TS5A1066 10 欧姆 SPST 模拟开关
数据:
TS5A1066是一款单刀单掷(SPST)模拟开关,设计工作电压为1.65 V至5.5 V.该器件可同时处理数字和模拟信号以及高达V + (峰值)的信号可以向任一方向传输。
特性
  • 低导通电阻(10Ω)
  • 控制输入为5.5V容差
  • 低电荷注入
  • 低总谐波失真(THD)
  • 1.65 V至5.5 V单电源供电
  • 闩锁性能超过100 mA根据JESD 78,II类
  • 每个JESD测试的ESD性能22
    • 2000-V人体模型
      (A114-B,II类)
    • 1000 V充电设备型号(C101)
参数 与其它产品相比 模拟开关/多路复用器
Configuration
Number of Channels (#)
Power Supply Type
Vss (Min) (V)
Vss (Max) (V)
Vdd (Min) (V)
Vdd (Max) (V)
Ron (Typ) (Ohms)
Bandwidth (MHz)
Rating
Operating Temperature Range (C)
Package Size: mm2:W x L (PKG)
Package Group
Supply Range (Max)
Ron (Max) (Ohms)
Input/Output Continuous Current (Max) (mA)
Supply Current (Typ) (uA)
Supply Current (Max) (uA)
Features
OFF-state leakage current (Max) (µA)
ON-state leakage current (Max) (µA)
Input/Output ON-state Capacitance (Typ) (pF)
Input/Output OFF-state Capacitance (Typ) (pF)
ESD Charged Device Model (kV)
ESD HBM (kV)
VIL (Max) (V)
VIH (Min) (V)
TS5A1066 TS5A3166 TS5A3167
1:1 SPST     1:1 SPST     1:1 SPST
1     1     1
Single     Single     Single
N/A     N/A     N/A
N/A     N/A     N/A
1.65     1.65     1.65
5.5     5.5     5.5
7.5     0.7     0.75
400     200     200
Catalog     Catalog     Catalog
-40 to 85     -40 to 85     -40 to 85
See datasheet (DSBGA)
5SC70: 4 mm2: 2.1 x 2(SC70)
5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23)
DSBGA
SC70
SOT-23
DSBGA
SC70
SOT-23
DSBGA
SC70
SOT-23
5.5     5.5     5.5
100     4     4
50     200     200
  0.001
10     0.8     10
  Break-before-make     Powered off protection
2     0.1     0.15
2     0.02     0.05
14     36.5     35.5
6.8     19.5     18
1     1     1
2     2     2
Vdd*.3     0.8     0.8
Vdd*.7     1.5     1.5
技术文档
数据手册(1)
元器件购买 TS5A1066 相关库存
