基于PM8805封装系统级芯片的智能以太网供电解决方案
电子工程师 来源:陈翠 2019-05-11 09:56 次阅读
ST公司的PM8805是封装系统级芯片,用于以太网供电PoE)供电器件(PD),可用功率水平高达99.9W.器件嵌入两个有源桥及其驱动电路与驱动高边MOSFET,热插拔MOSFET和兼容IEEE 802.3bt的电池泵.PM8805能进行物理层分类,提供有成效的PSE认证身份证明标识,可确认出4对PSE,信息由专用的Tx信号矩阵来提供。器件由以太网电缆的电源或由外接电源如墙上适配器。 PM8805集成了100V N沟MOSFET,总通路电阻为0.2Ω,100V 0.1Ω高边热插拔MOSFET,PoE-PD单识别标志接口和IEEE 802.3bt/at/af兼容,支持对PoE应用,支持12V辅助源,智能工作模式,热关断保护,主要用在大功率无线数据系统,安全照相机,接入点,公共信息显示以PoE照明系统。本文介绍了PM8805主要特性,内部框图,应用电路,以及大功率PoE PD/5 V高达20A有源箝位正向评估板STEVAL-POE003V1主要特性别,电路图和材料清单以及PCB设计图与装配图。
The PM8805 is a system-in-package for smartpower supply of Power over Ethernet (PoE)Powered Devices (PD) and it is applicable forpower level up to 99.9 W.
It embeds: two active bridges and their drivingcircuitry, a charge pump to drive the high-sideMOSFETs, the hot swap MOSFET and theinterface compliant with IEEE 802.3bt.
The device performs the physical layerclassification, providing the indication ofsuccessful PSE type identification. A 4-pair PSEis identified and the information is available by adedicated matrix of Tx signals.
The device works with power either from theEthernet cable or from an external power sourcesuch as a wall adapter, with possible prevalenceof the auxiliary source with respect to the PoE.
The PM8805 is suitable to build the interfacesection of PoE switch mode power supplies targeting the highest conversion efficiency. Itprovides a PGD signal that can be used to enablea PWM controller, a DC-DC converter or an LEDdriver.
The PM8805 integrates a dual MOSFET bridge and a PD-PoE single-signature interface,specifically designed to support high power, 4-pair (4P) applications, as being specified in the new IEEE802.3bt standard, but also capable of working with high efficiency, 2P applications.
Typically, after the data transformer a diode bridge is used to set a defined polarity to the input voltage since such polarity on the Ethernet cable may vary.
Considering the maximum power levels defined by the IEEE802.3-2015 standard (25 W fora Type2 PD) the diode bridges power losses may still be acceptable, but with new powerhungry applications like UPOE, with more than 50 W at PD end, the power losses of astandard diode bridge become too high.
The same consideration is valid for standard applications that need to squeeze the maximum available power from the PSE. For example, comparing a diode bridge with Vd= 0.8 V with bridged 100 mΩ Ron MOSFETs, the gain at 0.5 A, 50 V is about 0.75 W out of 25W, i.e. about 3% on overall efficiency.
PM8805主要特性:
 Dual active bridge, hot swap MOSFETandPoE-PD interface in a system-in-package
 100 V N-ch MOSFETs with 0.2 Ω total pathresistance for each active bridge.
 100 V, 0.1 Ω high-side N-ch hot swap MOSFET
 PoE-PD single-signature interface compliantwith IEEE 802.3bt / at / af
 Supports 4-pair PoE applications
 Supports 12 V auxiliary sources
 Identifies which kind of PSE (standard orlegacy) is connected with and provides successful IEEE802.3bt/at/af classificationindication as a combination of the T0, T1 andT2 signals (open drain)
 Smart operational modes
 Programmable classification current with3.3 ms delay.
 Optional Autoclass feature
 Advanced energy-saving MPS timings
 Two-step hot swap current protection: DC with1 ms delay and short-circuit with 10 us delay.
 Controlled pre-charge of the output capacitor
 PGD signal (open drain) to enable an externalPWM controller.
