数据: TS3DV642 具有 1.8V 兼容控制和断电模式的 12 通道 1:2多路复用器/多路解复用器 数据表 (Rev. E)
TS3DV642是一款12通道1:2或2:1双向多路复用器/多路解复用器.TS3DV642可由2.6V至4.5V的电源供电,适用于电池供电。应用。该器件的导通电阻(R ON )较低并且I /O电容较小,能够实现典型值高达7.5GHz的带宽。该器件可为HDMI和DisplayPort应用提供所需的高带宽。
TS3DV642具有断电模式,该模式下所有通道均具有高阻抗(Hi-Z),并且功耗极低。< /p>
<小>所有商标是其相应所有者的财产。
Protocols |
Configuration |
Number of Channels (#) |
VCC (Min) (V) |
VCC (Max) (V) |
Ron (Typ) (Ohms) |
Input/Ouput Voltage (Min) (V) |
Input/Ouput Voltage (Max) (V) |
ICC (Max) (uA) |
Bandwidth (MHz) |
ESD HBM (Typ) (kV) |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Crosstalk (dB) |
ESD Charged Device Model (kV) |
ICC (Typ) (uA) |
Input/Output Continuous Current (Max) (mA) |
Input/Output OFF-state Capacitance (Typ) (pF) |
Input/Output ON-state Capacitance (Typ) (pF) |
Off Isolation (Typ) (dB) |
OFF-state leakage current (Max) (µA) |
Propagation Delay (ns) |
Ron (Max) (Ohms) |
Ron Channel Match (Max) (Ω) |
RON Flatness (Typ) (Ohms) |
Turn off Time (Disable) (Max) (ns) |
Turn on Time (Enable) (Max) (ns) |
VIH (Min) (V) |
VIL (Max) (V) |
TS3DV642 | TS3DV621 |
HDMI DVI DisplayPort TMDS LVDS VGA |
HDMI DVI DisplayPort TMDS LVDS |
2:1 SPDT | 2:1 SPDT |
12 | 12 |
2.6 | 3 |
4.5 | 3.6 |
6.5 | 8 |
0 | 0 |
5.5 | 5.5 |
400 | |
7500 | 2200 |
2 | |
-40 to 85 | |
42WQFN: 32 mm2: 3.5 x 9(WQFN) | 42WQFN: 32 mm2: 3.5 x 9(WQFN) |
WQFN | WQFN |
-98 | -70 |
1 | 1 |
50 | 300 |
128 | 128 |
0.5 | 5.6 |
0.3 | 2 |
-40 | |
10 | 1 |
0.03 | 0.04 |
10.5 | 12 |
1 | 1 |
1.5 | 1.5 |
5 | |
7 | |
1.4 | 2 |
0.5 | 0.8 |
型号:TS3DV642A0RUAR 封装:WQFN42_EP
品牌:TI 描述:用于DVI 1.0/显示端口1.4/HDMI 2.0的6 Gbps 12通道差分1对2和2对1多路复用器
金额:¥3.25892
去购买
