数据: High Speed CMOS Logic Analog Multiplexer/Demultiplexer 数据表
该器件是一款数控模拟开关,利用硅栅CMOS技术实现与LSTTL类似的工作速度,集成了标准CMOS的低功耗该模拟多路复用器/多路分解器控制可在电源电压范围内变化的模拟电压(即V CC 至V EE )。它是一个双向开关,允许任何模拟输入用作输出,反之亦然。该开关具有低导通电阻和低OFF泄漏。此外,该器件具有一个使能控制,当高电平时,禁止所有开关进入OFF状态。
Configuration |
Number of Channels (#) |
Power Supply Type |
Vss (Min) (V) |
Vss (Max) (V) |
Vdd (Min) (V) |
Vdd (Max) (V) |
Ron (Typ) (Ohms) |
Bandwidth (MHz) |
Rating |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Supply Range (Max) |
Ron (Max) (Ohms) |
Input/Output Continuous Current (Max) (mA) |
Supply Current (Typ) (uA) |
Supply Current (Max) (uA) |
Features |
OFF-state leakage current (Max) (µA) |
ON-state leakage current (Max) (µA) |
Input/Output ON-state Capacitance (Typ) (pF) |
Input/Output OFF-state Capacitance (Typ) (pF) |
ESD Charged Device Model (kV) |
ESD HBM (kV) |
VIL (Max) (V) |
VIH (Min) (V) |
CD74HCT4051-Q1 | CD54HCT4051 | CD74HCT4051 |
8:1 | 8:1 | |
1 | 1 | |
Single Dual | Single Dual | |
-6 | -6 | |
0 | 0 | |
4.5 | 4.5 | |
5.5 | 5.5 | |
40 | 45 | 40 |
180 | 180 | |
Automotive | Military | Catalog |
-40 to 125 | -55 to 125 | -55 to 125 |
16SOIC: 59 mm2: 6 x 9.9(SOIC) | See datasheet (CDIP) | See datasheet (PDIP) 16SOIC: 59 mm2: 6 x 9.9(SOIC) |
SOIC | CDIP | PDIP SOIC |
10 | 10 | |
270 | 130 | 270 |
25 | 25 | |
8 | 8 | |
160 | 80 | |
Dual supply Break-before-make | Low Power Low Crosstalk Break-before-make | Dual supply Break-before-make |
2 | 1 | |
2 | 1 | |
25 | 25 | |
5 | 5 | |
0.2 | ||
0.5 | ||
0.8 | 0.8 | |
2 | 2 | |
无样片 |
