数据: SN74CBTLV3253 低电压、双 4 选 1 FET 多路复用器/多路信号分离器 数据表 (Rev. J)
这个开关具有低导通状态电阻,可以在最短传播延迟情况下建立连接。
选择(S0,S1)输入端控制数据流。当相关输出使能( OE )输入为高电平时,FET多路复用器/多路信号分离器被禁用。
SN74CBTLV3253器件完全适用于使用I off 的局部掉电应用.I off 特性确保在关断时防止损坏电流通过器件回流。该器件可在关断时提供隔离。
所有商标均为其各自所有者的财产。
Configuration |
Number of Channels (#) |
Power Supply Type |
Vss (Min) (V) |
Vss (Max) (V) |
Vdd (Min) (V) |
Vdd (Max) (V) |
Ron (Typ) (Ohms) |
Bandwidth (MHz) |
Rating |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Supply Range (Max) |
Ron (Max) (Ohms) |
Input/Output Continuous Current (Max) (mA) |
Supply Current (Typ) (uA) |
Supply Current (Max) (uA) |
Features |
OFF-state leakage current (Max) (µA) |
ON-state leakage current (Max) (µA) |
Input/Output ON-state Capacitance (Typ) (pF) |
Input/Output OFF-state Capacitance (Typ) (pF) |
ESD Charged Device Model (kV) |
ESD HBM (kV) |
VIL (Max) (V) |
VIH (Min) (V) |
SN74CBTLV3253 | SN74CB3Q3253 |
4:1 | 4:1 |
2 | 2 |
Single | Single |
N/A | N/A |
N/A | N/A |
2.3 | 2.3 |
3.6 | 3.6 |
5 | 3.5 |
200 | 500 |
Catalog | Catalog |
-40 to 85 | -40 to 85 |
16SOIC: 59 mm2: 6 x 9.9(SOIC) 16SSOP: 29 mm2: 6 x 4.9(SSOP) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) 16TVSOP: 23 mm2: 6.4 x 3.6(TVSOP) 16VQFN: 14 mm2: 3.5 x 4(VQFN) | 16SSOP: 29 mm2: 6 x 4.9(SSOP) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) 16TVSOP: 23 mm2: 6.4 x 3.6(TVSOP) 16VQFN: 14 mm2: 3.5 x 4(VQFN) |
SOIC SSOP TSSOP TVSOP VQFN | SSOP TSSOP TVSOP VQFN |
3.6 | 3.6 |
40 | 11 |
128 | 64 |
700 | |
10 | 1500 |
Powered off protection | Powered off protection |
1 | 1 |
1 | |
13 | |
5.5 | 3.5 |
1 | 1 |
2 | 2 |
0.8 | 0.8 |
2 | 1.7 |
