SN74TVC3306器件提供三个并联的NMOS传输晶体管和一个共用的无缓冲栅极。开关的低导通状态电阻允许以最小的传播延迟进行连接。
该器件可用作双开关,栅极级联到参考晶体管。每个传输晶体管的低压侧限于由参考晶体管设置的电压。这样做是为了保护具有对高态电压电平过冲敏感的输入的元件。
Configuration |
Number of Channels (#) |
Power Supply Type |
Vss (Min) (V) |
Vss (Max) (V) |
Vdd (Min) (V) |
Vdd (Max) (V) |
Ron (Typ) (Ohms) |
Bandwidth (MHz) |
Rating |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Supply Range (Max) |
Ron (Max) (Ohms) |
Input/Output Continuous Current (Max) (mA) |
Supply Current (Typ) (uA) |
Supply Current (Max) (uA) |
OFF-state leakage current (Max) (µA) |
Input/Output ON-state Capacitance (Typ) (pF) |
Input/Output OFF-state Capacitance (Typ) (pF) |
ESD Charged Device Model (kV) |
ESD HBM (kV) |
VIL (Max) (V) |
VIH (Min) (V) |
SN74TVC3306 |
1:1 SPST |
3 |
Single |
N/A |
N/A |
0 |
5 |
3.5 |
100 |
Catalog |
-40 to 85 |
8SM8: 12 mm2: 4 x 2.95(SM8) 8VSSOP: 6 mm2: 3.1 x 2(VSSOP) |
SM8 VSSOP |
5 |
9.5 |
64 |
0.07 |
1 |
5 |
10.5 |
4 |
2 |
2.5 |
N/A |
N/A |
