该器件是一款数控模拟开关,利用硅栅CMOS技术实现与LSTTL类似的工作速度,集成了标准CMOS的低功耗该模拟多路复用器/多路分解器控制可在电源电压范围内变化的模拟电压(即V CC 至V EE )。这些双向开关允许任何模拟输入用作输出,反之亦然。这些开关具有低导通电阻和低OFF泄漏。此外,该设备还具有启用控制 E ,当处于高电平时,禁用所有开关到其OFF状态。
Configuration |
Number of Channels (#) |
Power Supply Type |
Vss (Min) (V) |
Vss (Max) (V) |
Vdd (Min) (V) |
Vdd (Max) (V) |
Ron (Typ) (Ohms) |
Bandwidth (MHz) |
Rating |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Supply Range (Max) |
Ron (Max) (Ohms) |
Input/Output Continuous Current (Max) (mA) |
Supply Current (Typ) (uA) |
Supply Current (Max) (uA) |
Features |
OFF-state leakage current (Max) (µA) |
ON-state leakage current (Max) (µA) |
Input/Output OFF-state Capacitance (Typ) (pF) |
ESD Charged Device Model (kV) |
ESD HBM (kV) |
VIL (Max) (V) |
VIH (Min) (V) |
CD74HC4051-Q1 | CD54HC4051 | CD74HC4051 | CD74HC4051-EP |
8:1 | 8:1 | ||
1 | 1 | ||
Single Dual | Single Dual | ||
-6 | -6 | ||
0 | 0 | ||
2 | 2 | ||
6 | 6 | ||
40 | 45 | 40 | 45 |
180 | 200 | ||
Automotive | Military | Catalog | HiRel Enhanced Product |
-40 to 125 | -55 to 125 | -55 to 125 | -55 to 125 |
16SOIC: 59 mm2: 6 x 9.9(SOIC) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) | See datasheet (CDIP) | See datasheet (PDIP) 16SO: 80 mm2: 7.8 x 10.2(SO) 16SOIC: 59 mm2: 6 x 9.9(SOIC) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) | 16SOIC: 59 mm2: 6 x 9.9(SOIC) |
SOIC TSSOP | CDIP | PDIP SO SOIC TSSOP | SOIC |
10 | 10 | ||
270 | 130 | 270 | 130 |
25 | 25 | ||
16 | 8 | ||
320 | 80 | ||
Dual supply Break-before-make | Low Power Low Crosstalk Break-before-make | Dual supply Break-before-make | Low Power Low Crosstalk Break-before-make |
2 | 1 | ||
2 | 1 | ||
5 | 5 | ||
0.2 | |||
0.5 | |||
Vdd*.3 | Vdd*.3 | ||
Vdd*.7 | Vdd*.7 | ||
无样片 |
