数据: 7-CHANNEL, 1:2 VIDEO SWITCH WITH INTEGRATED LEVEL SHIFTERS 数据表
The TS3V713EL is a high bandwidth, 7-channel video multiplexer/demultiplexer for switching between a single VGA source and one of two end points. The device is designed for ensuring video signal integrity and minimizing video signal attenuation by providing high bandwidth of 1.3 GHz.
The TS3V713EL has integrated level shifting buffers for the HSYNC and VSYNC signals which provide voltage level translation between 3.3V and 5V logic. The SCL and SDA lines use NMOS switches which clamp the output voltage to 1 V below VDD.
The video signals are protected against ESD with integrated diodes to VDD and GND that support levels up to ±2 kV Contact Discharge (IEC61000-4-2) and 8 kV Human Body Model (JESD22-A114E).
Protocols |
Configuration |
Number of Channels (#) |
VCC (Min) (V) |
VCC (Max) (V) |
Ron (Typ) (Ohms) |
Input/Ouput Voltage (Min) (V) |
Input/Ouput Voltage (Max) (V) |
ICC (Max) (uA) |
Bandwidth (MHz) |
ESD HBM (Typ) (kV) |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Crosstalk (dB) |
ESD Charged Device Model (kV) |
ICC (Typ) (uA) |
Input/Output Continuous Current (Max) (mA) |
Input/Output OFF-state Capacitance (Typ) (pF) |
Input/Output ON-state Capacitance (Typ) (pF) |
OFF-state leakage current (Max) (µA) |
Propagation Delay (ns) |
Ron (Max) (Ohms) |
Ron Channel Match (Max) (Ω) |
RON Flatness (Typ) (Ohms) |
Turn off Time (Disable) (Max) (ns) |
Turn on Time (Enable) (Max) (ns) |
VIH (Min) (V) |
VIL (Max) (V) |
TS3V713EL | TS3V712EL |
RGB Composite VGA |
RGB Composite VGA |
2:1 SPDT | 2:1 SPDT |
7 | 7 |
3 | 3 |
5.5 | 5.5 |
3 | 3 |
3 | 0 |
5.5 | 5.5 |
550 | 500 |
1300 | 1300 |
7 | |
-40 to 85 | -40 to 85 |
32WQFN: 18 mm2: 3 x 6(WQFN) | 32WQFN: 18 mm2: 3 x 6(WQFN) |
WQFN | WQFN |
-95 | |
2 | 2 |
200 | |
128 | 128 |
8 | 3 |
2.5 | 8 |
1 | 1 |
0.25 | 0.25 |
8 | 6 |
1 | 1 |
0.2 | 0.2 |
13 | 13 |
11 | 13 |
2 | 2 |
0.8 | 0.8 |
