CD4052B 具有低导通泄漏电流的 2 通道 4:1 模拟开关
数据:
CD405xB模拟多路复用器和解复用器是数字控制的模拟开关,具有低导通阻抗和极低的关断漏电流。这些多路复用器电路在整个V DD -V SS 和V DD - V EE 电源上消耗极低的静态功耗 - 电压范围,与控制信号的逻辑状态无关。
特性
  • 广泛的数字和模拟信号电平
    • 数字:3 V至20V
    • 模拟: ≤20V PP
  • 低导通电阻,125Ω(典型值)超过15 V PP V的信号输入范围 DD - V EE = 18 V
  • 高阻断电阻,V DD - V EE = 18 V
  • 3 V至20 V(V DD - V 的数字寻址信号的逻辑电平转换SS = 3 V至20 V)将模拟信号切换至20 V PP (V DD - V EE = 20 V )匹配开关特性,r ON =5Ω(典型值)V DD - V EE = 15 V极低静态功耗全部数字控制输入和供电条件,V DD 时0.2μW(典型值) - V SS = V DD - V EE < /sub> = 10 V
  • 芯片上的二进制地址解码
  • 5 V,10 V和15 V参数速率ngs
  • 100%测试20 V时的静态电流
  • 18 V时整个封装温度范围内的最大输入电流为1μA,18 V和25°C时为100 nA
  • Break-Before-Make Switching消除频道重叠
所有商标均为其各自所有者的财产。
参数 与其它产品相比 模拟开关/多路复用器
Configuration
Number of Channels (#)
Power Supply Type
Vss (Min) (V)
Vss (Max) (V)
Vdd (Min) (V)
Vdd (Max) (V)
Ron (Typ) (Ohms)
Bandwidth (MHz)
Rating
Operating Temperature Range (C)
Package Size: mm2:W x L (PKG)
Package Group
Supply Range (Max)
Ron (Max) (Ohms)
Input/Output Continuous Current (Max) (mA)
Supply Current (Typ) (uA)
Supply Current (Max) (uA)
Features
ESD Charged Device Model (kV)
ESD HBM (kV)
VIL (Max) (V)
VIH (Min) (V)
CD4052B CD4051B CD4051B-MIL CD4051B-Q1 CD4053B
4:1     8:1       8:1     2:1 SPDT
2     1       1     3
Single
Dual
Single
Dual
  Single
Dual
Single
Dual
-10     -10       -10     -10
0     0       0     0
5     5       5     5
20     20       20     20
125     125     125     125     125
25     20       20     30
Catalog     Catalog     Military     Automotive     Catalog
-55 to 125     -55 to 125     -55 to 125     -40 to 125     -55 to 125
See datasheet (PDIP)
16SO: 80 mm2: 7.8 x 10.2(SO)
16SOIC: 59 mm2: 6 x 9.9(SOIC)
16TSSOP: 32 mm2: 6.4 x 5(TSSOP)
See datasheet (CDIP)     16TSSOP: 32 mm2: 6.4 x 5(TSSOP)     See datasheet (PDIP)
PDIP
SO
SOIC
TSSOP
PDIP
SO
SOIC
TSSOP
CDIP     TSSOP     PDIP
SO
SOIC
TSSOP
20     20       20     20
1300     1300     240     1300     1300
10     10       10     10
0.04     0.04       0.04     0.04
3000     3000       3000     3000
Control logic voltage translation
Dual supply
Break-before-make
Dual supply
Break-before-make
Low Power
Break-before-make
Dual supply
Break-before-make
Dual supply
Break-before-make
  2         1.5
  3         2.5
Vdd*.3     Vdd*.3       Vdd*.3     Vdd*.3
Vdd*.7     Vdd*.7       Vdd*.7     Vdd*.7
方框图 (2)
技术文档
数据手册(1)
元器件购买 CD4052B 相关库存
