CAT-P592-R472A PIDG 环形端子
数据:
请查看产品文档或联系我们以了解最新的机构审批信息。
产品类型特性
  • 环形和叉形螺钉尺寸  0,
  • 环形和叉形压线筒类型  闭式压线筒
  • Sealable 
  • Insulated  Yes
  • 环形和叉形导线/电缆类型  常规导线, 铜
  • 支持种类  绝缘支撑, 绝缘限制, 非绝缘支撑, 非绝缘支撑
  • 形状描述  RING-041, RING-042, RING-043, RING-046, RING-059, RING-080, RING-092, 圆形/椭圆形
  • 端子特性  修剪
结构特性
  • 孔数  1
  • 端子角度  90°, 直式
电气特征
  • 电压(最大值) (V) 300, 600
主体特性
  • 环形和叉形电镀材料  铜, 锡, 锡铅
  • 条纹颜色  白色, 红色, 绿色, 蓝色, 褐色, 黄色, 黑色
  • 单件重量 (g) .078, .155, .222, .23, .237, .249, .265, .282, .286, .287, .288, .289, .301, .302, .317, .322, .362, .406, .411, .45, .451, .468, .486, .499, .53, .532, .539, .581, .588, .6, .611, .622, .625, .637, .65, .658, .66, .662, .676, .7, .703, .705, .715, .722, .739, .747, .767, .769, .775, .781, .782, .787, .789, .796, .805, .806, .818, .821, .826, .828, .83, .839, .84, .842, .843, .846, .847, .85, .851, .852, .856, .869, .87, .872, .876, .877, .881, .894, .904, .917, .919, .938, .939, .945, .95, .956, .964, .967, .985, .986, .99, .996, 1, 1.007, 1.013, 1.014, 1.016, 1.021, 1.026, 1.028, 1.031, 1.039, 1.048, 1.051, 1.075, 1.081, 1.085, 1.087, 1.091, 1.102, 1.114, 1.122, 1.123, 1.156, 1.159, 1.172, 1.213, 1.215, 1.217, 1.228, 1.23, 1.234, 1.235, 1.241, 1.244, 1.25, 1.256, 1.278, 1.305, 1.323, 1.363, 1.376, 1.379, 1.391, 1.392, 1.404, 1.408, 1.413, 1.448, 1.458, 1.459, 1.476, 1.48, 1.485, 1.49, 1.495, 1.503, 1.522, 1.542, 1.545, 1.653, 1.658, 1.702, 1.871, 1.883, 1.919, 1.924, 10, 10.282, 12.088, 2.002, 2.004, 2.118, 2.131, 2.151, 2.192, 2.236, 2.24, 2.247, 2.251, 2.27, 2.284, 2.294, 2.306, 2.314, 2.321, 2.338, 2.358, 2.369, 2.386, 2.393, 2.426, 2.427, 2.429, 2.438, 2.441, 2.442, 2.504, 2.53, 2.544, 2.563, 2.57, 2.571, 2.588, 2.6, 2.601, 2.656, 2.659, 2.691, 2.707, 2.742, 2.752, 2.789, 2.795, 2.819, 2.826, 2.827, 2.838, 2.869, 3, 3.018, 3.028, 3.087, 3.15, 3.166, 3.172, 3.186, 3.244, 3.249, 3.266, 3.345, 3.415, 3.472, 3.485, 3.558, 3.648, 3.741, 3.75, 3.797, 3.95, 3.98, 4.32, 4.462, 4.514, 4.889, 4.947, 5.307, 5.547, 5.962, 7.09, 9.972
  • 绝缘套管颜色  土黄色, 红色, 蓝色, 黄色, 黑色
  • 检查插槽  否, 是
接触件特性
  • 端子基材  铜 (Cu)
  • 端子和接头类型  Hook Tongue, Ring Tongue, 多个螺钉
  • 环形和叉形端子方向  偏移, 直式
  • 军用部件级别  I 级, II 级
机械附件
  • 带导线绝缘  带有
尺寸
  • Wire Size (AWG) 10, 12, 12 – 10, 14, 16, 16 – 14, 18, 20, 22, 22 – 16, 24, 24 – 20, 26, 26 – 22, 26 – 24
  • Wire Size (mm²) .1 – .4, .1 – .41, .12 – .15, .12 – .24, .12 – .32, .12 – .4, .129 – .326, .2 – .24, .2 – .517, .2 – .518, .205 – .4, .205 – .518, .25 – 1.6, .26 – 1.42, .26 – 1.65, .3 – .4, .3 – 1.3, .3 – 1.42, .3 – 1.65, .326 – 1.31, .5 – .6, .6, .8 – .9, .9 – .96, 1.04 – 2, 1.04 – 2.62, 1.04 – 2.64, 1.25 – 1.4, 1.25 – 2, 1.3 – 2, 1.31 – 2.08, 2 – 2.15, 2.26 – 6.64, 2.62 – 6.64, 2.7 – 6.6, 3 – 6, 3.3 – 5.3, 3.31, 3.31 – 5.26, 5 – 6
  • 线径 (CMA) 202 – 509, 202 – 810, 238 – 475, 304, 320 – 1290, 475, 509 – 3260, 754, 1186, 1900, 2050 – 5180, 2800, 4234, 5180 – 13100, 6654, 12066
  • 螺钉直径 (mm) 2.18, 2.36, 2.84, 3.02, 3.023, 3.25, 3.51, 3.68, 4.17, 4.34, 4.82, 4.83, 5, 5.003, 5.0038, 5.2, 5.25, 5.26, 5.66, 6.3, 6.35, 6.73, 7.92, 8.3, 8.33, 9.53, 9.906, 9.91, 12.7, 13.02, 13.08, 16.66, 19.05
