SN74CBT3384A提供10位高速TTL兼容总线切换。开关的低导通电阻允许以最小的传播延迟进行连接。
该器件被组织为两个5位开关,具有独立的输出使能(OE \)输入。当OE \为低电平时,开关打开,端口A连接到端口B.当OE \为高电平时,开关打开,两个端口之间存在高阻状态。
Configuration |
Number of Channels (#) |
Power Supply Type |
Vss (Min) (V) |
Vss (Max) (V) |
Vdd (Min) (V) |
Vdd (Max) (V) |
Ron (Typ) (Ohms) |
Bandwidth (MHz) |
Rating |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Supply Range (Max) |
Ron (Max) (Ohms) |
Input/Output Continuous Current (Max) (mA) |
Supply Current (Max) (uA) |
OFF-state leakage current (Max) (µA) |
ON-state leakage current (Max) (µA) |
Input/Output OFF-state Capacitance (Typ) (pF) |
VIL (Max) (V) |
VIH (Min) (V) |
SN74CBT3384A |
1:1 SPST |
10 |
Single |
N/A |
N/A |
4 |
5.5 |
5 |
200 |
Catalog |
-40 to 85 |
24SOIC: 160 mm2: 10.3 x 15.5(SOIC) 24SSOP: 52 mm2: 6 x 8.65(SSOP) 24SSOP: 64 mm2: 7.8 x 8.2(SSOP) 24TSSOP: 50 mm2: 6.4 x 7.8(TSSOP) 24TVSOP: 32 mm2: 6.4 x 5(TVSOP) |
SOIC SSOP SSOP TSSOP TVSOP |
5.5 |
20 |
128 |
3 |
1 |
1 |
4.5 |
0.8 |
2 |
