LM56 双路输出温度开关
数据:
LM56是一款精密低功耗恒温器。通过使用3个外部电阻分压LM56 1.250V带隙电压基准,可以产生两个稳定的温度跳变点(V T1 和V T2 )。 LM56有两个数字输出。当温度超过T1时,OUT1变为低电平,当温度低于T1时,OUT1变为高电平(T1-T HYST )。类似地,当温度超过T2时OUT2变为低电平,当温度低于T2时变为高电平(T2-T HYST )。 T HYST 是内部设置的5°C典型迟滞。
LM56采用8引脚VSSOP表面贴装封装和8引脚SOIC封装。
特性
  • 数字输出支持TTL逻辑电平
  • 内部温度传感器
  • 2具有迟滞的内部比较器< /li>
  • 内部参考电压
  • 提供8引脚SOIC和VSSOP封装
参数 与其它产品相比 温度开关
Operating Temperature Range (C)
Accuracy Over Temp Range (Max) (C)
Sensor Gain (mV/Deg C)
SetPoint Value (deg C)
SetPoint Type
Output Type
Supply Voltage (Min) (V)
Supply Voltage (Max) (V)
Supply Current (Typ) (uA)
Comparator Channels (#)
Features
Rating
Package Group
Package Size: mm2:W x L (PKG)
Interface
LM56 LM26LV LM57 TMP300 TMP708 TMP709
-40 to 125     0 to 150     -50 to 150     -40 to 125     -40 to 125     -40 to 125
3     2.3     1.5     2     3     3
6.2     -5.1 to -12.8     -5.2 to -12.9     10
-40 to 125     Range (0 to 150)
50, 60, 65, 70
75, 80, 85, 90
95, 100, 105, 110
115, 120, 125, 130
135, 140, 145, 150
-40 to 150     -40 to 125     0 to 125     0 to 125
Resistor Programmable     Factory Programmed     Resistor Programmable     Resistor Programmable     Resistor Programmable     Resistor Programmable
Open Drain     Open Drain
Push Pull
Open Drain
Push Pull
Open Drain     Open Drain     Open Drain
2.7     1.6     2.4     1.8     2.7     2.7
10     5.5     5.5     18     5.5     5.5
230     8     24     110     40     40
2     1     1     1     1     1
Built-in Hysteresis
Hysteresis (5°C)
Temperature Sensor and Switch
Built-in Hysteresis
Hysteresis (5°C)
Trip Test
Built-in Hysteresis
Hysteresis (5°C or 10°C)
Trip Test
Pin-Selectable Hysteresis
Hysteresis (10°C or 30°C)
Hysteresis (2°C or 10°C)
Catalog     Catalog     Catalog     Catalog     Catalog     Catalog
SOIC
VSSOP
WSON     TSSOP
WSON
SC70
SOT-23
SOT-23     SOT-23
8SOIC: 29 mm2: 6 x 4.9(SOIC)
8VSSOP: 15 mm2: 4.9 x 3(VSSOP)
See datasheet (WSON)     8TSSOP: 19 mm2: 6.4 x 3(TSSOP)
6SC70: 4 mm2: 2.1 x 2(SC70)
6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23)
5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23)     5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23)
Analog Output
Switch
Analog Output
Switch
Analog Output
Switch
Analog Output
Switch
Switch     Switch
方框图 (3)
技术文档
数据手册(1)
元器件购买 LM56 相关库存
