CD54HC4511,CD74HC4511和CD74HCT4511是BCD至7段锁存器/解码器/驱动器,具有四个地址输入(D 0 ?? D 3 ),有效低消隐(BL)\输入,灯测试(LT)\输入和锁存使能(LE)\输入,当高电平时,使能用于存储BCD输入的锁存器。当LE \为低电平时,锁存器被禁用,使输出对BCD输入透明。
这些器件具有标准尺寸的输出晶体管,但能够输出(标准V OH < /sub>水平)4.5 V时最高7.5 mA.HC类型可在6 V时提供高达10 mA的电流。
Function |
Technology Family |
VCC (Min) (V) |
VCC (Max) (V) |
Channels (#) |
Voltage (Nom) (V) |
F @ Nom Voltage (Max) (Mhz) |
ICC @ Nom Voltage (Max) (mA) |
tpd @ Nom Voltage (Max) (ns) |
Configuration |
Type |
IOL (Max) (mA) |
IOH (Max) (mA) |
Rating |
Operating Temperature Range (C) |
Package Group |
Package Size: mm2:W x L (PKG) |
Bits (#) |
Digital input leakage (Max) (uA) |
ESD Charged Device Model (kV) |
ESD HBM (kV) |
CD74HC4511 | CD54HC4511 |
Decoder Demultiplexer | Decoder/Demultiplexer |
HC | HC |
2 | 2 |
6 | 6 |
1 | 1 |
3.3 5 | 3.3 5 |
28 | 28 |
0.08 | 0.08 |
60 | 60 |
4:7 | 4:7 |
Standard | Standard |
5.2 | 5.2/-10 |
-10 | |
Catalog | Military |
-55 to 125 | -55 to 125 |
PDIP SOIC TSSOP | CDIP |
See datasheet (PDIP) 16SOIC: 59 mm2: 6 x 9.9(SOIC) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) | See datasheet (CDIP) |
7 | 7 |
5 | 5 |
0.75 | 0.75 |
2 | 2 |
无样片 |
