Computer通信,一方面又要和下位机通信,这时就需要扩展串行通道。本文具体介绍了两种串行通道的扩展方法。 2 串行口的扩展方法常用的标准51单片机内部仅含有一个可编程的全双工串行通信接口,具有UART的全部功能
2015-09-02 14:47:12
在以单片机为核心的多级分布式系统中,常常需要扩展单片机的串行通信口,本文分别介绍了基于SP2538专用串行扩展芯片及INTE18251的两种串行口扩展方法,并给出了实际的硬件电路原理及相应的通信程序段。
2011-03-02 12:13:46
网友们好象没人提过PLD的话题,我感觉是对这个东西不太熟,其实PLD是大有用武之地的,其优势在于:1、可以很灵活的实现各种“与、或、非”逻辑功能;2、任何复杂的逻辑运算都是一步完成,避免产生额外
2012-11-19 20:41:23
PSD834F2A-70JIT - Flash in-system programmable (ISP) peripherals for 8-bit MCUs, 5 V - STMicroelectronics
2022-11-04 17:22:44
PSD834F2A-70JT - Flash in-system programmable (ISP) peripherals for 8-bit MCUs, 5 V - STMicroelectronics
2022-11-04 17:22:44
PSD834F2A-70MIT - Flash in-system programmable (ISP) peripherals for 8-bit MCUs, 5 V - STMicroelectronics
2022-11-04 17:22:44
PSD834F2A-90MT - Flash in-system programmable (ISP) peripherals for 8-bit MCUs, 5 V - STMicroelectronics
2022-11-04 17:22:44
PSD834F2A-90UIT - Flash in-system programmable (ISP) peripherals for 8-bit MCUs, 5 V - STMicroelectronics
2022-11-04 17:22:44
PSD834F2V - Flash PSD, 3.3V Supply, for 8-bit MCUs 2 Mbit 256 Kbit Dual Flash Memories and 64 Kbit SRAM - STMicroelectronics
2022-11-04 17:22:44
PSD834F2V-15 - Flash PSD, 3.3V Supply, for 8-bit MCUs 2 Mbit 256 Kbit Dual Flash Memories and 64 Kbit SRAM - STMicroelectronics
2022-11-04 17:22:44
PSD834F3A-70JIT - Flash in-system programmable (ISP) peripherals for 8-bit MCUs, 5 V - STMicroelectronics
2022-11-04 17:22:44
PSD834F3A-70JT - Flash in-system programmable (ISP) peripherals for 8-bit MCUs, 5 V - STMicroelectronics
2022-11-04 17:22:44
PSD834F3A-70MIT - Flash in-system programmable (ISP) peripherals for 8-bit MCUs, 5 V - STMicroelectronics
2022-11-04 17:22:44
PSD834F3A-70MT - Flash in-system programmable (ISP) peripherals for 8-bit MCUs, 5 V - STMicroelectronics
2022-11-04 17:22:44
PSD834F3A-70UT - Flash in-system programmable (ISP) peripherals for 8-bit MCUs, 5 V - STMicroelectronics
2022-11-04 17:22:44
PSD834F3A-90JT - Flash in-system programmable (ISP) peripherals for 8-bit MCUs, 5 V - STMicroelectronics
2022-11-04 17:22:44
PSD834F3A-90MIT - Flash in-system programmable (ISP) peripherals for 8-bit MCUs, 5 V - STMicroelectronics
2022-11-04 17:22:44
PSD834F3A-90UT - Flash in-system programmable (ISP) peripherals for 8-bit MCUs, 5 V - STMicroelectronics
2022-11-04 17:22:44
PSD834F2 - Flash in-system programmable (ISP) peripherals for 8-bit MCUs, 5 V - STMicroelectronics
2022-11-04 17:22:44
串行通信接口(SCI)内部有一个串行通信(SCI)接口模块,来实现与其它外设之间的串行数据通信。波特率可编程。SCI的发送器与接收器都是双缓冲的。各自有工作使能和中断控制。可工作于全双工模式波特率
2009-09-16 12:44:00
串行通信的通信方式是什么?常见的串行通信接口有哪些?STM32F4异步通信方式特点是什么?