  • 螺钉直径 (in) .086, .093, .112, .119, .128, .138, .145, .164, .171, .19, .191, .197, .2047, .205, .207, .223, .248, .25, .264489, .265, .312, .327, .328, .375, .39, .5, .515, .656, .75
  • 舌厚 (mm) .46, .5, .68, .686, .74, .77, .78, .787, .79, .84, .99, 1, 1.016, 1.02, 1.07, 1.22, 1.27
  • 舌厚 (in) .018, .0197, .027, .029, .03, .0305, .031, .033, .039, .0393, .04, .042, .048, .05
  • 环形和叉形总长 (mm) 1.3, 13.33, 13.36, 14.96, 15.6, 15.67, 16.41, 16.97, 16.99, 17.07, 17.4, 17.86, 17.9, 18.6, 18.64, 18.7, 18.77, 18.8, 18.9, 18.92, 19.4, 19.43, 19.86, 20.1, 20.24, 20.65, 20.67, 20.7, 20.85, 21.2, 21.44, 21.62, 21.8, 21.82, 21.92, 21.94, 22.25, 23, 23.01, 24.2, 24.21, 24.31, 26.19, 26.54, 26.57, 26.6, 26.72, 27.38, 27.4, 27.5, 27.51, 27.68, 28.39, 28.83, 28.96, 29, 29.16, 29.2, 29.59, 29.74, 29.77, 30.18, 30.2, 30.94, 32.5, 32.51, 32.84, 32.9, 32.92, 33.58, 33.6, 33.83, 34.4, 35.18, 35.36, 35.58, 35.9, 35.91, 35.92, 35.96, 35.97, 36, 36.4, 37.74, 37.85, 38.35, 38.38, 40.48, 40.49, 55.36, 56.36, 56.4, 58.62
  • 环形和叉形总长 (in) .051, .525, .526, .589, .615, .617, .646, .668, .669, .67, .672, .685, .703, .731, .734, .736, .739, .74, .744, .745, .765, .782, .792, .797, .8, .813, .814, .821, .833, .84, .844, .851, .859, .86, .863, .864, .876, .906, .91, .95, .953, .957, 1.03, 1.045, 1.046, 1.05, 1.052, 1.076, 1.078, 1.08, 1.083, 1.09, 1.12, 1.14, 1.148, 1.151, 1.165, 1.17, 1.171, 1.188, 1.19, 1.218, 1.28, 1.292, 1.293, 1.296, 1.3, 1.32, 1.322, 1.33, 1.355, 1.39, 1.392, 1.41, 1.414, 1.42, 1.432, 1.486, 1.49, 1.51, 1.59, 1.594, 2.18, 2.219, 2.22, 2.31
  • 环形和叉形电线绝缘直径(最大值) (mm) 1.4, 2.03, 2.08, 2.54, 2.67, 2.79, 3.18, 3.3, 3.56, 3.81, 4.32, 5.08, 5.59, 5.84, 6.35, 6.4, 7.62
  • 环形和叉形电线绝缘直径(最大值) (in) .055, .08, .082, .1, .105, .11, .125, .13, .14, .15, .17, .2, .22, .23, .25, .252, .3
  • 环形和叉形电线绝缘直径 (mm) .66 – 1.4, .79 – 1.4, .81 – 2.08, .97 – 2.79, 1.02 – 2.54, 1.17 – 2.79, 1.27 – 2.03, 1.27 – 2.08, 1.27 – 2.67, 1.42 – 2.79, 1.6 – 3.3, 1.98 – 3.3, 2.03 – 3.18, 2.03 – 3.81, 2.41 – 5.08, 2.67 – 3.56, 2.67 – 3.81, 2.68 – 3.81, 2.92 – 4.31, 3.02 – 5.08, 3.8 – 6.4, 3.81 – 5.59, 3.81 – 5.84, 3.81 – 6.35, 4.32 – 7.62
  • 环形和叉形电线绝缘直径 (in) .026 – .055, .031 – .055, .032 – .082, .038 – .11, .04 – .1, .046 – .11, .05 – .08, .05 – .082, .05 – .105, .056 – .11, .063 – .13, .078 – .13, .08 – .125, .08 – .15, .095 – .2, .105 – .14, .105 – .15, .106 – .15, .115 – .17, .119 – .2, .15 – .22, .15 – .23, .15 – .25, .15 – .252, .17 – .3
使用环境
  • 工作温度范围 (°C) -40 – 105, 105, 150, 170, 288
  • 工作温度范围 (°F) -40 – 221, 221, 302, 338, 550
  • 绝缘要求  部分绝缘
操作/应用
  • 重载  否, 是
行业标准
  • 符合政府资质  否, 是
包装特性
  • 环形和叉形包装方式  包装, 卷, 卷带包装, 带上安装, 盒, 盒和纸箱, 零散零件
  • 封装数量  1, 100, 1000, 1500, 15000, 2000, 2500, 3500, 4000, 50, 500, 5000, 50000
其他
  • 注释  仅在绝缘中提供超大尺寸的膨胀。, 在胶带上提供,适用于自动端接。, 必须使用 22-18 或 22-16 PIDG(红色)工具压接。, 标记:商用 22-16- 军用 22-18,符合 MIL-T-7928.。, 比标准
参考编号
  • TE 内部编号 CAT-P592-R472A
技术文档
数据手册(1) 相关资料(2)
元器件购买 CAT-P592-R472A 相关库存
