SN74LV4052A 双路 4 通道模拟多路复用器/多路解复用器
数据:
SN74LV4052A器件是双通道,4通道CMOS模拟多路复用器和多路分解器,设计用于2 V至5.5 VV CC operation。
SN74LV4052A器件可处理模拟和数字信号。每个通道允许幅度高达5.5 V(峰值)的信号在任一方向传输。
特性
  • 2-V to 5.5-V VCC Operation
  • Fast Switching
  • High On-Off Output-Voltage Ratio
  • Low Crosstalk Between Switches
  • Extremely Low Input Current
  • Latch-Up Performance Exceeds 100 mA Per JESD 78, Class II
  • ESD Protection Exceeds JESD 22:
    • 2000-V Human-Body Model (A114-A)
    • 1000-V Charged-Device Model (C101)
参数 与其它产品相比 模拟开关/多路复用器
Configuration
Number of Channels (#)
Power Supply Type
Vss (Min) (V)
Vss (Max) (V)
Vdd (Min) (V)
Vdd (Max) (V)
Ron (Typ) (Ohms)
Bandwidth (MHz)
Rating
Operating Temperature Range (C)
Package Size: mm2:W x L (PKG)
Package Group
Supply Range (Max)
Ron (Max) (Ohms)
Input/Output Continuous Current (Max) (mA)
Supply Current (Max) (uA)
Features
OFF-state leakage current (Max) (µA)
ON-state leakage current (Max) (µA)
Input/Output ON-state Capacitance (Typ) (pF)
Input/Output OFF-state Capacitance (Typ) (pF)
ESD Charged Device Model (kV)
ESD HBM (kV)
VIL (Max) (V)
VIH (Min) (V)
SN74LV4052A SN74LV4052A-EP SN74LV4052A-Q1
4:1       4:1
2       2
Single       Single
N/A       N/A
N/A       N/A
2       2
5.5       5.5
25     25     100
50       50
Catalog     HiRel Enhanced Product     Automotive
-40 to 85     -40 to 105     -40 to 105
-40 to 125
See datasheet (PDIP)
16SO: 80 mm2: 7.8 x 10.2(SO)
16SOIC: 59 mm2: 6 x 9.9(SOIC)
16SSOP: 48 mm2: 7.8 x 6.2(SSOP)
16TSSOP: 32 mm2: 6.4 x 5(TSSOP)
16TVSOP: 23 mm2: 6.4 x 3.6(TVSOP)
16VQFN: 14 mm2: 3.5 x 4(VQFN)
16TSSOP: 32 mm2: 6.4 x 5(TSSOP)     16SOIC: 59 mm2: 6 x 9.9(SOIC)
PDIP
SO
SOIC
SSOP
TSSOP
TVSOP
VQFN
TSSOP     SOIC
TSSOP
5.5       5.5
225     75     225
25       25
40       20
  Low Power
Low Crosstalk
1       2
1       2
5.6       5.6
5.6
2       0.5
4       2
Vdd*.3       Vdd*.3
Vdd*.7       Vdd*.7
方框图 (1)
技术文档
数据手册(1)
元器件购买 SN74LV4052A 相关库存
