本例用STM32单片机普通IO口模拟SPI的方式来读取高通字库GT20L16S1Y。
本款芯片适合最基本的16点阵字库、16x16汉字库、一级字库、单片机字库应用,支持gb2312点阵和基本的ASCII编码的字符集,采用SPI协议的接口来读取芯片内的数据。封装为SOT23-6,体积较小,适合任意大小的设备。
本例中使用的单片机型号是STM32F103VDT6,字库使用的引脚是PA口的4,5,6,7脚。
首先我们对这个单片机的系统时钟进行设置。进行系统时钟设置后才能开启端口的时钟。具体如下例所示。
void SystemInit (void)
RCC->CR |= (uint32_t)0x00000001;
RCC->CFGR &= (uint32_t)0xF0FF0000;
RCC->CR &= (uint32_t)0xFEF6FFFF;
RCC->CR &= (uint32_t)0xFFFBFFFF;
RCC->CFGR &= (uint32_t)0xFF80FFFF;
RCC->CIR = 0x009F0000;
RCC->CFGR2 = 0x00000000;
SystemInit_ExtMemCtl();
SetSysClock();
SCB->VTOR = FLASH_BASE | VECT_TAB_OFFSET;
设置好时钟后开始初始化STM32的IO口,如下例所示
#define CLK_H GPIO_SetBits(GPIOA,GPIO_Pin_5)
#define CLK_L GPIO_ResetBits(GPIOA,GPIO_Pin_5)
#define SO_H GPIO_SetBits(GPIOA,GPIO_Pin_7)
#define SO_L GPIO_ResetBits(GPIOA,GPIO_Pin_7)
#define CS_H GPIO_SetBits(GPIOA,GPIO_Pin_4)
#define CS_L GPIO_ResetBits(GPIOA,GPIO_Pin_4)
#define SI GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_6)
void GenitopZkInit(void)
GPIO_InitTypeDef GPIO_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_7;
GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;
GPIO_Init(GPIOA,&GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_6;
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IN_FLOATING;
好了,下面开始用IO口模拟SPI来读写字库
发送0X03及计算出来的字库地址
void GenitopZk_Address(unsigned char AddH,unsigned char AddM,unsigned char AddL)
Send_Byte(0x03);
Send_Byte(AddH);
Send_Byte(AddM);
Send_Byte(AddL);
从字库指定的地址address读出一个字节的数据出来
unsigned char ZkReadOneByte(unsigned long int address)
unsigned char dat=0x00,AddH,AddM,AddL;
CS_L;
AddH=address>>16;
AddM=address>>8;
AddL=address;
GenitopZk_Address (AddH,AddM,AddL);
dat=ReadByte();
CS_H;
return dat;
从字库指定的地址读出N个字节的数据
Void ZkReadNByte(unsigned long int address,unsigned char byte_long,unsigned char *p_arr)
unsigned char AddH,AddM,AddL;
unsigned int j;
CS_L;
AddH=address>>16;
AddM=address>>8;
AddL=address;
for(j=0;j { p_arr[j]=ReadByte(); } CS_H; } 该函数向字库发送数据 void Send_Byte(unsigned char out) { unsigned char i=0; for(i=0;i<8;i++) { CLK_L; if(((out< SO_L; else SO_H; CLK_H; } } 该函数从字库接收数据 u8 ReadByte(void) { u8 i; u8 dat; CLK_H; for(i=0;i<8;i++) { CLK_L; dat=dat<<1; if(SI) dat=dat|0x01; else dat&=0xfe; CLK_H ; } return dat; } 读取汉字并显示的函数,参数M是指汉字机内码的高字节,L是指汉字机内码的低字节。 