2021-12-03 07:35:13
设备之间通信的方式串行通信的分类常见的串行通信接口UART引脚连接方法STM32的UART特点STM32中UART参数
2021-03-17 07:32:21
的“串行通信总线”即可。2、串口通信基本原理:用少量的“通道”(如导线)将要传送的多个bit数据,在时间轴上“分时”传送过去,用以代替(冯·诺伊曼系统结构)计算机系统中“并行”方式工作总线(一次传送多个
2021-12-24 07:13:21
本应用笔记适用于STM32F2x7微控制器,介绍利用Ethernet通信接口实现在应用编程的实现方案。
2022-12-01 07:21:32
利用异步通信芯片TL16C750实现DSP与PC机的高速串行通[hide][/hide]
2009-06-17 09:49:53
流程图,即可完成正常的数据通信任务。如果需要利用软件来实现dsp与pc的双向复位,则可将图1中的跳线端子jump1的1、2 脚短接,串口的dtr引脚通过上拉电阻接通电源,将jump4的2、3脚短接
2019-06-12 05:00:09
【转自互联网,如需引用请联系原作者】 在工程中,常采用Modem通过模拟线路进行数据的远程传输。我们用工业级PIC16F87系列单片机控制Modem完成串行异步/同步通信,在较低速率的线路上实现了
2018-07-03 09:09:54
在PLC及网络中存在哪几类通信?什么是串行通信方法?
2021-05-27 06:49:12
测温度用符号扩展的16位数字量方式串行输出。一线式(1-WIRE)串行总线是利用1条信号线就可以与总线上若干器件进行通信。具体应用中可以利用微处理器的I/O端口对DS18B20直接进行通信,也可以通过
2020-04-28 07:37:31
,另外,还集成了一个事件管理模块EVM。因此,TMS320F240不仅具有高速数据处理能力,还具有控制和事件管理能力,可完成人机界面、与 上位机进行串行通信等功能。 2 TMS320F240串行通信接口
2019-05-06 09:18:14
过程中,参考图2所示的dsp与pc串行通信流程图,即可完成正常的数据通信任务。如果需要利用软件来实现dsp与pc的双向复位,则可将图1中的跳线端子jump1的1、2脚短接,串口的dtr引脚通过上拉电阻
2012-12-28 10:10:36
我最近在用aduc834进行设计,通过串口进行串行下载程序时遇到了问题。晶体为32,768khz,EA上拉,不论psen状态如何(下拉或者悬空),power on 或者reset之后,pc都会
2018-08-30 11:10:20
实际使用过程中,需要为它提供一个人机接口或上层控制接口,以便于观察控制效果或传递必要的控制信息。因此,实现tms320f240与pc之间串行通信接口的设计方法,具有较高的实用价值。串行通信接口的硬件
2019-06-20 05:00:06
1.串口通信串行接口(Serial Interface) 是指数据一位一位地顺序传送,其特点是通信线路简单,占用芯片引脚资源少,只要一对传输线就可以实现双向通信(可以直接利用电话线作为传输线),从而
2021-11-26 08:14:25
要掌握的。那么,对于新手来讲,串口是什么呢?串口是串行通信接口的简称,即是一种采用串行通信方式的扩展接口,那么什么又是串行通信呢??所谓串行通信就是,在一根数据线上,数据进行一位一位的发送或接收,从...
