数据: TS3USB3000 DPDT USB 2.0 高速和移动高清链路 (MHL) 6.1GHz 开关 数据表 (Rev. D)
TS3USB3000器件是一款双刀双掷(DPDT)多路复用器,在同一封装内包含一个高速移动高清链接(MHL)开关和一个USB 2.0高速(480Mbps)开关。这些配置使得系统设计人员能够为MHL视频信号和USB数据使用一个普通USB或者微型USB连接器。
TS3USB3000的V CC 范围为2.3V至4.8V,支持过压容量(OVT)功能,允许I /O引脚承受过压条件(最高可达5.5V)。掉电保护功能可在掉电时强制所有I /O引脚进入高阻抗模式,从而将信号线完全隔离,免受过量泄漏电流的影响.TS3USB3000的选择引脚与1.8V控制电压兼容,允许其直接与移动处理器的通用I /O(GPIO) )相连。
TS3USB3000采用小型10引脚UQFN封装,尺寸仅为1.5mm×2mm,是移动应用的理想之选低功耗是一个关键问题。
所有商标均为其各自所有者的财产。
Device Type |
Number of Channels (#) |
Configuration |
VCC (Min) (V) |
VCC (Max) (V) |
Ron (Typ) (Ohms) |
Input/Ouput Voltage (Min) (V) |
Input/Ouput Voltage (Max) (V) |
ICC (Max) (uA) |
Bandwidth (MHz) |
ESD HBM (Typ) (kV) |
Features |
Rating |
Operating Temperature Range (C) |
Package Group |
Package Size: mm2:W x L (PKG) |
Pin/Package |
TS3USB3000 | TS3USB3031 | TS3USB3200 | TS3USBCA4 | TS5USBC400 | TS5USBC402 | TS5USBC41 |
USB/MHL Switch | USB/MHL Switch | USB/MHL Switch | Multiplexer | USB/MHL Switch | USB/MHL Switch | |
2 | 2 | 2 | 3 | 2 | 2 | 2 |
2:1 SPDT | 3:1 | 2:1 SPDT | Multiplexer with MIC/AGND | Dual 2:1 | Dual 2:1 | Dual 2:1 |
2.7 | 2.5 | 2.7 | 2.4 | 2.3 | 2.3 | 2.3 |
4.3 | 4.3 | 4.3 | 5.5 | 5.5 | 5.5 | 5.5 |
4.6 | 4.5 | 4.6 | 5 | 5.6 | 5.6 | 5.6 |
0 | 0 | 0 | 0 | 0 | 0 | 0 |
3.6 | 3.6 | 3.6 | 5.5 | 18 | 20 | 18 |
50 | 40 | 70 | 70 | 100 | 100 | 22 |
6100 | 6500 | 5500 | 500 | 1200 | 1200 | 1200 |
3.5 | 2 | 3.5 | 2 | 2 | 2 | 2 |
USB 2.0 Mobile High-Definition Link (MHL) Over-Voltage Tolerance (OVT) Current Leakage Protection Logic Controlled (Output Enabled) |
USB 2.0 Mobile High-Definition Link (MHL) Over-Voltage Tolerance (OVT) Current Leakage Protection Flexible Power Control Logic Controlled (Output Enabled) |
SBU Multiplexer with MIC/AGND | 16V Over Voltage Protection | 20V Over Voltage Protection |
20V Over Voltage Protection Very low power consumption |
Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
-40 to 85 | -40 to 85 | -40 to 85 | 0 to 70 |
-40 to 85 0 to 70 |
-40 to 85 0 to 70 |
-40 to 85 0 to 70 |
UQFN | WQFN | UQFN | UQFN | DSBGA | DSBGA | DSBGA |
10UQFN: 3 mm2: 2 x 1.5(UQFN) | 12WQFN: 3 mm2: 1.8 x 1.8(WQFN) | 16UQFN: 5 mm2: 1.8 x 2.6(UQFN) | 16UQFN: 5 mm2: 1.8 x 2.6(UQFN) | See datasheet (DSBGA) | See datasheet (DSBGA) | See datasheet (DSBGA) |
10UQFN | 12WQFN | 16UQFN | 16UQFN | 12DSBGA | 12DSBGA | 12DSBGA |
