TSU6111支持阻抗检测的差分高性能自动SP2T开关。这个开关特有阻抗检测,这一功能能够检测通过DP和DM附件的多种配件。充电器检测满足USB充电器规范v1.1。V BUS_IN 支持28V允差差电压以避免外部保护。
这个设备通过附加的V BAT < /sub>或者V BUS_IN 进行供电。
此开关有自动检测逻辑控制或者通过I 2 C接口手动控制。当USB,UART JIG线缆在开发和制造期间被用来进行测试时,JIG和BOOT针脚启用.TSU6111支持开漏JIG输出(低电平有效)。
Device Type |
Number of Channels (#) |
Configuration |
VCC (Min) (V) |
VCC (Max) (V) |
Ron (Typ) (Ohms) |
Input/Ouput Voltage (Min) (V) |
Input/Ouput Voltage (Max) (V) |
ICC (Max) (uA) |
Bandwidth (MHz) |
ESD HBM (Typ) (kV) |
Features |
Rating |
Operating Temperature Range (C) |
Package Group |
Package Size: mm2:W x L (PKG) |
Pin/Package |
TSU6111 | TSU5511 | TSU5611 | TSU6111A | TSU6712 | TSU6721 | TSU8111 |
USB/MHL Switch | USB/MHL Switch | USB/MHL Switch | USB/MHL Switch | USB/MHL Switch | USB/MHL Switch | |
2 | 2 | 2 | 2 | 2 | 2 | 2 |
1:2 SPDT | 1:3 SP3T | 1:3 SP3T | 1:2 SPDT | 1:4 SP4T | 1:3 SP3T | 1:2 SPDT |
3 | 2.8 | 2.8 | 3 | 3 | 3 | 1.65 |
6.5 | 6.7 | 6.7 | 6.5 | 6.5 | 6.5 | 6.5 |
8 | 4.5 | 4.5 | 8 | 8 | 6 | 8 |
0 | -1.3 | 0 | -0.8 | -1.5 | 0 | |
3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | |
75 | 70 | See data sheet | 75 | 600 | 155 | 150 |
920 | 830 | 830 | 920 | 510 | 510 | 820 |
2 | 2 | 1.5 | 5 | 1.5 | 4 | 12 |
USB 2.0 UART BCv1.1 Charger Detection I2C Interface JIG and BOOT Support Attach and Detach Interrupt Surge Protection |
USB 2.0 UART Audio Switch (Negative Rail Capability) Click-Pop Reduction Charging Capability I2C Interface Impedance Detection |
USB 2.0 Audio Switch (Negative Rail Capability) Integrated LDO Impedance Detection |
Audio Switch (Negative Rail Capability) Charging Capability I2C Interface JIG and BOOT Support Impedance Detection |
USB 2.0 UART Audio Switch (Negative Rail Capability) ID Bypass Switch Charging Capability BCv1.2 Charger Detection I2C Interface JIG and BOOT Support Impedance Detection Attach and Detach Interrupt |
USB 2.0 Integrated Single-Cell Charger BCv1.1 Charger Detection Impedance Detection Thermal Regulation and Shutdown |
Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
-40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
UQFN | DSBGA | DSBGA | UQFN | DSBGA | DSBGA | DSBGA |
16UQFN: 5 mm2: 1.8 x 2.6(UQFN) | See datasheet (DSBGA) | See datasheet (DSBGA) | 16UQFN: 5 mm2: 1.8 x 2.6(UQFN) | See datasheet (DSBGA) | See datasheet (DSBGA) | See datasheet (DSBGA) |
16UQFN | 20DSBGA | 20DSBGA | 16UQFN | 25DSBGA | 25DSBGA | 20DSBGA |