2022-01-17 06:42:03
基础知识介绍什么是并行通信和串行通信串行通信:串行通信是指利用一条传输线将数据一位位地顺序传送。传输方式:传输一个字节(8个位)的数据时,串口是将8个位排好队,逐个地在1条连接线上传输。特点
2022-01-13 06:09:38
单片机扩展串行通信资料
2012-08-20 11:05:42
在STM32F417中如何如何利用USART和FIFO进行两个外设之间的串行传输
2018-05-13 22:22:15
(assp)主/设备u***控制器可用做视频的phy接口。输出经并行总线可以被送往pld以进行数据处理,为了进一步集成,u*** mac(介质访问控制器)可以被设计到pld中。
并行的视频数据可以经
2018-12-28 07:00:06
基于TMS320C6000的串行通信扩展方法 from hellodsp
2011-09-08 21:03:50
本文利用32位DSP-TMS320F2812自身的增强型SPI接口,结合性价比高的串行接口Flash,高效地实现了对系统存储容量的扩展。
2021-04-27 06:22:15
可编程逻辑器件(PLD)的两种主要类型是现场可编程门阵列(FPGA)和复杂可编程逻辑器件(CPLD)。根据半导体行业协会提供的数据,PLD现在是半导体行业中增长最快的领域之一,高性能PLD现在已经从
2019-09-24 06:58:39
异步串行通信(UART)是一种广泛应用的串行数据传输协议,UART的要求是传输线少,可靠性高而且传输距离远。UART功能负责从总线采集数据,转换成传输格式,然后发送到串口。也负责从串口接收数据,检查和删除附加的位,并传送结果数据给总线。
2019-10-11 07:06:29
M25P80最常用的指令操作如何利用M25P80实现基于FPGA的串行Flash扩展?
2021-04-29 06:41:00
如何利用STM32中断模式实现点灯和串口通信?
2022-01-20 07:40:01
如何利用stm32cubemx实现串行flash模拟u盘?
2021-12-15 06:34:17
PSD作为一种精密的光电位置传感器,具有灵敏度高、响应时间短、位置分辨率高、光谱响应范围大等特点,因此被广泛应用于现代光电检测技术中,尤其是高精度、高速度的数据采集技术中。如何在极短的响应
2021-03-09 07:38:28
如何去实现FPGA中的各个模块?如何去实现FPGA与PC的串行通信?
2021-05-26 07:25:13
进行通信,如GPRSMODEM、红外发送和接收模块、RS485总线接口等。这使得开发人员常常面临嵌入式系统中主机串行通信接口不足的问题。扩展串行口就十分有必要了。
2019-10-29 07:08:01
用串行口扩展并行输出口一、实验目的二、实验内容三、实验步骤四、C代码如下五、实验结果六、实验体会一、实验目的掌握AT89C52串行口方式0的工作方式和编程掌握利用串行口和移位寄存器扩展并行接口的方法
2021-12-06 06:20:21
用的资源很少。顾名思义,该总线协议使用一根线与主控制器通信,通常是微处理器。该参考设计实现了PLD中的单线控制器。初始化过程和所有数据传输都在PLD中实现,以卸载微处理器的任务。微处理器的任务简化为通过
2020-04-30 09:36:09
串行通信发送器是什么工作原理?怎么用VHDL语言在CPLD上实现串行通信?
2021-04-13 06:26:46
、红外串行通信,符合IrDA1.x标准,利用950 nm近红外波段的红外线作为传递信息的载体,通过红外光在空中的传播来传递信息,由红外发射器和接收器实现。其最大优点是:不易被人发现和截获,保密性强
2011-10-18 14:22:04
程序中利用利用串行口扩展并行口检测按键,使用到了串行中断,串行通信的结果从LED灯中显示,程序编译连接都没有问题,求高手帮忙看一下哪不对
2013-02-17 17:11:08
EVAL-ADuC834QSZ,用于ADuC834微转换器MCU的ADuC8xx评估套件。 ADuC8x系列(8052内核)精密模拟微控制器的快速入门套件具有串行端口下载/调试功能和汇编源调试环境
2019-06-11 09:43:18
系统编程(ISP)。除此之外,PSD4235G2还有以3000门通用CPLD实现的 时序逻辑。该CPLD有82个输入和24个输出,可提供足够的片上可编程逻辑去实现诸如移位寄位器、信箱和串行通道的外部功能