 Thermal shutdown protection
PM8805应用:
 High power wireless data systems
 Security cameras
 Access points
 Public information displays
 PoE lighting systems
图1.PM8805内部框图
图2.采用PM8805输入级的PD简化应用电路图
图3.采用PM8805和DC/DC前CM滤波器的PD简化通用电路图
图4.简化的前辅助连接器电路图
图5.简化的后辅助连接器电路图
图6.PM8805应用案例布局图
This evaluation board implements a PoE Class 8 converter that is compliant with the IEEE802.3bt standard. The PoE interface is based on the PM8805 PoE-PD interface and a DC-DC forward active clamp converter based on the PM8804 controller.
The PM8805 system on package device embeds two active bridges and anIEEE802.3bt compliant Powered Device (PD) interface. It can be used in all mediumto-high power 2P and 4P high efficiency PoE and PoE+ applications.
The PM8804 PWM controller integrates all the circuitry required for a smart andefficient 48 V converter, including a programmable oscillator for the switchingfrequency, adjustable slope compensation, dual complementary low-side drivers withprogrammable dead time, programmable soft start, soft turn off and a programmablecurrent sense blanking time.The device targets high efficiency conversion over a wide load range.
The STEVAL-POE003V1consists of a POE interface compliant with the last standard IEEE802.3bt, created withthe PM8805 interface and a forward active clamp DC-DC converter that receives a DC voltage from POEinterface.
PM8805 device integrates two N-channel MOSFET bridges, one for every 2-pair of the POE interface, and anhotswap MOSFET placed in series with the outputs of two bridges. The following figure shows the efficiency of the single forward converter, and the overall efficiency that alsoincludes the power losses of the POE interface.
评估板STEVAL-POE003V1主要特性:
• Features of PM8805
– System in package integrating a double active bridge, a hot-swap MOSFETand a PoE-PD interface
– PoE-PD single-signature interface compliant with IEEE 802.3bt
– Detection and support of high power 4-pair applications
– 100 V N-Ch MOSFETs with 0.2 Ω total path resistance for each activebridge
– Identifies which kind of PSE (standard or legacy) it is connected to andprovides successful IEEE802.3 af / at / bt classification indication as acombination of the T0, T1 and T2 signals (open drain)
– VFQFPN43 8x8 mm with 6 exposed pads
• Features of PM8804
– PWM peak current mode controller
– Input operating voltage up to 75 V
– Internal high voltage start up regulator with 20 mA capability
– Programmable fixed frequency up to 1 Mhz
– Soft start up with settable time
– Soft turn off (optionally disabled)
– Dual 1Apk, low side complementary gate drivers
– GATE2 optionally turned off for reduced consumption
– 80% maximum duty cycle with internal slope compensation
