数据: TS3A24157 0.65-Ω 2-Channel SPDT Analog Switch 2-Channel 2:1 Multiplexer and Demultiplexer 数据表
TS3A24157是一款双向,双通道,单刀双掷(SPDT)模拟开关,设计工作电压为1.65 V至3.6 V该器件具有低导通电阻和出色的导通电阻,与先开后合功能相匹配,可防止信号从一个通道传输到另一个通道时发生信号失真。该器件具有出色的总谐波失真(THD)性能,功耗极低。这些功能使该器件适用于便携式音频应用。
Configuration |
Number of Channels (#) |
Power Supply Type |
Vss (Min) (V) |
Vss (Max) (V) |
Vdd (Min) (V) |
Vdd (Max) (V) |
Ron (Typ) (Ohms) |
Bandwidth (MHz) |
Rating |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Supply Range (Max) |
Ron (Max) (Ohms) |
Input/Output Continuous Current (Max) (mA) |
Supply Current (Typ) (uA) |
Supply Current (Max) (uA) |
Features |
OFF-state leakage current (Max) (µA) |
ON-state leakage current (Max) (µA) |
Input/Output ON-state Capacitance (Typ) (pF) |
Input/Output OFF-state Capacitance (Typ) (pF) |
ESD Charged Device Model (kV) |
ESD HBM (kV) |
VIL (Max) (V) |
VIH (Min) (V) |
TS3A24157 | TS3A24159 |
2:1 SPDT | 2:1 SPDT |
2 | 2 |
Single | Single |
N/A | N/A |
N/A | N/A |
1.65 | 1.65 |
3.6 | 3.6 |
0.45 | 0.26 |
50 | 23 |
Catalog | Catalog |
-40 to 85 | -40 to 85 |
10UQFN: 3 mm2: 2 x 1.5(UQFN) 10VSSOP: 15 mm2: 4.9 x 3(VSSOP) | See datasheet (DSBGA) 10VSON: 9 mm2: 3 x 3(VSON) 10VSSOP: 15 mm2: 4.9 x 3(VSSOP) |
UQFN VSSOP | DSBGA VSON VSSOP |
3.6 | 3.6 |
1 | 0.5 |
300 | 300 |
0.01 | 0.01 |
1 | 50 |
Break-before-make | Break-before-make |
0.25 | 0.05 |
0.4 | 0.1 |
140 | 250 |
50 | 90 |
1 | 1 |
2 | 2 |
0.5 | 0.5 |
1 | 1 |
