数据: TS3DV520E 5-Channel Differential 10:20 Multiplexer Switch 数据表
TS3DV520E是一款20位至10位多路复用器/多路分解器数字视频开关,具有单选(SEL)输入。 SEL控制多路复用器/多路分解器的数据路径。该器件提供五个差分通道用于数字视频信号切换。
该器件提供低和平的导通电阻(r on )和出色的导通电阻匹配。低输入/输出电容,高带宽,低偏斜和通道间低串扰使该器件适用于各种数字视频应用,如DVI和HDMI。
SEL引脚上的电压应小于或等于至V CC ,即使在掉电模式下(V CC = 0 V)。
Protocols |
Configuration |
Number of Channels (#) |
VCC (Min) (V) |
VCC (Max) (V) |
Ron (Typ) (Ohms) |
Input/Ouput Voltage (Min) (V) |
Input/Ouput Voltage (Max) (V) |
ICC (Max) (uA) |
Bandwidth (MHz) |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Crosstalk (dB) |
ESD Charged Device Model (kV) |
ICC (Typ) (uA) |
Input/Output Continuous Current (Max) (mA) |
Input/Output OFF-state Capacitance (Typ) (pF) |
Input/Output ON-state Capacitance (Typ) (pF) |
OFF-state leakage current (Max) (µA) |
Propagation Delay (ns) |
Ron (Max) (Ohms) |
Ron Channel Match (Max) (Ω) |
RON Flatness (Typ) (Ohms) |
Turn off Time (Disable) (Max) (ns) |
Turn on Time (Enable) (Max) (ns) |
VIH (Min) (V) |
VIL (Max) (V) |
TS3DV520E | TS3DV520 |
HDMI DVI LVDS TMDS VGA SXGA |
2:1 SPDT | 2:1 SPDT |
10 | 10 |
3 | 3 |
3.6 | 3.6 |
4 | 3.5 |
0 | 0 |
3.6 | 5.5 |
600 | 500 |
950 | 1200 |
-40 to 85 | |
42WQFN: 32 mm2: 3.5 x 9(WQFN) | 56WQFN: 55 mm2: 5 x 11(WQFN) |
WQFN | WQFN |
-90 | -90 |
7.5 | 1 |
250 | |
128 | 128 |
9 | 7.8 |
3 | 3 |
1 | |
0.25 | 0.25 |
8 | 6 |
1.2 | 1 |
0.7 | 0.5 |
9 | 9 |
15 | 15 |
2 | 2 |
0.8 | 0.8 |
型号:TS3DV520ERUAR 封装:WFQFN42_9X3.5MM_EP
品牌:TI 描述:视频开关 IC 串行 HDMI 1.2a,IEC 61000-4-2 42-WQFN (3.5x9.0) 封装
金额:¥7.00930
去购买