2019-06-27 07:38:07
SCI 是全双工异步串行通信接口,主要用于 MCU 与其他计算机或设备之间的通信,几个独立的 MCU也能通过 SCI 实现串行通信,形成网络。 MC9S12XS128里有两个SCI(SCI0
2021-12-07 12:48:01
总线可以被送往PLD以进行数据处理,为了进一步集成,USB MAC(介质访问控制器)可以被设计到PLD中。 并行的视频数据可以经复用器被送至最终的视频解码器播放。USB 2.0 PHY芯片可被轻松连接
2019-05-14 07:00:12
,我国也迫切需要发展自己的IP核。本文针对I2C的主方式串行扩展通信的特点,详细给出设计过程和结果。1 IP核简介 IP核是指:将一些在数字电路中常用但比较复杂的功能块,如FIR滤波器、SDRAM
2019-04-12 07:00:09
PSD3XX页面寄存器的使用和利用PSD3XX页面寄存器进行软件设计时的相关技术
2009-05-13 11:10:14
9 利用PSD8XXF的特性实现现场可编程门阵列的配置
2009-05-13 13:45:08
17 PSD3XX页面寄存器的使用和利用PSD3XX页面寄存器进行软件设计时的相关技术
2009-05-15 14:22:38
21 本文对FX系列PLC的通信协议进行了详细的介绍,并以VB为开发工具实现了PC机与FX系列PLC的串行通信。关键词: PLC ;串行通信;VB6.0
2009-05-30 08:28:07
26 本文介绍了一种在Arm 9 处理器和Linux 操作系统的嵌入式组合中实现数据终端设备与无线通信模块之间的串行通信链路复用功能的新的方法。这种方法利用Linux 伪终端功能,在
2009-06-09 10:07:23
15 在以单片机为核心的多级分布式系统中,常常需要扩展单片机的串行通信口,本文分别介绍了基于SP2538 专用串行口扩展芯片及Intel8251 的两种串行口扩展方法,并给出了实际的硬件电
2009-06-15 09:53:11
33 介绍了西门子S7–200 系列 PLC 的自由口通信模式及在Windows 环境下应用VC++6.0 实现PC 机与PLC串行通信的编程方法,开发了玻璃器皿冲压机上位机监控系统。实际运行证明,该监控
2009-08-07 10:21:37
143 介绍了西门子S7–200 系列 PLC 的自由口通信模式及在Windows 环境下应用VC++6.0 实现PC 机与PLC串行通信的编程方法,开发了玻璃器皿冲压机上位机监控系统。实际运行证明,该监控系统
2009-09-01 08:38:34
44 摘要:本文介绍一种用纯软件来扩展89C51单片机串行口的方法,详细说明了通过扫描发送、中断接收实现模拟串行通信的编程技巧。关键词:串行口;通信;89C51;单片机;扩展
2010-07-15 12:25:00
33 摘 要:本文主要介绍了基于FPGA技术实现与PC串行通信的过程,给出了各个模块的具体实现方法,分析了实现结果,验证了串行通信的正确性。引言串行通信即
2006-03-24 13:31:51
4660
摘 要: 串行通信是实现远程测控的重要手段。采用VHDL语言在CPLD上实现了串行通信,完全可以脱离单片机使用。
关键词:
2009-06-20 12:43:50
570
串行同步通信的应用
该文给出利用8251A实现串行同步通讯设计的方法
关键词:
2009-10-17 11:24:07
1986
基于FPGA的串行Flash扩展实现
FPGA凭借其方便灵活、可重复编程等优点而日益被广泛应用;闪速存储器(Flash Memory)以其集成度高、成本低、使用方便等优点,在众多领域中
2010-01-12 10:39:55
1363
利用串行RapidIO实现FPGA协处理
为了支持“三重播放”应用,人们对高速通信和超快速计算的需求日益增大,这向系统开发师、算法开发师和硬件工程师等人员提出了新
2010-02-25 17:06:55
1216
2010-03-25 14:48:25
1389
该模块利用了PlC16F877的异步串行通信端口,实现与PC机的串行通信。
2011-06-23 11:21:54
913