void Display_GTHZ16(unsigned char M,unsigned char L) { unsigned char i,j; unsigned long BaseAdd; unsigned char MSB,LSB; unsigned long Address; unsigned char hzbuf[32]; unsigned char addr[4]; MSB=M; LSB=L; BaseAdd=0x00;//以下公式参见GT20L16S1Y规格书的第17页。 if(MSB==0xA9 && LSB>=0xa1) Address=(282+(LSB-0XA1))*32+BaseAdd; else if(MSB >=0xA1 && MSB <= 0xA3 && LSB >=0xA1) Address= ((MSB - 0xA1) * 94 + (LSB - 0xA1))*32+BaseAdd; else if(MSB >=0xB0 && MSB <= 0xF7 && LSB >=0xA1) Address = ((MSB - 0xB0) * 94 + (LSB - 0xA1)+ 1038)*32+ BaseAdd; ZkReadNByte (Address,hzbuf,32); for(i=0;i<16;i++) //以下是显示部分,用的是128X64的STN屏。 { LcdWriteCmd(0XB0+y); LcdWriteCmd(0X10|(x+i+4)>>4); LcdWriteCmd(0X0F&(x+i+4)); LcdWriteData(hzbuf[i]); } for(j=0;j<16;j++) { LcdWriteCmd(0XB0+y+1); LcdWriteCmd(0X10|(x+j+4)>>4); LcdWriteCmd(0X0F&(x+j+4)); LcdWriteData(hzbuf[j+16]); } x=x+16; } 读取ASCII编码并显示的函数 void Display_GTAscii16(unsigned char AsciiCode) { unsigned char i,j; unsigned long BaseAdd; unsigned long Address; unsigned char asciibuf[16]; unsigned char addr[4]; BaseAdd=0x3B7C0; //以下公式参见GT20L16S1Y规格书的第18页。 if(AsciiCode>=20 && AsciiCode <= 0x7E) Address=(AsciiCode-0x20) *16+BaseAdd; ZkReadNByte (Address,asciibuf,16); for(i=0;i<8;i++) { LcdWriteCmd(0XB0+y); LcdWriteCmd(0X10|(x+i+4)>>4); LcdWriteCmd(0X0F&(x+i+4)); LcdWriteData(asciibuf[i]); } for(j=0;j<8;j++) { LcdWriteCmd(0XB0+y+1); LcdWriteCmd(0X10|(x+j+4)>>4); LcdWriteCmd(0X0F&(x+j+4)); LcdWriteData(asciibuf[j+8]); } x=x+8; } 在main函数内的实现方法 Void main() { SystemInit(); GenitopZkInit(); Unsigned char *text=”高通科技ABC”; While(*text!=”\0”) { If(*text>0x80){ Display_GTHZ16(*text,*(text++)); //显示汉字 } else { Display_GTAscii16(*text); //显示英文Ascii编码 } Text++; } While(1); } 公司介绍: 深圳高通半导体有限公司成立于2014年11月,其技术及团队传承上海高通半导体有限公司。迄今已来始终致力于中文信息处理技术,坚持发展中文信息民族产业的道路,秉持着用科技传承文化的理念,从1992年DOS时代的汉卡类产品至如今的汉字库芯片产品,持续为行业提供专业的中文信息产品。 高通公司为国家高新技术企业,软件企业,累积知识产权百余项,专注于中文信息处理集成电路产品,简称字库芯片。其开发产品包含点阵字库芯片、矢量字库芯片、GUI字库芯片、智能字库芯片等,为用户提供各类电子产品中的文字解决方案,使产品在中文信息处理方面的开发更加便捷,效果与品质极大提升。 逾6000 个客户案例积累,所涵盖领域包括智能穿戴、智能家居、物联网设备、金融设备、智能表、教育、医疗、商用机器等等深圳高通在成本、专业、便捷、标准、品质方面追求极致。在字库产业发展方面取得了骄人的业绩,在行业内的影响力亦日趋提升,整合国内外字库资源,形成全球领先的文字处理信息产业生态链。 我们深信:汉字作为中华文明的核心之一,有着极其重要的地位。随着世界不断数字化,随着中国不断全球化,中文信息将作为现在与未来的沟通技术,拥有者务必宽广的可能性。无论科技如何发展,我们将致力于发展中文信息产业,秉承用科技传承文化的理念,创造文明智能!
查看更多
