数据: High-Speed CMOS Logic 16-Channel Analog Multiplexer and Demultiplexer 数据表
CD74HCT4067-Q1器件是一款数控模拟开关,采用硅栅CMOS技术实现与LSTTL类似的工作速度,功耗低标准CMOS集成电路。
该模拟多路复用器和多路分解器控制可能在电源范围内变化的模拟电压。它是双向开关,因此允许任何模拟输入用作输出,反之亦然。该开关具有低(导通)电阻和低(关)泄漏。此外,该器件还具有一个使能控制,当该电平为高电平时,禁止所有开关进入关闭状态。
Configuration |
Number of Channels (#) |
Power Supply Type |
Vss (Min) (V) |
Vss (Max) (V) |
Vdd (Min) (V) |
Vdd (Max) (V) |
Ron (Typ) (Ohms) |
Bandwidth (MHz) |
Rating |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Supply Range (Max) |
Ron (Max) (Ohms) |
Input/Output Continuous Current (Max) (mA) |
Supply Current (Typ) (uA) |
Supply Current (Max) (uA) |
Features |
OFF-state leakage current (Max) (µA) |
Input/Output ON-state Capacitance (Typ) (pF) |
Input/Output OFF-state Capacitance (Typ) (pF) |
ESD Charged Device Model (kV) |
ESD HBM (kV) |
VIL (Max) (V) |
VIH (Min) (V) |
CD74HCT4067-Q1 | CD74HCT4067 |
16:1 | 16:1 |
1 | 1 |
Single | Single |
N/A | N/A |
N/A | N/A |
4.5 | 4.5 |
5.5 | 5.5 |
70 | 60 |
89 | 89 |
Automotive | Catalog |
-40 to 125 -40 to 85 | -55 to 125 |
24SOIC: 160 mm2: 10.3 x 15.5(SOIC) | 24SOIC: 160 mm2: 10.3 x 15.5(SOIC) |
SOIC | SOIC |
5.5 | 5.5 |
225 | 270 |
25 | 25 |
8 | 8 |
80 | 80 |
Break-before-make | Break-before-make |
8 | 8 |
50 | 50 |
5 | 5 |
0.25 | |
0.4 | |
0.8 | 0.8 |
2 | 2 |
