数据: TS12A12511 5-Ω Single-Channel SPDT Analog Switch With Negative Signaling Capability 数据表
TS12A12511是一款双向,单通道,单刀双掷(SPDT)模拟开关,可以传递0至12 V摆幅的信号或者?? 6 V至6 V.当开关打开时,该开关在两个方向上的导电性能相同。该器件还提供5Ω(典型值)的低导通电阻,在通道之间匹配1Ω以内。最大电流消耗<1μA,Δω3dB带宽> 93MHz。 TS12A12511具有先开后合式开关动作,可防止切换通道时发生瞬间短路。该器件采用8引脚VSSOP封装,8引脚SOT-23封装和8引脚WSON封装。
Configuration |
Number of Channels (#) |
Power Supply Type |
Vss (Min) (V) |
Vss (Max) (V) |
Vdd (Min) (V) |
Vdd (Max) (V) |
Ron (Typ) (Ohms) |
Bandwidth (MHz) |
Rating |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Supply Range (Max) |
Ron (Max) (Ohms) |
Input/Output Continuous Current (Max) (mA) |
Supply Current (Typ) (uA) |
Supply Current (Max) (uA) |
OFF-state leakage current (Max) (µA) |
ON-state leakage current (Max) (µA) |
Input/Output ON-state Capacitance (Typ) (pF) |
Input/Output OFF-state Capacitance (Typ) (pF) |
ESD Charged Device Model (kV) |
ESD HBM (kV) |
VIL (Max) (V) |
VIH (Min) (V) |
TS12A12511 |
2:1 SPDT |
1 |
Single Dual |
-6 |
0 |
0 |
12 |
5 |
152 |
Catalog |
-40 to 85 |
See datasheet (SON) 8SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) |
SON SOT-23 VSSOP |
12 |
12.5 |
50 |
0.05 |
0.2 |
0.05 |
0.05 |
55 |
15 |
1 |
2 |
0.8 |
2.4 |
