SN74CBTD3306具有两个独立的线路开关。当相关的输出使能(OE \)输入为高电平时,每个开关都被禁用。芯片上集成了一个二极管至V CC ,允许在5V输入和3.3V输出之间进行电平转换。
小>
Configuration |
Number of Channels (#) |
Power Supply Type |
Vss (Min) (V) |
Vss (Max) (V) |
Vdd (Min) (V) |
Vdd (Max) (V) |
Ron (Typ) (Ohms) |
Bandwidth (MHz) |
Rating |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Supply Range (Max) |
Ron (Max) (Ohms) |
Input/Output Continuous Current (Max) (mA) |
Supply Current (Max) (uA) |
Features |
OFF-state leakage current (Max) (µA) |
ON-state leakage current (Max) (µA) |
Input/Output ON-state Capacitance (Typ) (pF) |
Input/Output OFF-state Capacitance (Typ) (pF) |
ESD Charged Device Model (kV) |
ESD HBM (kV) |
VIL (Max) (V) |
VIH (Min) (V) |
SN74CBTD3306 | SN74CB3T3306 | SN74CBTD3306C |
1:1 SPST | 1:1 SPST | 1:1 SPST |
2 | 2 | 2 |
Single | Single | Single |
N/A | N/A | N/A |
N/A | N/A | N/A |
4.5 | 2.3 | 4.5 |
5.5 | 3.6 | 5.5 |
5 | 5 | 3 |
20 | 100 | 20 |
Catalog | Catalog | Catalog |
-40 to 85 | -40 to 85 | -40 to 85 |
8SOIC: 29 mm2: 6 x 4.9(SOIC) 8TSSOP: 19 mm2: 6.4 x 3(TSSOP) | 8SM8: 12 mm2: 4 x 2.95(SM8) 8VSSOP: 6 mm2: 3.1 x 2(VSSOP) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8TSSOP: 19 mm2: 6.4 x 3(TSSOP) |
SOIC TSSOP | SM8 VSSOP | SOIC TSSOP |
5.5 | 3.6 | 5.5 |
50 | 8 | 20 |
128 | 128 | 128 |
1500 | 20 | 1500 |
Voltage Level Shifting | Powered off protection Signal path Translation | Powered off protection -2V undershoot protection Voltage Level Shifting |
1 | 10 | 10 |
1 | ||
4 | 12.5 | |
4 | 4.5 | 5 |
1 | 1 | |
2 | 2 | |
0.8 | 0.8 | 0.8 |
2 | 1.7 | 2 |
