This dual analog switch is operational at 0.8-V to 2.7-V VCC, but is designed specifically for 1.1-V to 2.7-V VCC operation.
The SN74AUC2G66 can handle both analog and digital signals. It permits signals with amplitudes of up to 2.7-V (peak) to be transmitted in either direction.
NanoFree package technology is a major breakthrough in IC packaging concepts, using the die as the package.
Applications include signal gating, chopping, modulation or demodulation (modem), and signal multiplexing for analog-to-digital and digital-to-analog conversion systems.
< small> NanoFree是德州仪器公司的商标。
Configuration |
Number of Channels (#) |
Power Supply Type |
Vss (Min) (V) |
Vss (Max) (V) |
Vdd (Min) (V) |
Vdd (Max) (V) |
Ron (Typ) (Ohms) |
Bandwidth (MHz) |
Rating |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Supply Range (Max) |
Ron (Max) (Ohms) |
Input/Output Continuous Current (Max) (mA) |
Supply Current (Max) (uA) |
Features |
OFF-state leakage current (Max) (µA) |
ON-state leakage current (Max) (µA) |
Input/Output ON-state Capacitance (Typ) (pF) |
Input/Output OFF-state Capacitance (Typ) (pF) |
ESD Charged Device Model (kV) |
ESD HBM (kV) |
VIL (Max) (V) |
VIH (Min) (V) |
SN74AUC2G66 |
1:1 SPST |
2 |
Single |
N/A |
N/A |
0.8 |
2.7 |
4 |
500 |
Catalog |
-40 to 85 |
See datasheet (DSBGA) 8SM8: 12 mm2: 4 x 2.95(SM8) 8VSSOP: 6 mm2: 3.1 x 2(VSSOP) |
DSBGA SM8 VSSOP |
2.7 |
40 |
50 |
10 |
low tpd unbuffered |
1 |
1 |
7 |
3 |
1 |
2 |
Vdd*.35 |
Vdd*.65 |
