数据: CDx4HC405x, CDx4HCT405x High-Speed CMOS Logic Analog Multiplexers and Demultiplexers 数据表
CDx4HC405x和CDx4HCT405x器件是数控模拟开关,采用硅栅CMOS技术实现与LSTTL类似的工作速度,具有标准CMOS的低功耗集成电路。
这些模拟多路复用器和多路分解器控制可能在电源电压范围内变化的模拟电压(例如,V CC 至V EE ) 。它们是双向开关,允许任何模拟输入用作输出,反之亦然。这些开关具有低导通电阻和低OFF泄漏。此外,所有这些设备都有一个启用控制,当高电平时,禁用所有开关到OFF状态。
All other trademarks are the property of their respective owners
Configuration |
Number of Channels (#) |
Power Supply Type |
Vss (Min) (V) |
Vss (Max) (V) |
Vdd (Min) (V) |
Vdd (Max) (V) |
Ron (Typ) (Ohms) |
Bandwidth (MHz) |
Rating |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Supply Range (Max) |
Ron (Max) (Ohms) |
Input/Output Continuous Current (Max) (mA) |
Supply Current (Max) (uA) |
Features |
OFF-state leakage current (Max) (µA) |
ON-state leakage current (Max) (µA) |
Input/Output OFF-state Capacitance (Typ) (pF) |
ESD Charged Device Model (kV) |
ESD HBM (kV) |
VIL (Max) (V) |
VIH (Min) (V) |
CD74HC4052 | CD54HC4052 |
4:1 | |
2 | |
Single Dual | |
-6 | |
0 | |
2 | |
6 | |
40 | 45 |
200 | |
Catalog | Military |
-55 to 125 | -55 to 125 |
See datasheet (PDIP) 16SO: 80 mm2: 7.8 x 10.2(SO) 16SOIC: 59 mm2: 6 x 9.9(SOIC) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) | See datasheet (CDIP) |
PDIP SO SOIC TSSOP | CDIP |
10 | |
270 | 130 |
25 | |
160 | |
Low Power Low Crosstalk Break-before-make | |
1 | |
1 | |
5 | |
0.2 | |
0.5 | |
Vdd*.3 | |
Vdd*.7 | |
无样片 |
