CD4067B CMOS 单路 16 通道模拟多路复用器/多路解复用器
数据:
CD4067B和CD4097B CMOS模拟多路复用器/多路分解器*是数字控制的模拟开关,具有低导通阻抗,低OFF漏电流和内部地址解码。此外,导通电阻在整个输入信号范围内相对恒定。 CD4067B是一个16通道多路复用器,带有四个二进制控制输入A,B,C,D和一个禁止输入,其排列方式使得任何输入组合都可以选择一个开关。
CD4097B是一个差分8通道多路复用器具有三个二进制控制输入A,B,C和禁止输入。输入允许选择八对开关中的一对。
禁止输入端的逻辑“1”将关闭所有通道。
CD4067B和CD4097B类型提供24 -lead密封双列直插式陶瓷封装(F3A后缀),24引脚双列直插塑料封装(E后缀),24引脚小外形封装(M,M96和NSR后缀),以及24-铅薄收缩小外形封装(P和PWR后缀)。
特性
  • Low ON resistance: 125 (typ.) over 15 Vp-p signal-input range for VDD - VSS = 15 V
  • High OFF resistance: channel leakage of ±10 pA (typ.) @ VDD - VSS = 10 V
  • Matched switch characteristics: RON = 5 (typ.) for VDD - VSS = 15 V
  • Very low quiescent power dissipation under all digital-control input and supply conditions: 0.2 uW (typ.) @ VDD - VSS = 10 V
  • Binary address decoding on chip
  • 5-V, 10-V, and 15-V parametric ratings
  • 100% tested for quiescent current at 20 V
  • Maximum input current of 1 µA at 18 V over full package-temperature range; 100nA at 18 V and 25°C
  • Meets all requirements of JEDEC Tentative Standard No. 13A, "Standard Specifications for Description of 'B' Series CMOS Devices"
  • Applications:
    • Analog and digital multiplexing and demultiplexing
    • A/D and D/A conversion
    • Siganl gating
* When these devices are used as demultiplexers, the channel in/out terminals are the outputs and the common out/in terminals are the inputs.
参数 与其它产品相比 模拟开关/多路复用器
Configuration
Number of Channels (#)
Power Supply Type
Vss (Min) (V)
Vss (Max) (V)
Vdd (Min) (V)
Vdd (Max) (V)
Ron (Typ) (Ohms)
Bandwidth (MHz)
Rating
Operating Temperature Range (C)
Package Size: mm2:W x L (PKG)
Package Group
Supply Range (Max)
Ron (Max) (Ohms)
Input/Output Continuous Current (Max) (mA)
Supply Current (Typ) (uA)
Supply Current (Max) (uA)
Features
VIL (Max) (V)
VIH (Min) (V)
CD4067B
16:1
1
Single
Dual
-5
18
125
14
Catalog
-55 to 125
24SOIC: 160 mm2: 10.3 x 15.5(SOIC)
24TSSOP: 50 mm2: 6.4 x 7.8(TSSOP)
SOIC
TSSOP
18
1300
10
0.04
600
Dual supply
Vdd*.3
Vdd*.7
技术文档
数据手册(1)
元器件购买 CD4067B 相关库存
