
CC3235x引擎区域图材料清单:
图6.带和不带共存的CC3235x RF电路图
CC3235x RF部分材料清单:
CC3235 SimpleLink™ LaunchPad™开发板LAUNCHXL-CC3235x
The CC3235 SimpleLink™ LaunchPad™ Development Kit (LAUNCHXL-CC3235x) is a low-costevaluation platform for Arm® Cortex®-M4-based MCUs. The LaunchPad (LP) design highlights theCC3235 Dual Band (2.4 GHz and 5 GHz) wireless MCU system on a chip. The CC3235 LaunchPad™ kitalso features temperature and accelerometer sensors, programmable user buttons, RGB LED for customapplications, and onboard emulator for debugging. The stackable headers of the LAUNCHXL-CC3235xdemonstrate how easy it is to expand the functionality of the LaunchPad™ kit. BoosterPack™ Plug-inModules allow for interfacing with other peripherals such as graphical displays, audio codecs, antennaselection, environmental sensing, and more.
The CC3235 LaunchPad™ kit, referred to by its part number LAUNCHXL-CC3235x, is a low-costevaluation platform for Arm® Cortex®-M4-based MCUs. The LaunchPad™ design highlights the CC3235Internet-on-a chip™ solution and Wi-Fi® capabilities. The CC3235 LaunchPad™ also features temperatureand accelerometer sensors, programmable user buttons, RGB LED for custom applications, and onboardemulation for debugging. The stackable headers of the CC3235 LaunchPad™ XL interface demonstratehow easy it is to expand the functionality of the LaunchPad™ when interfacing with other peripherals onmany existing BoosterPack™ add-on boards, such as graphical displays, audio codecs, antenna selection,environmental sensing, and more. There are two variants of the LaunchPad™: LAUNCHXL-CC3235S andLAUNCHXL-CC3235SF. This user’s guide applies to both variants, and any differences are noted inrelevant sections.
Multiple development environment tools are also available, including the Eclipse-based Code ComposerStudio™ (CCS) integrated development environment (IDE) and IAR Embedded Workbench® from TexasInstruments™. More information about the LaunchPad™, the supported BoosterPack™ modules, and theavailable resources can be found at the LaunchPad™ portal from TI. Also, visit the CC3235 Wiki page fordesign resources and example projects.
开发板LAUNCHXL-CC3235x主要特性:
• CC3235x Dual Band (2.4GHz and 5GHz) SimpleLink™ Wi-Fi®, Internet-on-a chip™ solution withintegrated MCU
• 40-pin LaunchPad™ pinout that leverages the BoosterPack™ ecosystem
• on-board XDS110-based JTAG emulation with serial port for flash programming
• Two buttons and RGB LED for user interaction
• Back-channel universal asynchronous receiver/transmitter (UART) through USB to PC
• Onboard chip antenna with U.FL connector for conducted testing
• Onboard accelerometer and temperature sensor
• Micro USB connector for power and debug connections
开发板LAUNCHXL-CC3235x包括:
• CC3235 LaunchPad™ development tool (LAUNCHXL-CC3235x)
• Micro USB cable
• Quick Start Guide
图7.开发板CC3235 LaunchPad™概述图
图8.开发板CC3235 LaunchPad™框图
开发板CC3235 LaunchPad™硬件特性:
• CC3235 SimpleLink™ Wi-Fi®, Internet-on-a chip™ solution with integrated MCU
• 40-pin LaunchPad™ standard that leverages the BoosterPack™ ecosystem
• TI Standard XDS110-based JTAG emulation with serial port for flash programming
• Supports both 4-wire JTAG and 2-wire SWD
• Two buttons and a RGB LED for user interaction
• Virtual COM port UART through USB on PC
• Onboard chip antenna with U.FL or SMA for conducted testing, selectable using 0-Ω resistors
