数据: TS12A4451x Low ON-State Resistance 4-Channel SPST CMOS Analog Switches 数据表
TS12A44513,TS12A44514和TS12A44515器件具有四个双向单刀单掷(SPST)单电源CMOS模拟开关。 TS12A44513有两个常闭(NC)开关和两个常开(NO)开关,TS12A44514有四个NO开关,TS12A44515有四个NC开关。
这些CMOS开关可以连续运行一个提供2 V至12 V电压,可处理轨到轨模拟信号。 OFF漏电流最大值在25°C时仅为1 nA或在85°C时为10 nA。
使用5 V电源时,所有数字输入均具有0.8 V至2.4 V逻辑阈值,确保TTL /CMOS逻辑兼容性。
Configuration |
Number of Channels (#) |
Power Supply Type |
Vss (Min) (V) |
Vss (Max) (V) |
Vdd (Min) (V) |
Vdd (Max) (V) |
Ron (Typ) (Ohms) |
Bandwidth (MHz) |
Rating |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Supply Range (Max) |
Ron (Max) (Ohms) |
Input/Output Continuous Current (Max) (mA) |
Supply Current (Typ) (uA) |
Supply Current (Max) (uA) |
OFF-state leakage current (Max) (µA) |
ON-state leakage current (Max) (µA) |
Input/Output ON-state Capacitance (Typ) (pF) |
Input/Output OFF-state Capacitance (Typ) (pF) |
ESD Charged Device Model (kV) |
ESD HBM (kV) |
VIL (Max) (V) |
VIH (Min) (V) |
TS12A44514 | TS12A44513 | TS12A44515 |
1:1 SPST | 1:1 SPST | 1:1 SPST |
4 | 4 | 4 |
Single | Single | Single |
N/A | N/A | N/A |
N/A | N/A | N/A |
2 | 2 | 2 |
12 | 12 | 12 |
6.5 | 6.5 | 6.5 |
530 | 530 | 530 |
Catalog | Catalog | Catalog |
-40 to 85 | -40 to 85 | -40 to 85 |
14SOIC: 52 mm2: 6 x 8.65(SOIC) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | 14SOIC: 52 mm2: 6 x 8.65(SOIC) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | 14SOIC: 52 mm2: 6 x 8.65(SOIC) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) |
SOIC TSSOP | SOIC TSSOP | SOIC TSSOP |
12 | 12 | 12 |
50 | 50 | 50 |
20 | 20 | 20 |
0.05 | 0.05 | 0.03 |
0.2 | 0.2 | 0.2 |
0.01 | 0.01 | 0.01 |
19 | 19 | 19 |
8 | 8 | 8 |
0.5 | 0.5 | 0.5 |
2 | 2 | 2 |
0.8 | 0.8 | 0.8 |
2.4 | 2.4 | 2.4 |
