SN74CBTLV1G125具有单个高速线路开关。当输出??启用(> OE )输入为高电平时,开关被禁用。
此设备完全指定为部分功率使用I off 关闭应用程序。 I off 功能可确保损坏的电流在断电时不会回流通过器件。在断电期间,器件具有隔离功能。
为确保上电或断电期间的高阻抗状态, OE 应绑定通过上拉电阻到V CC ;电阻的最小值由驱动器的电流吸收能力决定。
Configuration |
Number of Channels (#) |
Power Supply Type |
Vss (Min) (V) |
Vss (Max) (V) |
Vdd (Min) (V) |
Vdd (Max) (V) |
Ron (Typ) (Ohms) |
Bandwidth (MHz) |
Rating |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Supply Range (Max) |
Ron (Max) (Ohms) |
Input/Output Continuous Current (Max) (mA) |
Supply Current (Max) (uA) |
Features |
OFF-state leakage current (Max) (µA) |
ON-state leakage current (Max) (µA) |
Input/Output OFF-state Capacitance (Typ) (pF) |
VIL (Max) (V) |
VIH (Min) (V) |
SN74CBTLV1G125 | SN74CB3T1G125 | SN74CBT1G125 | SN74CBTLV1G125-Q1 |
1:1 SPST | 1:1 SPST | 1:1 SPST | |
1 | 1 | 1 | |
Single | Single | Single | |
N/A | N/A | N/A | |
N/A | N/A | N/A | |
2.3 | 4 | 2.3 | |
3.6 | 5.5 | 3.6 | |
5 | 5 | 5 | |
200 | 200 | ||
Catalog | Catalog | Catalog | Automotive |
-40 to 85 | -40 to 85 | -40 to 85 | -40 to 125 |
5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) |
SC70 SOT-23 | SC70 SOT-23 | SC70 SOT-23 | SOT-23 |
3.6 | 5.5 | 3.6 | |
25 | 20 | 25 | |
128 | 128 | ||
10 | 10 | ||
Powered off protection | Voltage translation Ioff 5V tolerant I/O bidirectional low capacitance and on-resistance | low tpd unbuffered low Ron Ioff 3-state Powered off protection | |
1 | 1 | ||
1 | 1 | ||
7 | 4 | 7 | |
0.8 | 0.8 | 0.8 | |
2 | 2 | 2 | |