• Onboard accelerometer and temperature sensor for out-of-box demo, with the option to isolate themfrom the inter-integrated circuit (I2C) bus
• Headers for current measurement and external JTAG connection, with an option to use the onboardXDS110 to debug customer platforms
• Bus-powered device, with no external power required for Wi-Fi®
• Long-range transmission with a highly optimized antenna (200-meter typical in open air with a 6-dBiantenna AP)
• Can be powered externally, working down to 2.3 V (typical)
图9.开发板CC3235 LaunchPad™电池加电图
图9.开发板CC3235SFLaunchPad™顶层装配图
图10.开发板CC3235SLaunchPad™顶层装配图
图11.开发板CC3235 LaunchPad™电路图(1)
图12.开发板CC3235 LaunchPad™电路图(2)
图13.开发板CC3235 LaunchPad™电路图(3)
图14.开发板CC3235 LaunchPad™电路图(4)
图15.开发板CC3235 LaunchPad™电路图(5)
图16.开发板CC3235 LaunchPad™电路图(6)
  • Wi-Fi
    TI CC3100汽车电子服务设备加装Wi-Fi功能解决方案
    CC3100设备是业界首款用于无线网络解决方案Wi-Fi CERTIFIED芯片。CC3100设备是新的SimpleLink Wi-Fi
    发表于 08-04 13:50 2540次阅读
    TI <b class='flag-5'>CC</b>3100汽车电子服务设备加装<b class='flag-5'>Wi-Fi</b>功能<b class='flag-5'>解决方案</b>
    SimpleLink™ Wi-Fi® CC3100 BoosterPack 模块
    ®,实现 物联网 (IoT) 应用。CC3100MODBOOST 评估板包含轻松创建物联网解决方案所需的所有资源 - 安防、快速连接、云支持、公开文档、E2E 支持论坛等。它集成了所有 Wi-Fi
    发表于 03-13 10:41
    发表于 05-05 10:50
    SimpleLink™ Wi-Fi® CC3000 Boosterpack 参考设计
    `描述此 BoosterPack 参考设计采用 TI 易于使用的 CC3000 SimpleLink™ Wi-Fi 解决方案,设计为在与任何微控制器单元 (MCU) LaunchPad 评估套件
    发表于 05-06 14:19
    CC3200 SimpleLink™ Wi-Fi® 和物联网解决方案
    CC3200 SimpleLink™ Wi-Fi® 和物联网解决方案,一款单芯片无线微控制器 (MCU)
    发表于 02-24 10:59
    Wi-Fi网状网络解决方案扩展连接边界
    网状网络还具有如下特点: 通过自愈功能实现无缝连接通过流经的路由流量卸载接入点即使没有接入点仍可建立网络连接易于网络管理的多跳能力 TI的Wi-Fi网状网络解决方案采用我们的WiLink™ 8
    发表于 08-30 14:33
    求首款单芯片低功耗Wi-Fi解决方案
    的 SimpleLink Wi-Fi CC3200 解决方案及首款无线连接 LaunchPad 评估套件启动开发工作。- SimpleLink Wi-Fi
    发表于 06-14 08:16
    Qorvo分布式Wi-Fi网格解决方案
    实现互联世界的创新RF解决方案提供商Qorvo宣布,正使用 802.11ax 产品组合扩大分布式 Wi-Fi 解决方案在住宅中的适用范围。该产品组合可改善 Wi-Fi 覆盖范围,帮助实
    发表于 11-02 07:01
    SimpleLink Wi-Fi CC3000
    SimpleLinkTM CC3000 Wi-Fi 是一款自成一体的无线解决方案,可大幅简化因特网连接的实施过程。SimpleLink Wi-Fi 能够最大限度地降低对主机微控制器 (
    发表于 03-14 15:19 251次下载
    SimpleLink <b class='flag-5'>Wi-Fi</b> <b class='flag-5'>CC</b>3000
    Simplelink Wi-Fi CC3000
    CC3200 是带 Wi-Fi 功能、集成 Cortex-M4 内核的处理器,提供单芯片的 Wi-Fi 解决方案。 为方便用户使用该芯片, TI 公司推出了
    发表于 05-19 11:17 2次下载
    Simplelink Wi-Fi CC3200
    发表于 05-19 11:17 3次下载
    SimpleLink Wi-Fi解决方案
    .CC3100提供了完整的解决方案平台,包括各种工具和软件,应用案例,用户和编程指南,参考设计和E2E支持社区.本文介绍了CC3100主要特性,硬件框图和软件框图,SimpleLink Wi-
    发表于 04-17 01:07 3610次阅读
    SimpleLink <b class='flag-5'>Wi-Fi</b>的<b class='flag-5'>解决方案</b>
    CC3100/CC3200 Simplelink™ Wi-Fi®片上互联网解决方案
    电子发烧友网站提供《CC3100/CC3200 Simplelink™ Wi-Fi®片上互联网解决方案.pdf》资料免费下载
    发表于 11-08 16:15 0次下载
    <b class='flag-5'>CC</b>3100/<b class='flag-5'>CC</b>3200 Simplelink™ <b class='flag-5'>Wi-Fi</b>®片上互联网<b class='flag-5'>解决方案</b>
    采用MCU LaunchPad™硬件的CC3235MODSF Simplelink™ Wi-Fi®和物联网解决方案
    电子发烧友网站提供《采用MCU LaunchPad™硬件的CC3235MODSF Simplelink™ Wi-Fi®和物联网解决方案.pdf》资料免费下载
    发表于 11-25 14:14 0次下载
    采用MCU LaunchPad™硬件的<b class='flag-5'>CC3235</b>MODSF Simplelink™ <b class='flag-5'>Wi-Fi</b>®和物联网<b class='flag-5'>解决方案</b>
    CC3200采用LaunchPad硬件的Simplelink Wi-Fi和物联网解决方案用户指南
    电子发烧友网站提供《CC3200采用LaunchPad硬件的Simplelink Wi-Fi和物联网解决方案用户指南.pdf》资料免费下载
    发表于 12-02 14:18 0次下载
    <b class='flag-5'>CC</b>3200采用LaunchPad硬件的Simplelink <b class='flag-5'>Wi-Fi</b>和物联网<b class='flag-5'>解决方案</b>用户指南
