数据: SN74CBTLV3257 Low-Voltage 4-Bit 1-of-2 FET Multiplexer/Demultiplexer 数据表
SN74CBTLV3257器件是一个4位1:2高速FET多路复用器/多路分解器。开关的低导通状态电阻允许以最小的传播延迟进行连接。
选择(S)输入控制数据流。当输出使能(> OE )输入为高电平时,FET多路复用器/多路分解器被禁用。
此器件完全指定为部分 - 使用I off 关闭应用程序。 I off 功能可确保损坏的电流在断电时不会回流通过器件。在断电期间,器件具有隔离功能。
为确保上电或断电期间的高阻态, OE 应绑定到V CC 通过上拉电阻;电阻的最小值由驱动器的电流吸收能力决定。
Configuration |
Number of Channels (#) |
Power Supply Type |
Vss (Min) (V) |
Vss (Max) (V) |
Vdd (Min) (V) |
Vdd (Max) (V) |
Ron (Typ) (Ohms) |
Bandwidth (MHz) |
Rating |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Supply Range (Max) |
Ron (Max) (Ohms) |
Input/Output Continuous Current (Max) (mA) |
Supply Current (Typ) (uA) |
Supply Current (Max) (uA) |
Features |
OFF-state leakage current (Max) (µA) |
ON-state leakage current (Max) (µA) |
Input/Output ON-state Capacitance (Typ) (pF) |
Input/Output OFF-state Capacitance (Typ) (pF) |
ESD Charged Device Model (kV) |
ESD HBM (kV) |
VIL (Max) (V) |
VIH (Min) (V) |
SN74CBTLV3257 | SN74CB3Q3257 | SN74CBT3257 | SN74CBT3257C |
2:1 SPDT | 2:1 SPDT | 2:1 SPDT | 2:1 SPDT |
4 | 4 | 4 | 4 |
Single | Single | Single | Single |
N/A | N/A | N/A | N/A |
2.3 | 2.3 | 4 | 4 |
3.6 | 3.6 | 5.5 | 5.5 |
5 | 4 | 5 | 3 |
200 | 500 | 200 | 200 |
Catalog | Catalog | Catalog | Catalog |
-40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
16SOIC: 59 mm2: 6 x 9.9(SOIC) 16SSOP: 29 mm2: 6 x 4.9(SSOP) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) 16TVSOP: 23 mm2: 6.4 x 3.6(TVSOP) 16UQFN: 5 mm2: 1.8 x 2.6(UQFN) 16VQFN: 14 mm2: 3.5 x 4(VQFN) | 16SSOP: 29 mm2: 6 x 4.9(SSOP) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) 16TVSOP: 23 mm2: 6.4 x 3.6(TVSOP) 16VQFN: 14 mm2: 3.5 x 4(VQFN) | 16SOIC: 59 mm2: 6 x 9.9(SOIC) 16SSOP: 29 mm2: 6 x 4.9(SSOP) 16SSOP: 48 mm2: 7.8 x 6.2(SSOP) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) 16VQFN: 14 mm2: 3.5 x 4(VQFN) | 16SOIC: 59 mm2: 6 x 9.9(SOIC) 16SSOP: 29 mm2: 6 x 4.9(SSOP) 16SSOP: 48 mm2: 7.8 x 6.2(SSOP) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) 16VQFN: 14 mm2: 3.5 x 4(VQFN) |
SOIC SSOP TSSOP TVSOP UQFN VQFN | SSOP TSSOP TVSOP VQFN | SOIC SSOP SSOP TSSOP VQFN | SOIC SSOP SSOP TSSOP VQFN |
40 | 9 | 20 | 12 |
128 | 64 | 128 | 128 |
250 | |||
10 | 700 | 3 | 3 |
Powered off protection | Powered off protection | Powered off protection -2V undershoot protection | |
1 | 1 | 10 | |
1 | 1 | ||
10.5 | 16.5 | ||
5.5 | 3.5 | 4 | 5.5 |
1 | 1 | ||
2 | 2 | 2 | |
0.8 | 0.8 | 0.8 | 0.8 |
2 | 1.7 | 2 | 2 |
