数据: TS5A22364 0.65-Ω Dual SPDT Analog Switches With Negative Signaling Capability 数据表
TS5A22364是一款双向,双通道,单刀双掷(SPDT)模拟开关,设计工作电压范围为2.3 V至5.5 V.具有负信号功能,允许地下信号通过开关而不失真。此外,TS5A22364还包括一个内部分流开关,当它们未连接到COM时,它会自动释放NC或NO端子上的任何电容。这减少了两个声源之间的可听咔嗒声/砰砰声。先断后合功能可防止信号从一个路径传输到另一个路径时发生信号失真。低导通电阻,出色的通道到通道导通电阻匹配以及最小的总谐波失真(THD)性能是音频应用的理想选择。 3.00 mm x 3.00 mm DRC封装也可用于医疗成像应用的非磁性封装。
所有商标均为其各自所有者的财产。
Configuration |
Number of Channels (#) |
Power Supply Type |
Vss (Min) (V) |
Vss (Max) (V) |
Vdd (Min) (V) |
Vdd (Max) (V) |
Ron (Typ) (Ohms) |
Bandwidth (MHz) |
Rating |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Supply Range (Max) |
Ron (Max) (Ohms) |
Input/Output Continuous Current (Max) (mA) |
Supply Current (Typ) (uA) |
Supply Current (Max) (uA) |
Features |
OFF-state leakage current (Max) (µA) |
ON-state leakage current (Max) (µA) |
Input/Output ON-state Capacitance (Typ) (pF) |
Input/Output OFF-state Capacitance (Typ) (pF) |
ESD Charged Device Model (kV) |
ESD HBM (kV) |
VIL (Max) (V) |
VIH (Min) (V) |
TS5A22364 | TS5A22362 | TS5A22364-Q1 | TS5A22366 |
2:1 SPDT | 2:1 SPDT | 2:1 SPDT | 2:1 SPDT |
2 | 2 | 2 | 2 |
Single | Single | Single | Single |
N/A | N/A | N/A | N/A |
2.3 | 2.3 | 2.3 | 2.25 |
5.5 | 5.5 | 5.5 | 5.5 |
0.52 | 0.52 | 0.52 | 0.7 |
18.3 | 18.3 | 18.3 | 32 |
Catalog | Catalog | Automotive | Catalog |
-40 to 85 | -40 to 85 | -40 to 125 | -40 to 85 |
See datasheet (DSBGA) 10VSON: 9 mm2: 3 x 3(VSON) 10VSSOP: 15 mm2: 4.9 x 3(VSSOP) | See datasheet (DSBGA) 10VSON: 9 mm2: 3 x 3(VSON) 10VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 10VSSOP: 15 mm2: 4.9 x 3(VSSOP) | See datasheet (DSBGA) |
DSBGA VSON VSSOP | DSBGA VSON VSSOP | VSSOP | DSBGA |
1.3 | 1.3 | 1.3 | 2 |
350 | 350 | 150 | 150 |
0.1 | 0.1 | 6 | 1 |
5 | 5 | 14 | 10 |
Break-before-make Supports negative voltages Click/Pop Noise Reduction | Supports negative voltages | Break-before-make Supports negative voltages | Break-before-make Supports negative voltages |
0.375 | 0.375 | ||
0.375 | 0.375 | 0.375 | 0.375 |
370 | 370 | 370 | 176 |
70 | 48 | ||
1.5 | 1.5 | 1.5 | 1 |
2.5 | 2.5 | 2.5 | 2.5 |
0.8 | 0.8 | 0.8 | 0.65 |
1.4 | 1.4 | 1.4 | 1.05 |
