?? CBTD3384器件提供10位高速TTL兼容总线切换。开关的低导通电阻允许在不增加传播延迟的情况下进行连接。二极管至V CC 集成在芯片上,允许在5V输入和3.3V输出之间进行电平转换。
这些器件组织为两个5位开关具有单独的输出使能(OE \)输入。当OE \为低电平时,开关打开,端口A连接到端口B.当OE \为高电平时,开关打开,两个端口之间存在高阻状态。
小>
Configuration |
Number of Channels (#) |
Power Supply Type |
Vss (Min) (V) |
Vss (Max) (V) |
Vdd (Min) (V) |
Vdd (Max) (V) |
Ron (Typ) (Ohms) |
Bandwidth (MHz) |
Rating |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Supply Range (Max) |
Ron (Max) (Ohms) |
Input/Output Continuous Current (Max) (mA) |
Supply Current (Max) (uA) |
Features |
OFF-state leakage current (Max) (µA) |
ON-state leakage current (Max) (µA) |
Input/Output ON-state Capacitance (Typ) (pF) |
Input/Output OFF-state Capacitance (Typ) (pF) |
ESD Charged Device Model (kV) |
ESD HBM (kV) |
VIL (Max) (V) |
VIH (Min) (V) |
SN74CBTD3384 | SN54CBTD3384 | SN74CB3T3384 | SN74CBTD3384C |
1:1 SPST | SPST | 1:1 SPST | 1:1 SPST |
10 | 10 | 10 | 10 |
Single | Single | Single | |
N/A | N/A | N/A | |
N/A | N/A | N/A | |
4.5 | 2.3 | 4.5 | |
5.5 | 3.6 | 5.5 | |
5 | 5 | 5 | 3 |
20 | 20 | 100 | 20 |
Catalog | Military | Catalog | Catalog |
-40 to 85 | -55 to 125 | -40 to 85 | -40 to 85 |
24SOIC: 160 mm2: 10.3 x 15.5(SOIC) 24SSOP: 52 mm2: 6 x 8.65(SSOP) 24SSOP: 64 mm2: 7.8 x 8.2(SSOP) 24TSSOP: 50 mm2: 6.4 x 7.8(TSSOP) 24TVSOP: 32 mm2: 6.4 x 5(TVSOP) | 28LCCC: 131 mm2: 11.43 x 11.43(LCCC) | 24SOIC: 160 mm2: 10.3 x 15.5(SOIC) 24SSOP: 52 mm2: 6 x 8.65(SSOP) 24TSSOP: 50 mm2: 6.4 x 7.8(TSSOP) | 24SOIC: 160 mm2: 10.3 x 15.5(SOIC) 24SSOP: 52 mm2: 6 x 8.65(SSOP) 24SSOP: 64 mm2: 7.8 x 8.2(SSOP) 24TSSOP: 50 mm2: 6.4 x 7.8(TSSOP) 24TVSOP: 32 mm2: 6.4 x 5(TVSOP) |
SOIC SSOP SSOP TSSOP TVSOP | LCCC | SOIC SSOP TSSOP | SOIC SSOP SSOP TSSOP TVSOP |
5.5 | 3.6 | 5.5 | |
50 | 7 | 8 | 20 |
128 | 128 | 128 | 128 |
1500 | 3 | 1500 | |
Voltage Level Shifting | Powered off protection Signal path Translation | Powered off protection -2V undershoot protection Voltage Level Shifting | |
1 | 10 | 10 | |
1 | |||
4 | 12.5 | ||
3.5 | 5 | 5 | |
1 | 1 | ||
2 | 2 | ||
0.8 | 0.8 | 0.8 | |
2 | 1.7 | 2 | |
无样片 |
