数据: 2-Gbps Differential SWITCH 8-Bits, 1: 2 MUX/DEMUX With 3-Side Band Signals 数据表
TS3DV20812是高达2Gbps的高速数据速率,用于差分信号无源双向多路复用器和解复用器,用于高达5V电平的I /O电压轨低串扰和插入损耗。
TS3DV20812可用于HDMI /DVI接收器侧或源侧,带有支持高速和控制引脚的4差分对。
Ioff和后驱动保护允许连接外部电缆,并在Vcc为0V时防止回流电流。
3个边带信号可用于DDC(SDAL,SCL)和CEC信号MUX。 /p>
TS3DS20812的特点是在40°C至85°C的温度范围内工作。
Protocols |
Configuration |
Number of Channels (#) |
VCC (Min) (V) |
VCC (Max) (V) |
Ron (Typ) (Ohms) |
Input/Ouput Voltage (Min) (V) |
Input/Ouput Voltage (Max) (V) |
ICC (Max) (uA) |
Bandwidth (MHz) |
ESD HBM (Typ) (kV) |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Crosstalk (dB) |
ESD Charged Device Model (kV) |
ICC (Typ) (uA) |
Input/Output Continuous Current (Max) (mA) |
Input/Output OFF-state Capacitance (Typ) (pF) |
Input/Output ON-state Capacitance (Typ) (pF) |
OFF-state leakage current (Max) (µA) |
Propagation Delay (ns) |
Ron (Max) (Ohms) |
Ron Channel Match (Max) (Ω) |
RON Flatness (Typ) (Ohms) |
Turn off Time (Disable) (Max) (ns) |
Turn on Time (Enable) (Max) (ns) |
VIH (Min) (V) |
VIL (Max) (V) |
TS3DV20812 | TS3DV416 | TS3L4892 |
HDMI DVI LVD VGA LAN |
HDMI DVI LVDS |
10 BASE-T 100 BASE-T 1000 BASE-T LVDS LAN |
2:1 SPDT | 2:1 SPDT | 2:1 SPDT |
11 | 8 | 11 |
2.25 | 3 | 3 |
3.6 | 3.6 | 3.6 |
4 | 4 | 4 |
0 | 0 | 0 |
5.5 | 5.5 | 3.6 |
500 | 600 | 500 |
1100 | 900 | 1100 |
2 | 2 | 2 |
-40 to 85 | -40 to 85 | -40 to 85 |
36VQFN: 36 mm2: 6 x 6(VQFN) |
48TSSOP: 101 mm2: 8.1 x 12.5(TSSOP) 48TVSOP: 62 mm2: 6.4 x 9.7(TVSOP) |
VQFN |
TSSOP TVSOP |
VQFN |
-95 | -41 | |
1 | 1 | 1 |
250 | 250 | |
128 | 128 | 128 |
8 | 3.5 | 2.5 |
2.5 | 10 | 8 |
1 | 1 | |
0.149 | 0.04 | 0.04 |
6 | 8 | 6 |
1 | 0.2 | 1 |
0.4 | 0.7 | 0.5 |
18 | 8.5 | 9 |
17 | 11.5 | 15 |
2 | 2 | 2 |
0.8 | 0.8 | 0.8 |
