数据: 7-CHANNEL, 1:2 VIDEO SWITCH WITH INTEGRATED LEVEL SHIFTERS 数据表
TS3V712EL是一款高带宽7通道视频多路分解器,用于在单个VGA信号源和两个端点之一之间切换。该器件旨在通过提供1.3 GHz的高带宽来确保视频信号完整性并最大限度地减少视频信号衰减。
TS3V712EL具有用于H SYNC 和V <的集成电平转换缓冲器sub> SYNC 信号,提供3.3 V和5 V逻辑电压电平转换。 SCL和SDA线使用NMOS开关,将输出电压钳位到低于V DD 的1 V。
视频信号通过集成二极管保护ESD,保护V DD 和GND,支持高达±2kV的接触放电(IEC61000-4-2)和7kV人体模型(JESD22-A114E)。
Protocols |
Configuration |
Number of Channels (#) |
VCC (Min) (V) |
VCC (Max) (V) |
Ron (Typ) (Ohms) |
Input/Ouput Voltage (Min) (V) |
Input/Ouput Voltage (Max) (V) |
ICC (Max) (uA) |
Bandwidth (MHz) |
ESD HBM (Typ) (kV) |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Crosstalk (dB) |
ESD Charged Device Model (kV) |
ICC (Typ) (uA) |
Input/Output Continuous Current (Max) (mA) |
Input/Output OFF-state Capacitance (Typ) (pF) |
Input/Output ON-state Capacitance (Typ) (pF) |
OFF-state leakage current (Max) (µA) |
Propagation Delay (ns) |
Ron (Max) (Ohms) |
Ron Channel Match (Max) (Ω) |
RON Flatness (Typ) (Ohms) |
Turn off Time (Disable) (Max) (ns) |
Turn on Time (Enable) (Max) (ns) |
VIH (Min) (V) |
VIL (Max) (V) |
TS3V712EL | TS3V713EL |
RGB Composite VGA |
RGB Composite VGA |
2:1 SPDT | 2:1 SPDT |
7 | 7 |
3 | 3 |
5.5 | 5.5 |
3 | 3 |
0 | 3 |
5.5 | 5.5 |
500 | 550 |
1300 | 1300 |
7 | |
-40 to 85 | -40 to 85 |
32WQFN: 18 mm2: 3 x 6(WQFN) | 32WQFN: 18 mm2: 3 x 6(WQFN) |
WQFN | WQFN |
-95 | |
2 | 2 |
200 | |
128 | 128 |
3 | 8 |
8 | 2.5 |
1 | 1 |
0.25 | 0.25 |
6 | 8 |
1 | 1 |
0.2 | 0.2 |
13 | 13 |
13 | 11 |
2 | 2 |
0.8 | 0.8 |
