数据: Dual Supply, Low ON-State Resistance SPST CMOS Analog Switches 数据表
TS12A4516 /TS12A4517是单刀单掷(SPST),低压,双电源CMOS模拟开关,具有极低的开关导通状态抵抗性。 TS12A4516常开(NO)。 TS12A4517常闭(NC)。
这些CMOS开关可以在±1 V和±6 V之间的双电源下连续工作[(2 V <(V + ?? V ?? )&lt; 12 V]。每个开关都可以处理轨到轨模拟信号。截止泄漏电流最大值在25°C时仅为5 nA或在85°时为10 nA °C。
对于与单电源配合使用的引脚兼容部件,请参见TS12A4514 /TS12A4515。
Configuration |
Number of Channels (#) |
Power Supply Type |
Vss (Min) (V) |
Vss (Max) (V) |
Vdd (Min) (V) |
Vdd (Max) (V) |
Ron (Typ) (Ohms) |
Bandwidth (MHz) |
Rating |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Supply Range (Max) |
Ron (Max) (Ohms) |
Input/Output Continuous Current (Max) (mA) |
Supply Current (Typ) (uA) |
Supply Current (Max) (uA) |
OFF-state leakage current (Max) (µA) |
ON-state leakage current (Max) (µA) |
Input/Output ON-state Capacitance (Typ) (pF) |
Input/Output OFF-state Capacitance (Typ) (pF) |
ESD Charged Device Model (kV) |
ESD HBM (kV) |
VIL (Max) (V) |
VIH (Min) (V) |
TS12A4516 | TS12A4514 | TS12A4515 | TS12A4517 |
1:1 SPST | 1:1 SPST | 1:1 SPST | 1:1 SPST |
1 | 1 | 1 | 1 |
Single Dual | Single | Single | Single Dual |
-5.5 | N/A | N/A | -5.5 |
-1.65 | N/A | N/A | -1.65 |
1.65 | 3 | 3 | 1.65 |
5.5 | 12.6 | 12.6 | 5.5 |
12 | 6.5 | 6.5 | 12 |
464 | 475 | 475 | 464 |
Catalog | Catalog | Catalog | Catalog |
-40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
8SOIC: 29 mm2: 6 x 4.9(SOIC) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (PDIP) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (PDIP) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) |
SOIC SOT-23 | PDIP SOIC SOT-23 | PDIP SOIC SOT-23 | SOIC SOT-23 |
11 | 12.6 | 12.6 | 11 |
47 | 50 | 50 | 47 |
20 | 20 | 20 | 20 |
20 | 0.03 | 20 | 250 |
80 | 0.2 | 80 | 500 |
0.01 | 0.01 | 0.01 | 0.01 |
14.5 | 19 | 19 | 14.5 |
5.5 | 7.5 | 7.5 | 5.5 |
1 | 1 | ||
2.5 | 2 | 2 | 2.5 |
Vdd -3.5 | 0.8 | 0.8 | Vdd -3.5 |
Vdd - 1.5 | 2.4 | 2.4 | Vdd - 1.5 |
