The TS3V330 video switch is a 4-bit 1-of-2 multiplexer/demultiplexer, with a single switch-enable (EN) input. When EN is low, the switch is enabled and the D port is connected to the S port. When EN is high, the switch is disabled and the high-impedance state exists between the D and S ports. The select (IN) input controls the data path of the multiplexer/demultiplexer.
Low differential gain and phase make this switch ideal for composite and RGB video applications. This device has wide bandwidth and low crosstalk, making it suitable for high-frequency applications as well.
This device is fully specified for partial-power-down applications using Ioff. The Ioff feature ensures that damaging current will not backflow through the device when it is powered down. This switch maintains isolation during power off.
To ensure the high-impedance state during power up or power down, EN should be tied to VCC through a pullup resistor; the minimum value of the resistor is determined by the current-sinking capability of the driver.
Protocols |
Configuration |
Number of Channels (#) |
VCC (Min) (V) |
VCC (Max) (V) |
Ron (Typ) (Ohms) |
Input/Ouput Voltage (Min) (V) |
Input/Ouput Voltage (Max) (V) |
ICC (Max) (uA) |
Bandwidth (MHz) |
ESD HBM (Typ) (kV) |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Crosstalk (dB) |
ESD Charged Device Model (kV) |
ICC (Typ) (uA) |
Input/Output Continuous Current (Max) (mA) |
Input/Output OFF-state Capacitance (Typ) (pF) |
Input/Output ON-state Capacitance (Typ) (pF) |
Off Isolation (Typ) (dB) |
OFF-state leakage current (Max) (µA) |
Ron (Max) (Ohms) |
Turn off Time (Disable) (Max) (ns) |
Turn on Time (Enable) (Max) (ns) |
VIH (Min) (V) |
VIL (Max) (V) |
TS3V330 |
RGB Composite |
2:1 SPDT |
4 |
3 |
3.6 |
5 |
0 |
3.6 |
10 |
300 |
2 |
-40 to 85 |
16SOIC: 59 mm2: 6 x 9.9(SOIC) 16SSOP: 29 mm2: 6 x 4.9(SSOP) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) 16TVSOP: 23 mm2: 6.4 x 3.6(TVSOP) 16VQFN: 14 mm2: 3.5 x 4(VQFN) |
SOIC SSOP TSSOP TVSOP VQFN |
-80 |
1 |
10 |
128 |
10 |
17 |
-50 |
1 |
10 |
3.5 |
6.5 |
2 |
0.8 |
