CD74AC238 3 线至 8 线同向解码器/多路解复用器
数据:
The CD74AC238 decoder/demultiplexer is designed for high-performance memory-decoding and data-routing applications that require very short propagation-delay times. In high-performance memory systems, this decoder can be used to minimize the effects of system decoding. When employed with high-speed memories utilizing a fast enable circuit, the delay times of this decoder and the enable time of the memory usually are less than the typical access time of the memory. This means that the effective system delay introduced by the decoder is negligible.
The conditions at the binary-select inputs and the three enable inputs select one of eight output lines. Two active-low and one active-high enable inputs reduce the need for external gates or inverters when expanding. A 24-line decoder can be implemented without external inverters, and a 32-line decoder requires only one inverter. An enable input can be used as a data input for demultiplexing applications (see Application Information).
特性
  • 交流电源类型具有1.5V至5.5V的工作电压和30%电源电压下的均衡噪声抗扰度
  • 双极F,AS和S的速度,显着降低功耗
  • 专为高速存储器解码器和数据传输系统而设计
  • 采用三个使能输入来简化级联和/或数据接收
  • 平衡传播延迟
  • ±24-mA输出驱动电流
    • 扇出至15 F设备
  • 耐SCR闩锁CMOS工艺和电路设计
  • 超过MIL-STD-883的2kV ESD保护,方法3015
参数 与其它产品相比 编码器和解码器
Function
Technology Family
VCC (Min) (V)
VCC (Max) (V)
Channels (#)
Voltage (Nom) (V)
F @ Nom Voltage (Max) (Mhz)
ICC @ Nom Voltage (Max) (mA)
tpd @ Nom Voltage (Max) (ns)
Configuration
Type
IOL (Max) (mA)
IOH (Max) (mA)
Rating
Operating Temperature Range (C)
Package Group
Package Size: mm2:W x L (PKG)
Bits (#)
Digital input leakage (Max) (uA)
ESD Charged Device Model (kV)
ESD HBM (kV)
CD74AC238
Decoder
Demultiplexer
AC
1.5
5.5
1
1.5
3.3
5
100
0.08
187
21
15
3:8
Standard
24
-24
Catalog
-55 to 125
SOIC
16SOIC: 59 mm2: 6 x 9.9(SOIC)
8
5
0.75
2
技术文档
数据手册(1)
元器件购买 CD74AC238 相关库存
