TS3A44159是一款双向4通道单刀双掷(SPDT)模拟开关,带有两个控制输入,设计工作电压为1.65 V该器件也称为2通道双刀双掷(DPDT)配置。它具有低导通电阻和出色的导通电阻,与先开后合功能相匹配,可防止信号从一个通道传输到另一个通道时发生信号失真。该器件具有出色的总谐波失真(THD)性能,功耗极低。这些功能使该器件适用于便携式音频应用
Configuration |
Number of Channels (#) |
Power Supply Type |
Vss (Min) (V) |
Vss (Max) (V) |
Vdd (Min) (V) |
Vdd (Max) (V) |
Ron (Typ) (Ohms) |
Bandwidth (MHz) |
Rating |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Supply Range (Max) |
Ron (Max) (Ohms) |
Input/Output Continuous Current (Max) (mA) |
Supply Current (Typ) (uA) |
Supply Current (Max) (uA) |
Features |
OFF-state leakage current (Max) (µA) |
ON-state leakage current (Max) (µA) |
Input/Output ON-state Capacitance (Typ) (pF) |
Input/Output OFF-state Capacitance (Typ) (pF) |
ESD Charged Device Model (kV) |
ESD HBM (kV) |
VIL (Max) (V) |
VIH (Min) (V) |
TS3A44159 |
2:1 SPDT |
4 |
Single |
N/A |
N/A |
1.65 |
4.3 |
0.3 |
35 |
Catalog |
-40 to 85 |
16TSSOP: 32 mm2: 6.4 x 5(TSSOP) 16UQFN: 5 mm2: 1.8 x 2.6(UQFN) 16VQFN: 9 mm2: 3 x 3(VQFN) |
TSSOP UQFN VQFN |
4.3 |
0.8 |
200 |
0 |
0.7 |
Break-before-make |
0.05 |
0.05 |
162 |
51 |
1 |
2 |
1 |
1 |