– VFQFPN 3.0x3.0x1.0 16L 0.5 mm pitch
• WEEE compliant
• RoHS compliant
图7.评估板STEVAL-POE003V1外形图
评估板STEVAL-POE003V1主要指标:
图8.评估板STEVAL-POE003V1 PCB顶层装配图
图9.评估板STEVAL-POE003V1 PCB底层装配图
图10.评估板STEVAL-POE003V1电路图(1)
图11.评估板STEVAL-POE003V1电路图(2)
图12.评估板STEVAL-POE003V1电路图(3)
评估板STEVAL-POE003V1材料清单:
图13.评估板STEVAL-POE003V1 PCB设计图(1):层1顶层
图14.评估板STEVAL-POE003V1 PCB设计图(2):层2
图15.评估板STEVAL-POE003V1 PCB设计图(3):层3
图16.评估板STEVAL-POE003V1 PCB设计图(4):层4
图17.评估板STEVAL-POE003V1 PCB设计图(5):层5
图18.评估板STEVAL-POE003V1 PCB设计图(6):层6
  • 以太网
  • 封装系统
    POE以太网供电浪涌防护
    电网等工业系统,用以实现系统内的数据、视频传输、流量控制、以及通过总线实现供电。但由于工业以太网工作环境的严苛,对于POE端口的浪涌及静电防护必不可少,下面就POE
    发表于 03-02 11:42
    以太网供电 (PoE)/LAN 防护解决方案概述
    PoE 是一项成熟且不断发展的技术,用于便捷地通过以太网电缆向负载传输电力,而不必额外增加电源线。浪拓可提供电缆两端的防护解决方案
    发表于 09-12 13:21
    以太网供电完全自主的四端口供电设备解决方案
    描述完全自主的 IEEE802.3at 2 型 (30W) 以太网供电 (PoE) 4 端口供电设备 (PSE) 解决方案。提供两个非标准高功率端口 (
    发表于 09-05 08:55
    以太网怎么为工业市场供电
    除拓扑结构以外,工厂自动化设备的工作电压为24伏,而电信设备的供电电压为48伏。虽然这两种不同的版本已存在很长时间,但首个工业以太网供电解决方案最近才新鲜出炉,那就是:EtherCAT P。本篇博文
    发表于 08-06 07:37
    以太网供电方案设计
    高效的以太网供电解决方案降低了总体成本
    发表于 08-26 14:12
    【亚信电子】任天堂Switch - 亚信USB以太网芯片解决方案演示视频
    收发器、10/100/1000Mbps千兆以太网MAC与PHY整合在单一芯片中),是一款低价、小封装、高性能、高集成度、即插即用的USB 3.0转千兆以太网
    发表于 06-08 14:41
    如何利用以太网为工业市场供电
    结构。图 1:两种类型的以太网拓扑结构 除拓扑结构以外,工厂自动化设备的工作电压为24伏,而电信设备的供电电压为48伏。虽然这两种不同的版本已存在很长时间,但首个工业以太网供电解决方案
    发表于 11-10 06:13
    关于高效的以太网供电解决方案的应用介绍
    IEEE 802.3at 规范定义的以太网供电 (PoE) 是通过一条 CAT-5 以太网电缆安全地传输应用数据和电源的方法。由于它支持灵活地在任何地方安装设备,没有在附近提供交流电源的限制,也
    发表于 10-06 17:39 1107次阅读
    关于高效的<b class='flag-5'>以太网</b><b class='flag-5'>供电解决方案</b>的应用介绍
    Linux以太网解决方案的介绍
    本课程将回顾高性能以太网解决方案所需的系统功能。 将审查Xilinx以太网IP内核和相关设备驱动程序,包括设备树绑定。 还讨论了与Petalinux的联网。
    的头像 发表于 11-27 06:38 3288次阅读
    基于新一代IEEE 802.3bt以太网供电标准系统解决方案
    ADI公司为基于新的IEEE 802.3bt(PoE++)以太网供电(PoE)标准的系统提供全面的解决方案。本视频重点介绍了Power by Linear针对PD、PSE和网桥实施的
    的头像 发表于 08-05 06:13 4649次阅读
    高效的以太网供电解决方案降低了总体成本
    高效的以太网供电解决方案降低了总体成本
    发表于 03-20 19:50 5次下载
    高效的<b class='flag-5'>以太网</b><b class='flag-5'>供电解决方案</b>降低了总体成本
    以太网供电解决方案
    以太网供电解决方案
    发表于 05-18 13:45 15次下载
    POE以太网供电浪涌保护方案
    POE以太网供电技术的发展势头十分强劲,这一技术可简化用电设备的安装和部署,省去了需要设置独立输电的专用线。现如今,POE以太网供电技术应用十分广泛,在安防、通信以及
    的头像 发表于 05-09 11:08 2152次阅读
    POE<b class='flag-5'>以太网</b><b class='flag-5'>供电</b>浪涌保护<b class='flag-5'>方案</b>
    设计以太网供电(PoE)解决方案
    以太网供电(PoE)供电是一种利用网线来传输功率的供电方案,由供电设备(PSE)、受电设备(PD
    的头像 发表于 08-02 11:20 1577次阅读
    设计<b class='flag-5'>以太网</b><b class='flag-5'>供电</b>(PoE)<b class='flag-5'>解决方案</b>
    MMWAVEPOEEVM以太网供电解决方案用户指南
    电子发烧友网站提供《MMWAVEPOEEVM以太网供电解决方案用户指南.pdf》资料免费下载
    发表于 11-28 14:34 0次下载
    MMWAVEPOEEVM<b class='flag-5'>以太网</b><b class='flag-5'>供电解决方案</b>用户指南
