CD4016B系列类型是四边双向开关,用于模拟或数字信号的传输或多路复用。四个独立的双向开关中的每一个都有一个控制信号输入,它同时对给定开关中的p和n器件进行开启和关闭。
CD4016“B”系列类型以14引脚供电密封双列直插式陶瓷封装(F3A后缀),14引脚双列直插塑料封装(E后缀),14引脚小外形封装(M,MT,M96和NSR后缀),以及14-引线薄缩小外形封装(PW和PWR后缀)。
数据从Harris Semiconductor获得的表
Configuration |
Number of Channels (#) |
Power Supply Type |
Vss (Min) (V) |
Vss (Max) (V) |
Vdd (Min) (V) |
Vdd (Max) (V) |
Ron (Typ) (Ohms) |
Bandwidth (MHz) |
Rating |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Supply Range (Max) |
Ron (Max) (Ohms) |
Input/Output Continuous Current (Max) (mA) |
Supply Current (Typ) (uA) |
Supply Current (Max) (uA) |
Features |
ON-state leakage current (Max) (µA) |
VIL (Max) (V) |
VIH (Min) (V) |
CD4016B |
1:1 SPST |
4 |
Single Dual |
-10 |
0 |
3 |
18 |
180 |
40 |
Catalog |
-55 to 125 |
See datasheet (PDIP) 14SO: 80 mm2: 7.8 x 10.2(SO) 14SOIC: 52 mm2: 6 x 8.65(SOIC) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) |
PDIP SO SOIC TSSOP |
18 |
860 |
10 |
0.01 |
5 |
Control logic voltage translation Dual supply Break-before-make |
0.1 |
0.9 |
Vdd*.7 |
