TS2DDR2811是一款8通道单刀单掷(SPST)信号开关,能够切换带宽超过1 GHz的信号。该器件包含一个选择引脚(SEL),用于选择8个通道输入中的任何一个。该选择引脚控制SPST开关的数据路径。该器件提供低而平坦的导通电阻(r ON )和出色的导通电阻匹配。低输入/输出电容,高带宽,低偏斜和通道间低串扰使该器件适用于各种高带宽应用,如DDR2,10 /100/1000 Base-T,音频和视频。
Protocols |
Configuration |
Number of Channels (#) |
VCC (Min) (V) |
VCC (Max) (V) |
Ron (Typ) (Ohms) |
Input/Ouput Voltage (Min) (V) |
Input/Ouput Voltage (Max) (V) |
ICC (Max) (uA) |
Bandwidth (MHz) |
ESD HBM (Typ) (kV) |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Crosstalk (dB) |
ESD Charged Device Model (kV) |
ICC (Typ) (uA) |
Input/Output Continuous Current (Max) (mA) |
Input/Output OFF-state Capacitance (Typ) (pF) |
Input/Output ON-state Capacitance (Typ) (pF) |
OFF-state leakage current (Max) (µA) |
Propagation Delay (ns) |
Ron (Max) (Ohms) |
Ron Channel Match (Max) (Ω) |
RON Flatness (Typ) (Ohms) |
Turn off Time (Disable) (Max) (ns) |
Turn on Time (Enable) (Max) (ns) |
VIH (Min) (V) |
VIL (Max) (V) |
TS2DDR2811 | TS3DDR3812 |
DDR2 | DDR3 |
1:1 SPST | 2:1 SPDT |
8 | 12 |
3 | 3 |
3.6 | 3.6 |
4 | 8 |
0 | 0 |
3.6 | 3.6 |
500 | 400 |
1100 | 1675 |
2 | 2 |
-40 to 85 | -40 to 85 |
20BGA MICROSTAR JUNIOR: 8 mm2: 3 x 2.5(BGA MICROSTAR JUNIOR) | 42WQFN: 32 mm2: 3.5 x 9(WQFN) |
BGA MICROSTAR JUNIOR | WQFN |
-71 | |
1 | 1 |
250 | |
128 | 128 |
2.5 | 5.6 |
4 | 2 |
1 | |
0.04 | 0.04 |
6 | 12 |
1 | 1 |
0.5 | 1.5 |
9 | 5 |
15 | 7 |
2 | 2 |
0.8 | 0.8 |
