?? HC4066和CD74HCT4066包含四个独立的数字控制模拟开关,采用硅栅CMOS技术实现与LSTTL类似的低功耗运行速度标准CMOS集成电路。
这些开关具有金属栅极CD4066B的特征线性“导通”电阻。每个开关都通过其控制输入上的高电平电压打开。
从Harris Semiconductor获得的数据表
Configuration |
Number of Channels (#) |
Power Supply Type |
Vss (Min) (V) |
Vss (Max) (V) |
Vdd (Min) (V) |
Vdd (Max) (V) |
Ron (Typ) (Ohms) |
Bandwidth (MHz) |
Rating |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Supply Range (Max) |
Ron (Max) (Ohms) |
Input/Output Continuous Current (Max) (mA) |
Supply Current (Max) (uA) |
Features |
OFF-state leakage current (Max) (µA) |
Input/Output OFF-state Capacitance (Typ) (pF) |
VIL (Max) (V) |
VIH (Min) (V) |
CD74HC4066 | CD54HC4066 |
1:1 SPST | 1:1 SPST |
4 | 4 |
Single | |
N/A | |
N/A | |
2 | |
10 | |
15 | 16 |
200 | 200 |
Catalog | Military |
-55 to 125 | -55 to 125 |
See datasheet (PDIP) 14SOIC: 52 mm2: 6 x 8.65(SOIC) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | See datasheet (CDIP) |
PDIP SOIC TSSOP | CDIP |
10 | |
142 | 70 |
25 | |
20 | |
Low Power | |
1 | |
5 | |
Vdd*.3 | |
Vdd*.7 | |
无样片 |
