数据: LMH6629 Ultra-Low Noise, High-Speed Operational Amplifier with Shutdown 数据表
LMH6629是一款高速,超低噪声放大器,专为需要宽带宽,高增益和低噪声的应用而设计,如通信,测试和测量,光学和超声波系统。
LMH6629采用2.7 V至5.5 V电源供电,输入共模范围扩展至地下,输出摆幅仅为导轨的0.8 V以内用于单一供应应用。高频大信号可以驱动高达±250 mA的重负载,LMH6629的-3dB带宽为900 MHz,压摆率为1600 V /μs。 LMH6629(仅限WSON-8封装)具有用户可选的内部补偿,通过将COMP引脚拉低或拉高来控制4或10的最小增益,从而避免在竞争器件中需要外部补偿电容。 SOT-23-5封装的补偿在内部设置,最小稳定增益为10 V /V. WSON-8封装还提供掉电启用/禁用功能。
低输入噪声(0.69 nV /√ Hz 和2.6 pA /√ Hz ),低失真(HD2 /HD3 = -90 dBc /-94 dBc)和超低DC误差(800μVV< sub> OS 最大温度,±0.45μV/°C漂移)允许在交流和直流耦合应用中进行精确操作。
LMH6629采用德州仪器制造?采用专有的SiGe工艺,采用3 mm×3 mm 8引脚WSON封装和SOT-23-5封装。
Architecture |
Number of Channels (#) |
Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
BW @ Acl (MHz) |
Acl, min spec gain (V/V) |
Slew Rate (Typ) (V/us) |
Vn at Flatband (Typ) (nV/rtHz) |
Vn at 1kHz (Typ) (nV/rtHz) |
Iq per channel (Typ) (mA) |
Vos (Offset Voltage @ 25C) (Max) (mV) |
Rail-to-Rail |
Features |
Rating |
Operating Temperature Range (C) |
Package Group |
Package Size: mm2:W x L (PKG) |
CMRR (Typ) (dB) |
Input Bias Current (Max) (pA) |
Offset Drift (Typ) (uV/C) |
GBW (Typ) (MHz) |
Output Current (Typ) (mA) |
2nd Harmonic (dBc) |
3rd Harmonic (dBc) |
@ MHz |
LMH6629 | LMH6624 | LMH6628 | LMH6654 |
Bipolar Voltage FB | Bipolar | Bipolar Voltage FB | Bipolar Voltage FB |
1 | 1 | 2 | 1 |
2.7 | 5 | 5 | 4.5 |
5.5 | 12 | 12 | 12 |
900 | 150 | 300 | 250 |
4 | 10 | 1 | 1 |
1100 | 400 | 550 | 200 |
0.69 | 0.92 | 2 | 4.5 |
15.5 | 12 | 9 | 4.5 |
0.78 | 0.5 | 2 | 3 |
No | No | No | In to V- |
Decompensated | Decompensated | N/A | N/A |
Catalog | Catalog | Catalog | Catalog |
-40 to 125 | -40 to 125 | -40 to 85 | -40 to 85 |
SOT-23 WSON | SOIC SOT-23 | SOIC | SOIC SOT-23 |
5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) See datasheet (WSON) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) |
87 | 95 | 62 | 90 |
23000 | 20000000 | 20000000 | 10000000 |
0.45 | 0.25 | 5 | 6 |
4000 | 1800 | 300 | 250 |
250 | 100 | 85 | 186 |
88 | 63 | 65 | 80 |
74 | 80 | 74 | 85 |
1 | 10 | 10 | 1 |
