CD54HC4511,CD74HC4511和CD74HCT4511是BCD至7段锁存器/解码器/驱动器,具有四个地址输入(D 0 ?? D 3 ),有效低消隐(BL)\输入,灯测试(LT)\输入和锁存使能(LE)\输入,当高电平时,使能用于存储BCD输入的锁存器。当LE \为低电平时,锁存器被禁用,使输出对BCD输入透明。
这些器件具有标准尺寸的输出晶体管,但能够输出(标准V OH < /sub>水平)4.5 V时最高7.5 mA.HC类型可在6 V时提供高达10 mA的电流。
Function |
Technology Family |
VCC (Min) (V) |
VCC (Max) (V) |
Channels (#) |
Voltage (Nom) (V) |
F @ Nom Voltage (Max) (Mhz) |
ICC @ Nom Voltage (Max) (mA) |
tpd @ Nom Voltage (Max) (ns) |
Configuration |
Type |
IOL (Max) (mA) |
IOH (Max) (mA) |
Rating |
Operating Temperature Range (C) |
Package Group |
Package Size: mm2:W x L (PKG) |
Bits (#) |
Digital input leakage (Max) (uA) |
ESD Charged Device Model (kV) |
ESD HBM (kV) |
CD74HCT4511 |
Decoder Demultiplexer |
HCT |
4.5 |
5.5 |
1 |
5 |
25 |
0.08 |
25 |
4:7 |
Standard |
4 |
-4 |
Catalog |
-55 to 125 |
PDIP |
See datasheet (PDIP) |
7 |
5 |
0.75 |
2 |