论述了在 Windows CE 嵌入式系统中,利用串口实现GPS 和 PDA 通信的方法;简要介绍了Windows CE串行通信基础知识以及PDA 与GPS 接收机的串行连接方法;详细说明在eVC4.0 环境下开发串口通信程
2011-06-27 15:51:45
32 介绍了基于DELPHI 环境的多种串行通信编程方法及编程技术,着重讨论了采用MSComm 控件实现串行通信的基本方法、技巧,并探讨了微机与多单片机系统间实时远程通信的编程实现。
2011-09-09 15:48:51
55 本文介绍了利用MATLAB仪器实现MCU串行通信的方法:
2012-02-20 16:41:49
55 本文介绍一种利用单片机ADμC834实现的频率智能化测量方法,所需外围元件少、扩展性强、测试准确。
2012-03-22 14:36:21
1600
当C5D 单片机不具备片上硬件.E0/4 或.E0/4 不够用时,可以利用软件模拟实现异步串行通信。论述了异步串行通信的基本概念,根据中断驱动的软件模拟异步串行通信的要求,设计了C5D 单片
2012-04-11 14:29:06
76 串行通讯是测试仪器必备的工业口,为了能更好的利用测试仪器的扩展功能,通过使用Delphi的第三方串行通讯组件,来实现PC机软件与测试仪器的串行通讯,进而对测试仪器的扩展功能
2012-07-06 15:13:40
47 为了正确反映基于光电位置敏感器(PSD)的微位移传感器的特性,首先介绍了一维光电位置敏感器的工作原理并分析了利用PSD结合光学三角测量法将位移信号转换成电压信号的工作原理,
2012-07-11 14:24:09
0 本文论述了在 Windows CE 嵌入式系统中, 利用串口实现 GPS 和 PDA 通信的方法; 简要介绍了 Windows CE串行通信基础知识以及 PDA 与 GPS 接收机的串行连接方法
2016-04-18 10:13:45
5 为了实现基于Windows CE.NET的嵌入式单板机与单片机间通信设计了单板机SBC84500VEA与8051C单片机RS232 通信的硬件连接 定制了支持串行通信的Windows CE平台编制了Windows CE下和单片机下串行通信的软件实现了SBC84500VEA与8051C单片机的RS232通信。
2016-04-18 11:28:14
5 单片机扩展串行通信资料,很好的设计资料,快来下载学习吧。
2016-05-09 17:35:56
26 介绍一种利用cPLD实现高速异步串行通信的方法,主要适用于必须使用高速异步串行通信,而对误码率要求又不是很高的应用环境,如基于Rs485协议的共线语音通信系统。对实现方法进行详细的说明,并指出该方法
2017-11-10 14:21:43
4 随着数字信号处理器(DSP)在系统控制领域中的广泛应用,控制各系统的DSP 之间 通信问题也越来越突出。利用DSP 本身的高速同步串行接口(SPI)模块,可以让DSP 直 接对接实现芯片间的同步串行
2019-02-06 08:56:00
6115
嵌入式系统在日常生活中的大量使用,人们也对其性能和速度提出了更高的要求。微控制器和可编程逻辑器件的结合,更能充分发挥嵌入式系统的优势。本文设计和实现的微控制器与可编程逻辑器件之间总线读写方式通信比传统的串行通信更可靠、速度更快。下面是一些相关术语的说明。
2018-10-02 01:06:10
1490
由于CPLD数字设计结构化的趋势,将出现针对CPLD不同层次的IP(Intellectual Property)核。各个IP核可重复利用,可大大提高设计能力和效率。国外各大公司都推出了专门的IP核,我国也迫切需要发展自己的IP核。本文针对I2C的主方式串行扩展通信的特点,详细给出设计过程和结果。
2020-04-07 09:54:10
3000
口( 0、uart1),所以必须进行串行口扩展。一种简单的扩展方法是利用 I/O端口控制多路转换器(如CD4052)进行串行口扩展(图3),实现了一点对多点分时串行口通信。根据微控制器μPSD
2020-04-06 11:16:00
496
本系统是利用8031单片机串行,实现双机口通信。其中1号发送机8031串行接发送号线P3.1(TXD)连到2号接收机机8031串行口接收信号线P3.0(RXD)上。而5G14433则是连在发送机那边的8031芯片上。通过调节W1来改变电压值,发送跟接收放的LED则跟踪显示电压值。
2023-10-19 15:56:15
1
正在加载...
