OPT9221 OPT9221 飞行时间控制器
数据:
The time-of-flight controller (TFC) is a high-performance, 3D time-of-flight (ToF) sensor companion device that computes the depth data from the digitized sensor data. Depth data are output via a programmable complementary metal-oxide-semiconductor (CMOS) parallel interface.
In addition to depth data, the TFC provides auxiliary information consisting of amplitude, ambient, and flags for each pixel. This information can be used to implement filters and masks and to dynamically control the system configuration for the intended performance.
The TFC supports a wide range of binning and ROI options that help optimize the data throughput that must be handled.
The 9-mm × 9-mm NFBGA package enables small form-factor, 3D, ToF systems that can be embedded into a variety of end equipment.
特性
  • QVGA 3D ToF控制器:最高120 FPS
  • 深度数据:
    • 12位相位
    • 最高12位幅度
    • 最高4位环境
    • 饱和度检测
  • 芯片组接口:
    • 与TI ToF传感器兼容(OPT8241)
  • 输出(CMOS,8通道数据,8个控制信号,
    和时钟):
    • 数字视频协议(DVP) - 兼容:
      • 数据,VD,HD,时钟
    • 同步串行接口(SSI) )-Compatible
  • 深度引擎:
    • 像素分档
    • 感兴趣区域(ROI)
    • De -Aliasing
    • 非线性校正
    • 温度补偿
    • 高动态范围操作
    • 空间滤波器
  • 计时协调员:
    • 传感器控制
    • 主站和从站同步操作
  • I 2 C从站接口
  • 电源:1.2 V内核,1.8-VI /O,3.3-VI /O
    2.5 V模拟
  • Packag e:256针,9毫米×9毫米NFBGA
  • 工作温度:0°C至85°C
参数 与其它产品相比 飞行时间(ToF)传感器
Device Type
Sensor Resolution
Output Format
Interface
Frame Rate (Max) (FPS)
Pixel Pitch (um)
Operating Temperature Range (C)
Pin/Package
OPT9221 OPT3101 OPT8241 OPT8320
ToF Controller     AFE     Sensor + AFE     System-on-Chip (SoC)
NA       320 x 240     80 x 60
Depth Data     Digital     Raw Correlation Data     Depth Data
DVP Compatible
SSI Compatible
I2C     LVDS     CMOS Parallel Interface, DVP, SSI
120     4000     150     1000
    15     30
0 to 70     -40 to 85     0 to 70     0 to 70
256NFBGA     28VQFN     78COG     56COG
方框图 (1)
技术文档
数据手册(1)
元器件购买 OPT9221 相关库存
相关阅读
