TS5A3160器件是单刀双掷(SPDT)模拟开关,设计工作电压为1.65 V至5.5 V.该器件具有低电平导通电阻和良好的沟道到沟道导通电阻匹配。该器件具有出色的总谐波失真(THD)性能,功耗极低。这些功能使该设备适用于便携式音频应用。
所有商标均为其各自所有者的财产。
Configuration |
Number of Channels (#) |
Power Supply Type |
Vss (Min) (V) |
Vss (Max) (V) |
Vdd (Min) (V) |
Vdd (Max) (V) |
Ron (Typ) (Ohms) |
Bandwidth (MHz) |
Rating |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Supply Range (Max) |
Ron (Max) (Ohms) |
Input/Output Continuous Current (Max) (mA) |
Supply Current (Typ) (uA) |
Supply Current (Max) (uA) |
Features |
OFF-state leakage current (Max) (µA) |
ON-state leakage current (Max) (µA) |
Input/Output ON-state Capacitance (Typ) (pF) |
Input/Output OFF-state Capacitance (Typ) (pF) |
ESD Charged Device Model (kV) |
ESD HBM (kV) |
VIL (Max) (V) |
VIH (Min) (V) |
TS5A3160 | TS5A3159 | TS5A3159A | TS5A4624 |
2:1 SPDT | 2:1 SPDT | 2:1 SPDT | 2:1 SPDT |
1 | 1 | 1 | 1 |
Single | Single | Single | Single |
N/A | N/A | N/A | N/A |
1.65 | 1.65 | 1.65 | 1.65 |
5.5 | 5.5 | 5.5 | 5.5 |
0.7 | 0.75 | 0.7 | 0.5 |
105 | 100 | 100 | 90 |
Catalog | Catalog | Catalog | Catalog |
-40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
6SC70: 4 mm2: 2.1 x 2(SC70) 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 6SC70: 4 mm2: 2.1 x 2(SC70) 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (DSBGA) 6SC70: 4 mm2: 2.1 x 2(SC70) 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 6SC70: 4 mm2: 2.1 x 2(SC70) |
SC70 SOT-23 | SC70 SOT-23 | DSBGA SC70 SOT-23 | SC70 |
3.5 | 3.2 | 3.5 | 3.3 |
200 | 200 | 200 | 200 |
0.001 | 0.01 | 0.01 | |
0.5 | 0.1 | 0.5 | 1.2 |
Powered off protection Make-before-break | Break-before-make | Powered off protection Break-before-make | Powered off protection Break-before-make |
0.1 | 0.02 | 0.1 | 0.1 |
0.1 | 0.04 | 0.1 | 0.1 |
55 | 84 | 55 | 55 |
18 | 23 | 18 | 18 |
1 | 1 | 1 | 1 |
2 | 2 | 2 | 2 |
0.8 | 0.8 | 0.8 | 0.8 |
1.5 | 1.5 | 1.5 | 1.5 |
