CD4514B 可选择输出“高”的 CMOS 4 位锁存器/4 至 16 线路解码器
数据:
CD4514B and CD4515B consist of a 4-bit strobed latch and a 4-to-16-line decoder. The latches hold the last input data presented prior to the strobe transition from 1 to 0. Inhibit control allows all outputs to be placed at 0 (CD4514B) or 1 (CD4515B) regardless of the state of the data or strobe inputs.
The decode truth table indicates all combinations of data inputs and appropriate selected outputs.
These devices are similar to industry types MC14514 and MC14515.
The CD4514B and CD4515B types are supplied in 16-lead hermetic dual-in-line ceramic packages (F3A suffix), 16-lead dual-in-line plastic packages (E suffix), and 16-lead small-outline packages (M and M96 suffixes).
特性
CD4514B输出“高”选择
CD4515B输出“低”选择
  • 选通输入锁存器
  • 禁止控制
  • 100%测试20 V时的静态电流
  • 在整个封装温度范围内,18 V时的最大输入电流为1μA;在18 V和25°C下100 nA
  • 噪声容限(在整个封装温度范围内):
    • 1 V,V DD = 5 V
    • 2 V V DD = 10 V
    • 2.5 V V DD = 15 V
    < /li>
  • 5 V,10 V和15 V参数额定值
  • 标准化,对称输出特性
  • 满足JEDEC暂定标准No. 13B的所有要求, “B ??系列CMOS器件描述的标准规范”
  • 应用:
    • 数字多路复用
    • 地址解码
    • 十六进制/BCD解码
    • 程序计数器解码
    • 控制解码器
从Harris Semiconductor获取数据表。
参数 与其它产品相比 编码器和解码器
Function
Technology Family
VCC (Min) (V)
VCC (Max) (V)
Channels (#)
Voltage (Nom) (V)
F @ Nom Voltage (Max) (Mhz)
ICC @ Nom Voltage (Max) (mA)
tpd @ Nom Voltage (Max) (ns)
Configuration
Type
IOL (Max) (mA)
IOH (Max) (mA)
Rating
Operating Temperature Range (C)
Package Group
Package Size: mm2:W x L (PKG)
Bits (#)
Digital input leakage (Max) (uA)
ESD Charged Device Model (kV)
ESD HBM (kV)
CD4514B
Decoder
Demultiplexer
CD4000
3
18
4
5
10
15
8
0.3
370
4:16
Standard
1.5
-1.5
Catalog
-55 to 125
SOIC
24SOIC: 160 mm2: 10.3 x 15.5(SOIC)
16
5
0.75
2
技术文档
数据手册(1)
元器件购买 CD4514B 相关库存
